'74 LH Torana Project
_BlownOutlaw_
Posted 13 June 2008 - 02:17 PM
I have been tossing and turning about whether to get this project on the move or to just sell the lot.
Maybe I need some encouraging words for other members.
Ive just bolted the 9" Diff in, so maybe I could keep going.
If I do, Im going to just bolt the lot in and once its all legal and registered properly I will pull it all appart again and make it all look nice.
As Ive only usually had cars that run on Avgas and the like with 4.55 gears and things which usually sit in the shed. This time it was to be something I could actually drive.
At the moment the run down is a 74 LH Torana Sedan. Its chamois grey and white roof.
Engine will be 307 chev.
Racematic trimatic, chev adapted.
TCE converter 3000 stall.
Raceglides built 9" diff, 3.55 gears, mini spool.
VR Commodore rear discs.
Hoppers front disc conversion.
Thats about it really. Fairly basic, low key.
Oh the wheels are the Wheel Vintiques, HQ GTS monaro look alikes in 15x7''.
Any comments or suggestions appeciated.
_BlownOutlaw_
Posted 13 June 2008 - 05:23 PM
_noslx_
Posted 13 June 2008 - 06:17 PM
Posted 13 June 2008 - 06:38 PM
just curious why you have chosen a 307 chev. Is it because you already have one?
_BlownOutlaw_
Posted 13 June 2008 - 07:07 PM
And after having a 308 before, I'd rather the Chevrolet product. Or at least I will give it a try.
_4IDFLXSS_
Posted 13 June 2008 - 07:43 PM
_BlownOutlaw_
Posted 17 June 2008 - 05:47 PM
Thanks for the replies.
Been working on the front brake conversion. Got the passenger side done.
Came to do the drivers side and found that one of the cap screws they sent me in the Hoppers Stoppers kit was incorrect!!
Not particularly happy at this point in time cause I was on a roll.
Have tried the 15" rim and it fits fine with no clearance issues.
-Leigh
_BlownOutlaw_
Posted 18 June 2008 - 09:33 AM
_1ARC_
Posted 18 June 2008 - 06:07 PM
_BlownOutlaw_
Posted 18 June 2008 - 07:37 PM
I should have said no caliper to rim clearance issues (as they say you need 15" rim dia or more).
These are HQ stud pattern, rims are 15x7. The tyres are too big on the front and I will get them changed but at present they are 235/15/60. I'll probably go back to a 205/15/50 or something like that.
I have not tried the full lock test at this stage, will have to wait till I get different tyres.
-Leigh
_BlownOutlaw_
Posted 10 August 2008 - 10:49 AM
I just checked my paint codes. I thought the car was Chamois Grey with White roof.
The codes are
568-15351 which seems to be called 'Willow' does anyone have photos of this colour??
Top - 568-13134 is Glacier White so thats OK.
Anyone know about the willow?
_BlownOutlaw_
Posted 10 August 2008 - 11:43 AM
_BlownOutlaw_
Posted 10 August 2008 - 11:49 AM
Last week the sump was delivered and I have found out the pick up tube is the wrong size for the oil pump. They told me they would send another one straight away, but I am still waiting.......
_BlownOutlaw_
Posted 21 August 2008 - 08:27 PM
Well, I did get the correct pick up for the sump eventually. I would not recommend Hi-Energy any more, they used to be good but seem to have been bought out. Im getting similar reports from other enthusiasts about them also. It took 2 months to get a sump sorted out.
Next problem has been extractors. I got the chev into Torana extractors from Castle Automotive Enterprises, as this was about the only place I believed I could find a decent premade set. Got them and these do not fit properly. They hit the steering in 3 places, partly on the K-frame and also the floor at the send of the collectors. Not a happy camper I can tell you! I have had to pull the whole engine and box out to get these back out again and now it looks like I will have to modify them myself. CAE dont seem to want to know about it. Again I have spoken to a few prominent people I know who have said they are hearing complaints about this business too.
So all in all everything has just started off well
Posted 21 August 2008 - 08:33 PM
then again it wouldn't be as much fun if it was an easy process.
Posted 21 August 2008 - 08:45 PM
This, the sump and a few of the other probs you encounter is one of the main reasons i stuck with the holden product for the street.
_BlownOutlaw_
Posted 21 August 2008 - 09:01 PM
I dont have any good photos so far, but the rego runs out on this vehicle in about 3 weeks and I am hoping to have the car totally built and running, engineered and registered by then. Lota work to do.
If anyone wants to know about some good companies. Excellent service from Hugo at Raceglides who organised my box, convertor and Michael at Ice Ignitions for the whole ignition system. These guys have only improved since the G'pak build, and are top blokes.
_BlownOutlaw_
Posted 06 September 2008 - 05:35 PM
Below engine with manifold ready to go.
Not much else to see but here is the tach mounted. Not sure what your call it or how common it was, but beside the dash and wheel, the rest of the interior is a very dark green colour, unless you were on the ball you would just think it was black, you can probably see some green highlighted by the flash.
Thats about as exciting as it gets right now. And by the way, as you can probably see, im putting this car together and getting it running first to sort out all the bugs and bad fitments etc (eg extractors!) first. It will be tidied up and made to look a bit better later down the track.
Edited by BlownOutlaw, 06 September 2008 - 05:43 PM.
Posted 07 September 2008 - 10:20 AM
What are the heads mate?
_BlownOutlaw_
Posted 07 September 2008 - 12:58 PM
Things are going along alright now.
Heath mentioned the Tacho, regarding gauges, I wonder if anyone has some suggestions of where the other gauges could be set up ? I have 4 other autometer gauges to install. There not that big 1-5/8 faces or something. Water Temp, Oil Press, and 2xEGT. I possibly may need the autometer fuel level gauge too not sure yet.
Im planning on putting the battery up front in the original spot rather than the boot this time also.
Apparantly there is an adaptor kit to adapt a B&M shifter cable to the trimatic, does anyone know about these?
Ive just trial fitted in the distributor, all looking good.
#21
Posted 07 September 2008 - 01:20 PM
I've seen some reasonably trick brackets that stick out of the ashtray area and they sit fully proud of the dash. It's not that neat but it does allow for the cool angled look and they are in good view of you when driving.
#22
Posted 07 September 2008 - 01:24 PM
The car looks nice btw.
Edited by gtrboyy, 07 September 2008 - 01:26 PM.
#23
_BlownOutlaw_
Posted 07 September 2008 - 01:35 PM
I'll try and get away with no gauge cups this time and just make an alloy plate or something, maybe down low like heath suggests, but certainly not above the dash or outside.
#24
_BlownOutlaw_
Posted 07 September 2008 - 01:51 PM
Some other stuff I need to ask is:
-Can I buy a water neck/thermostat housing from a local parts store? (I ask cause its a chev);
-What radiator hoses am I suppsed to get ? (again Chev
-What belt size would be needed, ie something standard that should fit, water pump, alternator and crank in Vbelt type.? If too hard ill just get some rope and measure it and take that size in to get one.
-Im putting the water temp probe in the port on passenger side front of manifold, there are other open water ports in manifold and water pump, should these be connected up to anything? or blocked? If I wanted to connect the heater hoses up where would they go ?
-Do you actually need the heater working for rego or only a fan ??
Thats about it so far
#25
_BlownOutlaw_
Posted 12 September 2008 - 10:58 AM
In the process of setting up shifter and cable.
Waiting on radiator/fan and fuel tank and some fittings.
Nothing worth photographing at present I dont think.
Still after advice re heater hose connections to manifold or water pump?
