Cool Tools
Posted 13 April 2008 - 12:08 PM
Wheelrite Wheel and Tyre Simulator
Sidchrome Rotator Ratchet
AccuLevel� Pro Model Digital Level � 78311 (Pinion Angle and suspension setup)
Wheel Dolly
GearCalc - Tyre and Gear calculator
_Brewster_
Posted 13 April 2008 - 01:54 PM
love your work ls2lxhatch!
Does this tool mean that you'd be give a wheel company the correct measurements of size and offset to suit your own car?
Posted 13 April 2008 - 04:19 PM
_gmhgtr_
Posted 13 April 2008 - 05:06 PM
unless its aussie sidchrome, snap on or stahlwille is better heheI though it would be worthwhile to have a thread with a list of cool tools.
Wheel Dolly
nice little gadgets you've found i must say!!, pretty handy to have if you need them,
good finds ls2lx!
_Baronvonrort_
Posted 09 December 2008 - 12:33 PM
Posted 11 August 2009 - 09:54 PM
Avdel illustration showing nutsert installation
I hire the Profast KJ21 from Searle Fastener Sales Co for about $20 a day or weekend. Searles carry a range of nutserts.
The Profast KJ21 retails for around $275. I have used cheaper tools with pressed steel handles that typically include M3-M6 mandrels but I would not recommend them.
Teng Tools Kit $242
Edited by ls2lxhatch, 11 August 2009 - 09:55 PM.
Posted 13 September 2009 - 12:45 AM
http://www.gmh-toran...=0
RoDoMo dodgey tip #32
When your angle grinder blows up, save the arbour nuts, take them to you bolt bloke and make up one of these.
Use it in your drill, it will fit where your angle grinder wont and you'll get a bit more out of your discs.
Then, with what's left of the right angle drive, you can make a right angle drill for getting into tight spots (parcel shelf for speakers?) I wouldn't recommend using anything bigger than 1/4 drill bits though.
_splosh123_
Posted 13 September 2009 - 01:52 PM
Posted 13 September 2009 - 02:22 PM
Thats pretty easy to tighten bolts wtih.....
_splosh123_
Posted 13 September 2009 - 02:35 PM
There was an exit in my basement that i didn't know about, so my slaves escaped, so i've resorted to doing things myself *shock horror*A someoneelsedoingitspanner???
Posted 13 December 2011 - 02:12 PM
Id assume it would work the same way as a stud finder? by measuring the variations in the depth of material?
Posted 13 December 2011 - 06:44 PM
A Micronmeter is probably cheaper....
Posted 13 December 2011 - 08:36 PM
The filler detective probably just uses a magnet with load cell to measure the pull. The budget method was to just use a fridge magnet.
Posted 13 December 2011 - 08:40 PM
Posted 13 December 2011 - 08:54 PM
It is a cool gadget however I don't think it is particularly practical for this job of inspecting a car before purchase.
Edited by ls2lxhatch, 13 December 2011 - 08:56 PM.
Posted 14 December 2011 - 06:12 PM
One i got for work was about $40.
Yes metal tip, that is one downside possibly, but i've never had it mark any paint.
Posted 14 December 2011 - 06:43 PM
I get the impression that the "Filler Detective" gives a constant readout and has a microfibre base so you could just slowly wipe it over a panel.
Posted 14 December 2011 - 08:46 PM
I"ll get onto my paint shop and see if there still available and what kinda $$$ were talking now days, they have a habit of changing supplyers, which is a pita as something i could get at one stage i cant get now etc etc.
_torbirdie_
Posted 23 December 2011 - 06:09 AM
Metrinch are my favourite because they can undo rounded bolts and nuts with no worries and they also do not damage them.
Yeh, they are good for that and fit either metric or imperial and if you can afford it have them on hand for that. But PIA for everything else as they wont stay on a nut unless you apply constant force, hence easy to slip off ..skinned knuckes. other instances like if you are using a socket in a tight spot and clearance dictates that you need to put the socket on first then attach the extension bar or ratchet, the socket will fall off in the mean time! and next to useless in tight spaces where you need to turn them a few mm at a time etc.there, and/or rely on a firm fit to keep the spanner in place.
Edited by torbirdie, 23 December 2011 - 06:12 AM.
#21
_Quagmire_
Posted 23 December 2011 - 07:58 AM
a bfh and impact socket costs the same and does a better job imo
#22
_CHOPPER_
Posted 23 December 2011 - 11:12 AM
#23
Posted 23 December 2011 - 12:53 PM
#24
_Sunbird_
Posted 03 May 2012 - 10:04 PM
#25
Posted 03 May 2012 - 11:05 PM
Was a very happy boy, they dont come up very often.
I have made or renovated a heap of parts on it too, such a usefull gadget, best attachemnt is a rotary table/indexing head (Not pictured)
