I'll show you how I cut guards from start to finish
Posted 29 July 2008 - 05:27 PM
Ruts
Posted 29 July 2008 - 06:25 PM
#3 _SS Hatchback_
Posted 29 July 2008 - 07:47 PM
#4 _AGGRO_
Posted 30 July 2008 - 12:07 PM
#5 _evil_lh_
Posted 31 July 2008 - 07:33 PM
#6 _Pete_
Posted 01 August 2008 - 07:46 PM
Posted 08 August 2008 - 03:50 PM
#8 _AGGRO_
Posted 08 August 2008 - 04:06 PM
Posted 08 August 2008 - 04:10 PM
Posted 08 August 2008 - 04:12 PM
Great idea, i am yet to fit flares and cut my guards so it will be very helpful
Chears Neil
#11 _rorym_
Posted 08 August 2008 - 05:11 PM
#12 _Marshall_
Posted 08 August 2008 - 05:36 PM
Posted 08 August 2008 - 05:40 PM
Posted 16 August 2008 - 05:17 PM
G'day all, first an apology for taking so long to get thing rolling, I work shift work and sometimes it slows thing down a bit in the shed. I'll just have to give up work I suppose.
Anyway this is the first instalment of many in regards to certain paint and panel issues and I hope that someone out there may be able to benefit with some of the knowledge that I have gained after 18 years in the paint and panel industry. As the title states this is an article on fitting flares and cutting front and rear guards on a LH/LX four door. Now I don't pretent to be the guru in regards to carrying out this procedure and I know that there will me many who may disagree with the way I do things and that's fine. Over the years I have seen many many different ways to do this. I have seen some very ordinary attempts that should never see the light of day and I have seen some that look amazing, just have a look at LITRE8's car, a very professional job. The idea of the this article is to give others an insight in what can be achieved with a little careful planning and a touch of elbow grease so that you may feel a bit confident in tackling this job yourself. It's not that hard and if your prepared to take the challenge then the finished product will be very satisfying. As I go through this process PLEASE, if anyone has a better idea and thinks that I may be doing things wrong myself then tell me, I will not be offended by what you have to say and maybe I can learn a few things from others as well. Please keep in mind that I ma doing this job on my days off and it may take a week or two to get through the whole procedure. So grab a drink and sit back and enjoy this first instalment.
First a little background on this car. It belongs to fellow forum member who is getting this car ready for plenty of street driving and a little bit of track work. As this is not my toy I will keep a few things to myself about the owner and what has been done to the car but in short it's an LH four door fitted with a 350 Chev, toploader and nine inch diff. The car has flares already fitted with guards cut but after closer inspection we found that most have to be redone to bring it up to scratch. I know the owner will be reading this but I don't apologise for expressing my anger in regards to the butchers who last worked on the bodywork.
To see the pictures more clearly click to view the full size.
Here's the car,
cutting guards 001.jpg 206.1K
53 downloads
cutting guards 002.jpg 195.97K
30 downloads
cutting guards 003.jpg 172.25K
28 downloads
As we all know if you want bigger wheels and tyres you need to fit a set of flares to keep things legal and under the protruding bodywork. But when flares are fitted you also need to cut some of the body work away so that when the car moves or you put heavier loads in or you turn the front wheels you have ample clearance.
The front of the car has been fitted with 15x8 wheels and on full lock the wheels rub on the inner floor.
cutting guards 015.jpg 127.82K
29 downloads
cutting guards 016.jpg 145.44K
23 downloads
cutting guards 017.jpg 152.9K
21 downloads
This is the front with the wheels removed. You can see the shiny bare steel where the wheels have rubbed.
cutting guards 024.jpg 178.58K
24 downloads
Whoever put the flares on this car previous should be drawn and quartered. The fitment is very second rate. Have a look at how far down the front flare sits at the rear, very untidy.
cutting guards 023.jpg 123.48K 26 downloads
The rears are not much better than the fronts. Have a look at the fit on the passengers rear.
cutting guards 005.jpg 162.66K
24 downloads
cutting guards 006.jpg 152.4K
22 downloads
cutting guards 008.jpg 116.44K
20 downloads
cutting guards 007.jpg 148.27K
23 downloads
cutting guards 009.jpg 137.64K
21 downloads
Here's the driver's size
cutting guards 013.jpg 142.7K
21 downloads
cutting guards 012.jpg 156.64K
20 downloads
Anyway time to close this one so that it does not exceed the allowable whatever.
