[Torviki] Specifications - Track
2 replies to this topic
#1 ls2lxhatch
  • 5,332 posts
Posted 06 October 2008 - 02:52 PM
Article title: Specifications - Rims, Tyres And Track
Article description:
Category: General LH-LX-UC
Date added: Oct 6 2008, 12:52 PM
Article starter: ls2lxhatch
LX RTS S & SL
Rim 13x4.5" Offset +0.75" ( 19 mm ) PCD 5x4.25" Stud 7/16" UNF Source: Unconfirmed
Tyre 175SR13 (Approximate metric equivalent is 175/70/13) Source: LX Torana owners manual
Track Front 54.9" (1394 mm) Source: LX Torana owners manual
Track Rear 54.0" (1372 mm) Source: LX Torana owners manual
LX RTS SL/R & SS
Rim 13x5.5" Offset +1.25" ( 32 mm ) PCD 5x4.25" Stud 7/16" UNF Source: Unconfirmed
Tyre CR70H13 (Approximate metric equivalent is 205/70/13) Source: Unconfirmed
Track Front 55.3" (1405 mm) Source: LX Torana owners manual
Track Rear 54.4" (1382 mm) Source: LX Torana owners manual
L34
Rim 14x6" Offset -0.25" ( 6.37 mm ) PCD 5x4.75" Stud 7/16" UNF Source: Unconfirmed
DR70H14 (Approximate metric equivalent is 200/70/14) Source: Unconfirmed
Track Front 57.89" (1470.4 mm) Source: "Holden Torana Performance Handbook" by Eric Blair 1993 p 64 and 65.
Track Rear 56.82" (1443.2 mm) Source: "Holden Torana Performance Handbook" by Eric Blair 1993 p 64 and 65.
L34/A9X
Track Front 57.2" (1452.88 mm) Source: "45 Years of Holden" Terry Bebbington and Michael Malik 1994 p 93 and 96.
Track Rear 56.1" (1424.94 mm) Source: "45 Years of Holden" Terry Bebbington and Michael Malik 1994 p 93 and 96.
A9X Hatch & Sedan
Track Front 59.5" (1485.9 mm) Source: Just Holdens Toranas collectors series. A9X edition pg 23
Track Rear 57.1" (1450.3 mm) Source: Just Holdens Toranas collectors series. A9X edition pg 23
Track
Wheel track is measured from the centre of the tyres. Wheel track will vary on the front suspension depending on ride height as the control arms swing in an arc. To maintain track all you have to do is maintain the standard offset regardless of the rim width.
Backspace
The trick to backspace is that the rim width is measured from the inboard tyre bead seat to the outboard tyre bead seat. Backspace is measured from the inboard flange to the hub. There is typically 0.5" of flange beyond the tyre bead seat. If you measure an 8" wide rim from flange to flange it will measure 9.0". If you measure from the inboard tyre bead seat to the outboard tyre bead seat it will measure 8.0".
Edit Notes:
6/10/08 Added specifications posted by JBM
VIEW ARTICLE
#2 _JBM_
_JBM_
Posted 06 October 2008 - 09:12 PM
L34 Front Track 57.89" (1470.4 mm) Rear 56.82" (1443.2 mm) Source "Holden Torana Performance Handbook" by Eric Blair 1993 p 64 and 65.
L34/A9X Front track 57.2" (1452.88 mm) Rear 56.1 (1424.94 mm) Source "45 Years of Holden" Terry Bebbington and Michael Malik 1994 p 93 and 96.
James
#3 ls2lxhatch
  • 5,332 posts
Posted 06 October 2008 - 10:31 PM
James,
I have added your specifications and references.
I have also added my references where possible.
I would like to get confirmation of standard tyres and sizes if possible.
