I picked up an SLR cluster in very bad condition.
![Attached File](https://www.gmh-torana.com.au/forums/public/style_extra/mime_types/gif.gif)
found the 4in1 gauges fryed. Came across these on ebay
with a bit of drawing, cutting and disecting it looks like the 52mm vdo gauges will fit in behind the face
I plan to use the lighting method the vdo 52mm gauges use. I am also using the rare spares replacement decal set, which i found light can go thru the decals
I am going to put this in a sl cluster. it will need i bit of cutting.
If i get this done, no more voltage regulator!!!!