Posted 16 August 2008 - 06:35 PM
Ok, so to make things a bit easier to work on I suggest you set the car up at comfortable height to that you don't have to bend to much. I have a bad sciatic nerve so I need to have the car up a bit for ease of working
cutting guards 022.jpg 179.52K
24 downloads
What I suggest is that when you put the cars on stands you place the stands under the suspension so that the car sits at ride height and this will help with working out how much you need cut away to give ample clearance. This way in regards to the front you can put the wheel back on and turn it full lock see what sort of clearance you do have.
cutting guards 021.jpg 178.14K
19 downloads
As this car had already had flares fitted when I got the car off the ground I removed the flares and discovered more dodgy work.
cutting guards 027.jpg 176.38K
21 downloads
cutting guards 028.jpg 149.16K 20 downloads
cutting guards 026.jpg 178.24K
19 downloads
Now we were toying on putting the larger A9X style flares on this car as on one side the wheel actually stuck out past the flare (L34 style) and this was leading us to believe that the rear end may be bent after doing some measurements I found that the rear end is fine and that the problem was in the flare itself.
Note the difference between the two sides,
Drivers
cutting guards 019.jpg 121.24K
21 downloads
Passenegers
cutting guards 020.jpg 108.15K
22 downloads
So I think we will stay with the L34 flares so what I did next and what I suggest when fiting new flares is firstly make sure that the all the doors and guards are on the car so that all the gaps can be set. I've seen people try and fit flares with the rear doors removed and when the door was refitted the flare on the door and quarter panel did not match up. So as stated fit the panels and make sure the gaps are even. At this point I am going to concentrate on the passengers rear as the there is much more work in the rears than the front. Just remember when you do the other side just mirror everything we've done here. So we have the rear door gaps set to an acceptable standard. Now what I suggest you do is fit the door flare first. I do this as everything follows from this point. Set the flare where it fits the best, at the bottom of the door and against the whee larch so that its a snug fit.
Here is the same flare fitted on the same door but in the correct position. Note how much cleaner the lines look.
cutting guards 030.jpg 127.24K
27 downloads
the old
19 downloads
The top of this flare is set against the rear edge of the door. Remember, set the bottom edge of the flare against the bottom edge of the door and make sure the rear top of the flare is against the rear edge of the door. Once these edges are set then fitting the rear is fairly straight forward. Set the top of the rear flare in line with the one on the door and make sure the rear bottom edge of the rear flare is set in the correct position on the lower 1/4 panel.
Here is a picture of the door flare fitted at the top near the rear edge of the door.
cutting guards 032.jpg 109.55K
22 downloads
When I had the door flare in the correct position I tried to fit the rear section but found that the previous dodgy repairs would not allow the flare to sit snugly on the 1/4 panel so I had to make a quick cut to get rid of some of the old guard. Please note that this is only a quick fix and is not the final cut but you can see how much I actually removed. Remember to cover any openings with a sheet or cardboard so that sparks will not damage anything and always wear eye and ear protection.
cutting guards 031.jpg 185.2K
27 downloads
Once the old bent and bogged up section was removed I was able to set the 1/4 panel flare in place. This picture is the flare fitted from directly side on, note the clean gap we have between the two flares which match up with the existing door gap. Nothing better than have an even gap all the way down. Also note how much lower the flare now sits against the old markings. I now see that a few holes will need to welded up on the doors. Nothing a mig and $$$$$$$$ won't fix.
cutting guards 033.jpg 126.45K
22 downloads
When viewed from the front you can see the difference between the door and 1/4 panel flare in regards to how much one sticks out further than the other.
cutting guards 034.jpg 159.63K
17 downloads
I have marked with a texta where the 1/4 panel flare needs a bit taken off so that both match up. You can see that the flare is sitting on the cut 1/4 panel / inner guard.
cutting guards 035.jpg 161.8K
23 downloads
Take the 1/4 panel flare off and take to it with a hand file to the whatever depth you need to make the two flares meet. When trial fitting flares I suggest you fit them with self tappers and washers at this stage.
cutting guards 036.jpg 132.18K
18 downloads
When you have filled the flare trial fit it back on and see if you need to take more off or not. If all is good it should look something like this.
cutting guards 037.jpg 147.46K 23 downloads
cutting guards 038.jpg 148.24K 22 downloads
Note the nice even gap all the way down the door
cutting guards 039.jpg 128.2K
21 downloads
Note the difference between the old and the new after only 2 hours work.
