LED Lighting
Posted 30 December 2008 - 07:34 PM
As part of my dash installation, I'm changing some of the original bulbs to LEDs.
Jaycar have 12V LEDs which have a resistor already in the circuit, and it's on the -ve side of the light.
I had to buy a blue LED for high beams which did NOT have the resistor, and the gentleman at Jaycar kindly worked out the resistor i needed to use which was 510 Ohms. ( Which if i recall correctly SSHatchback mentioned to me was the right value!).
A Question, Does the Resistor go on the -ve side of the LED or the +ve?
Just for note, I'm using the standard 5w incandescent lamps for the brake/fail and the Altenator lights because i dont want to risk the altenator not charging if i take the light out of circuit!
Cheers Gents!
Posted 30 December 2008 - 07:48 PM
Posted 30 December 2008 - 07:51 PM
These are on the -ve, so i might go with that i guess!
Posted 30 December 2008 - 07:55 PM
Posted 30 December 2008 - 08:13 PM
I'm currently Autocadding everything to see if i can fit it all in!
Cheers guys
_SS Hatchback_
Posted 01 January 2009 - 07:15 PM
Cant wait to see the finished product
Posted 01 January 2009 - 08:04 PM
I had remebered "somewhere" around the 500 ohm mark, so when he mentioned 510 Ohm i thought fair enough! He did look up the specs, so hopefully he's close!
I'll definitely be posting pictures, So far so good!
Cheers!
_slr253_
Posted 21 May 2009 - 10:08 PM
How did the LED conversion go? Does the dash look a lot better than the dull yellow glow?
Any pictures of the end result? Do you have any advice from the experience of fitting LED's?
Cheers,
Brett
_torana_umunga74_
Posted 21 May 2009 - 10:27 PM
_Squarepants_
Posted 22 May 2009 - 04:37 PM
Yeah, the dimmer is now just an on/off switch in mine.i dont think the dimmer works with LEDs i might be wrong tho. they are a sh*tload brighter tho.
Posted 05 June 2009 - 12:52 AM
LEDs don't dim very well, so as you drop the voltage by dimming the lights, the LED will get dim pretty quickly. Also, LEDs are very directional, so while thye're bright when looking straight at them, they can be quite dim when looking at an angle. For car dash use, you need to diffuse the light, eg by using a few LEDs and a plastic diffuser like is used on fluoro lights. For a cheap option, you can sandpaper the top of the body of the LED, which diffuses the light as well.
Tiny, you're probably right with the alternator light globe - most use the current flowing through the globe to excite the alternator stator windings, and if you change the wattage of the globe, you change the characteristics of the alternator. You can use an LED on the dash with an appropriate resistor, but you need to keep the incandescent globe in circuit, even if you can't see it.
_Squarepants_
Posted 05 June 2009 - 06:09 PM
Similar to the tail light led's that Keith is selling, apparently. (I'm keen Keith, just gotta get around to calling you back)
My Dad put single led's in his Hilux tail lights and you could only really see them if you're directly behind it, if you're off on a bit of an angle they were very hard to see.
_Kermit SLR_
Posted 10 June 2009 - 06:05 PM
The rear lights i used 80 X 80mm trailer type multi led's. Single amber for the indicators and a red stop/tail combination. I removed the old globe and fitted them to the globe holder/backing. I have the white plastic type. Then fitted the original lens back over the top. I think it looks great now. Realy bright when standing behind.
I got sick of dull lights and my alt light glowing dimly all the time. There was voltage drop over just about every circuit.
Took me months as i work away 2 weeks at a time and have little time when i'm home for a week.
Multi LED,s are the way to go. I bought most of mine on Ebay. Really cheap. If anyone wants to know from where, i'll dig up a reciept.
K.
_Squarepants_
Posted 10 June 2009 - 06:23 PM
I've heard red light doesn't like to go through red lenses.
Do you use a multi in your number plate light? If so, I'd be interested in where you got that.
_Kermit SLR_
Posted 10 June 2009 - 11:03 PM
Kermit, do you use coloured LED's behind coloured lenses or white LED's?