Old
18 downloads
New
cutting guards 041.jpg 161.49K
20 downloads
In regards to cutting the guards I suggest a hand held grinder and a quality cutting disc. The discs I use cut like a hot knife through butter.
cutting guards 043.jpg 99.85K
21 downloads
That's all for now folks. If anyone has any questions to ask feel free to ask them. Remember there are no such things as silly questions.
Ruts.
#16 _rookie_
Posted 17 August 2008 - 07:33 AM
Thanks.
Posted 17 August 2008 - 11:07 AM
In regards to the flare sticking out you can add fibreglass to the flare to line them up. I know you don't want to paint anything or do as little as possible but you will need to paint if you done fibreglass work. I will be doing some glass work so stay tuned. Also as you will see I put small tabs of metal in behind the flares (just like an A9X) to help hold the flare in position. When I cut the 1/4 panel and door you will see very soon that I will have the same problem as you so watch and I'll show you how to overcome this.
Ruts
Posted 17 August 2008 - 11:25 AM
Ruts I don't like telling any professional how to go about something but mate get a gaurd on that grinder... specialy with them thin wheels.
Posted 17 August 2008 - 11:34 AM
#20 _Pete_
Posted 17 August 2008 - 03:27 PM
#21 _noslx_
Posted 17 August 2008 - 07:02 PM
#22 _BlownOutlaw_
Posted 17 August 2008 - 07:44 PM
#23 _Rob 5000_
Posted 17 August 2008 - 07:57 PM
#24
Posted 17 August 2008 - 08:37 PM
Well I've just had another very productive day in the shed so here is the next chapter in this epic story.
When we left you last time I had just reset the flares on the rear door and 1/4 panel to a point where I was happy with the fit. What I will concentrate on this time is the marking and cutting of the back door and rear inside dog leg. Before I start here are few pictures of some the doors I have in the shed that have been cut by myself and others before me.
This door is from my fathers original SLR5000, yeah I know about the colour but we painted it back in 1986 when Formula Blue from the VK grooup A was the in thing.
cutting guards 055.jpg 168.89K
15 downloads
The flares and inside of the doors were fitted and cut back in 1978 so I suppose this was how they cut the doors in the old days. Just like Yella's old girl there is not much taken off the door. This car was fitted with 265/50 14's hotwires and there was no problem with tyre rub.
cutting guards 054.jpg 131.71K
13 downloads
This door is from an SLR5000 fitted with large A9X flares which had 345/35 15 Pirelli's. This car had no problem with rear tyre rub but note the amount taken from the door.
cutting guards 053.jpg 136.84K
12 downloads
same door from the inside. Note the finish is a littel bit rough.
cutting guards 052.jpg 112.72K
16 downloads
This last set is from an L32 SLR which I am in the process of finishing so that I can sell this car. You can see the build of this car in 'Members projects and plans'
Passengers rear inside
cutting guards 048.jpg 113.1K
16 downloads
Passengers rear outside (unfinished)
cutting guards 049.jpg 111.71K
14 downloads
Drivers rear inside with flare fitted
cutting guards 050.jpg 118.42K
14 downloads
Same door
cutting guards 051.jpg 130.83K
19 downloads
I just wanted to show everyone the difference in each car. Now back to the point at hand.
Please note I always start with the door them work back. I believe the door flare dictates where the back half will be cut.
When the flares are fitted where you want them mark the outside of the flare so that when you take the flare off you have a guide as to where the flare sits. This will give you an idea of how much you can take off the door. Now each to there own here, take off what YOU want and what YOU think will be enough. When deciding how much to take off there are a few things to consider like, what size wheels will I use, how low is the car, what loads will I carry, will the car be used for track work, is the car fitted with a drop tank, again think of 3 people in the back and full tank of fuel (if you can afford to fill it up that is).
I used a texta as I will have to paint the outside of the door. If you think you can do it without painting then use a pencil that will rub off. This picture shows the front half removed so don't be confused. But first check to see if your happy with the fit on the inside. This picture shows the near perfect fit of the flare onto the contour of the door.
cutting guards 056.jpg 119.12K
15 downloads
If I'm happy I mark the outside of the flare. This picture was taken with the front half removed but don't take it off yet. I got a bit ahead of myself.
cutting guards 057.jpg 145.77K
14 downloads
I then mark on the inside of the door where I want the cut made. Please note I have marked the ridge where the flare sits against. This ridge hold the flare in the correct position so I want to leave a bit of steel below the ridge to help hold the flare out. I have also marked a spot weld that holds the door skin on. I would not cut lower then this spot weld as this may pull the door skin away from the frame before you get a chance to weld the door which could distort the door skin. The dotted line is where I will make the cut, as you can see there will be a fair bit removed but this is what the owner wanted.
cutting guards 046.jpg 125.32K
14 downloads
I then carry this mark around the corner and onto the flare which will help me line up the rear cut later.
cutting guards 047.jpg 120.98K
12 downloads
I then close the door and mark the rear flare at the same point as the front half.
13 downloads
Remove the door flare and prepare yourself for cutting the door. Ear and eye protection and guard on your grinder (sorry could not help myself) then cut along your cut line. This picture is halfway through the door cut.
cutting guards 058.jpg 120.34K
12 downloads
And then all off.
cutting guards 059.jpg 125.58K
13 downloads
This is how the door looks after the piece is removed. There is a bit of a gap but we can improve on this with a bit of tidy up work.
cutting guards 060.jpg 158.86K
12 downloads
#25
Posted 17 August 2008 - 09:32 PM
When I'm happy with the door cut I close the door and then mark the inner dog leg tracing from the cut in the door. Note that door cut matches with the mark on the rear flare.
cutting guards 061.jpg 128.74K
15 downloads
cutting guards 062.jpg 119.62K
13 downloads
The line on the dog leg is where I will make the cut in the dog leg.
cutting guards 063.jpg 142.34K
9 downloads
Well I was lucky with this one the line on the dog leg met up with the edge that I had already cut on the 1/4 panel. Better by myself a lottery ticket.
cutting guards 064.jpg 126.55K
12 downloads
When I'm happy with the cut line on the dog leg I cut away.
cutting guards 065.jpg 128.94K
10 downloads
When the cuts are made you will probably have a rough line. I then take my trusty Rupes grinder and with 36 grit attached I clean up all the cut edges. PLEASE BE CAREFULL AT THIS POINT. THE GRINDER CAN CATCH THE EDGE OF THE PANEL AND TAKE OFF SO PLEASE PLEASE BE CAREFULL. If you do not feel confident with a paper grinder then use a stone angle grinder to clean up the edges.
cutting guards 066.jpg 256.9K
12 downloads
cutting guards 067.jpg 131.71K
10 downloads
cutting guards 069.jpg 122.31K
12 downloads
When the grinding is done you should have a nice clean edge to work with.
cutting guards 068.jpg 137.19K
14 downloads
Looking up from underneath
cutting guards 071.jpg 332.73K
14 downloads
When I'm happy with the edges on the door I use a pair of multi or vice grips and slowly slowly work the inner and outer skins together. Do not clamp them tight as this may pull the outer skin in and distort the door which will cause you to carry out repairs to the now warped door skin. I leave about a 3-4 millimetre gap which I will weld up and smooth off.
cutting guards 073.jpg 122.71K
14 downloads
cutting guards 074.jpg 114.43K
12 downloads
When I'm happy with the gap between the inner and outer door skins I take my trusty mig welder
cutting guards 075.jpg 242.72K
11 downloads
and start to weld up the door a bit at a time to prevent panel distortion.
cutting guards 076.jpg 109.66K
11 downloads
cutting guards 077.jpg 126.55K
13 downloads
cutting guards 078.jpg 208.07K
14 downloads
After tacking the door I then work the inner dog leg out to meet the outer leg. Remember slow and steady wins the race.
cutting guards 072.jpg 282.28K
15 downloads
When I get the inner dog leg close to the outer I use a pair of vice grips and get the two close in the same manner as the door. Remember about 3-4 millimetres then weld up the gap. Just like the door don not clamp them tight as this will distort the outer dog leg and you will have to repair the area where the clamps were attached.
cutting guards 080.jpg 137.17K
13 downloads
When the door flare is refitted you can see the difference from when we started and exactly how much more room we have underneath.
cutting guards 084.jpg 320.51K
12 downloads
And how much we removed
cutting guards 082.jpg 129.77K
16 downloads
Well that's it for now. Tomorrow I will be filling up the gap between the inner and outer skins on the 1/4 panel and finishing off the welds.
remember if you have questions please ask and if you want photo's from different angles just let me know.
Ruts.