Hi Squarepants,
Front indicators are a multi-led white. Dash is multi led's white. Tail lights are coloured 80 x 80 led's, red behind red, amber behind amber. The numberplate light is a single led and is plenty bright enough. Cant remeber the type of socket in the plate light, but if its the same wedge type as the dash, you can get them in multi. White, red, green and blue i think.
I will be flying home tomorrow from nightshift, so will post some pics and the ebay store i bought them from, sometime on Friday.
K.
_the gts_
Posted 10 June 2009 - 11:42 PM
please post some pics.
Squarepants - who is 'keith' that may be selling some?
Anyone know the legalities of these?
_BAILLIE_
Posted 11 June 2009 - 07:02 PM
There seems to be a fair amount of suitable bits on the net that could be used in a custom set-up, and Autobarn stocks a few things too. I nearly bought a new bolt-on number plate lamp the other day, looked half-decent and not too bulky, i think they make em for trailers.
Had a think and realised a good number plate light is not that high on the old priorities at the mo.
_Squarepants_
Posted 11 June 2009 - 07:10 PM
GTS, Keith is a member on this forum. His details can be found in this thread: http://www.gmh-toran...showtopic=36540
_BAILLIE_
Posted 11 June 2009 - 07:11 PM
the legalities not a problem. As long as your not changing colours (like blue indicators or purple tail lights) and they comply with the relevant ADR laws. Basically they have to be as bright or brighter than the original setup, and i guess it works the other way too, they shouldnt be so bright as to blind the person behind you when you brake for example... obviously...
I think there is some proper kind of test you can do, but it;s pretty easy to tell with your own eyes.
Dont know if an engineers report is needed, ? Kermit?
_keith1962_
Posted 11 June 2009 - 07:16 PM
cheers Keith
#21
_the gts_
Posted 11 June 2009 - 10:17 PM
Yea looking forward to the pics from kermit.
I will ask my engineer when i speak to him next, would hate to do all that and get knocked back at the pits.
#22
_BAILLIE_
Posted 12 June 2009 - 04:23 PM
#23
_Kermit SLR_
Posted 12 June 2009 - 10:22 PM
This is the interior light, bit hard to tell but it's a 16 LED light
This is the front park light - multi LED (BA9S)(Thanks Squarepants)
This is one of the Multi LED dash lights. Wedge type
This is the front indicator globe:
This is the lail light assembly with the 80 x 80 LED'S
This is the park light and indicator on (late afternoon)
Park lights and reverse lights (at night)
Hard to guage the brightness of them but they are highly visable during the day.
As for the legalities of the rear led's i am unsure. Have not checked with any authorities :-)
But they are brighter than standard globes.
The front park lights emit a great white light, really stands out.
You may have noticed i have a single green LED for the numberplate light. With a multi globe (same as the front park) the plate would be extremely well lit.
The Ebay store that i bought the globes through is http://stores.shop.e...S__W0QQ_armrsZ1
Hope all this is uploaded correctly
K.
Edited by Kermit SLR, 12 June 2009 - 10:30 PM.
#24
_the gts_
Posted 12 June 2009 - 11:49 PM
they would definately be a preference over normal globes. can you get orange for the front so it is legal to use the clear front lenses?
I am thinking of modifying the tail lights and fititng the panel type LED's behind the normal torana lense so it looks like the new truck type ones where you can see there is individual LED's in there. anyone think that would look ok on a Torana?
silmilar to these
Edited by the gts, 12 June 2009 - 11:59 PM.
#25
_Kermit SLR_
Posted 13 June 2009 - 09:01 AM
Thanks for the pics kermit.
silmilar to these
From memory, you can get the amber LED's for the front (check the Ebay website i listed or contact Keith, as he seems to have access to LED's. Better to support a fellow Torry owner eh.) I have the orange lenses so i didnt bother.
The 80A lights you have pictured are similar to the ones i have fitted.
I think the 100mm will fit also. If you fit them, you have to mount them higher on one side in the holder (behind the lens) so the LED assembly is "level" with the lense.
K.
P.S. Found the amber globes "the GTS", heres the link :
Edited by Kermit SLR, 13 June 2009 - 09:13 AM.
