Any panel/paint Expert wanna be my MSN mentor?
#1 _Viper_
Posted 17 December 2009 - 07:17 PM
I know I can just use the forums, and I will be too... but its good to have that instant answer and you get a conversation going on msn which I find helps alot more.
So yea if anyone would like to help add me with [email protected]
Posted 17 December 2009 - 11:30 PM
#3 _Yella SLuR_
Posted 18 December 2009 - 01:05 AM
#4 _Yella SLuR_
Posted 18 December 2009 - 01:28 AM
Edited by Yella SLuR, 18 December 2009 - 01:30 AM.
#5 _Viper_
Posted 18 December 2009 - 09:32 AM
But Yea... nothing like a deadline to get ya ass into gear... but If I dont make it I dont make it... I still have 2 weeks holidays after motorvation.
P.S Msn is this handy little internet tool where you can chat to someone in real time... every computer has it now and even my mum can use it
#6 _Bomber Watson_
Posted 18 December 2009 - 03:55 PM
#7 _Viper_
Posted 18 December 2009 - 04:03 PM
#8 _Bomber Watson_
Posted 18 December 2009 - 04:05 PM
#9 _Viper_
Posted 18 December 2009 - 10:55 PM
#10 _Viper_
Posted 18 December 2009 - 11:12 PM
Edited by Viper, 18 December 2009 - 11:22 PM.
Posted 19 December 2009 - 12:24 AM
I will add you but i'm here more than anything.
#12 _Viper_
Posted 19 December 2009 - 10:02 AM
Also just reading the Technical data sheet it says
"If 410-48248 Epoxy Urethane Primer is left to
dry longer than 8 hours, it should be sanded
with P180-P240 and re-coated with itself."
So that means I have to spray the epoxy then give it a few coats of normal primer shortly after? whys that :S I thought I was supposed to put any filler on after the epoxy and before the primer? or can I use filler over the normal primer?
It says to use:
"Flash off for 25 minutes then overcoat with:
PPG Polyester Spray Filler (468 Line) WOW after 25
minutes @ 25ºC. (sanding not required)
PPG two pack acrylic urethane primer filler (467 line)
after 25 minutes @ 25ºC. (sanding not required)
PPG Polyester Body Filler after 25 minutes @ 25ºC.
2K Wet on Wet primer after 25 minutes @ 25ºC.
(sanding not required)"
Which one is best? and what does "WOW" mean?
Edited by Viper, 19 December 2009 - 10:10 AM.
#13 _Bomber Watson_
Posted 19 December 2009 - 11:43 AM
WOW means wet on wet.
I've never used that particular primer but i cant see why you would have to put anything different over it, or itself, should be able to put top coat strait over after sanding and most epoxy's i've used want a lot longer than 8 hours to flash off....
Im going to take a random guess and say the first one, 2k poly spray filler 468 line is best, usually they put them in order of preference.
I've always put filler over bare metal, im old fassioned, but one day will try the whole over primer thing.
Just re read all that and realized im of no use to anyone
#14 _2runa_
Posted 19 December 2009 - 12:37 PM
Bomber are you saying as a rule the you can place filler (bog) over an epoxy primer filler or epoxy etch primer without going back to metal maybe I'm ...school as wellI've always put filler over bare metal, im old fashioned, but one day will try the whole over primer thing.
#15 _Bomber Watson_
Posted 19 December 2009 - 01:35 PM
I have done it in small portions at work on trucks just experimenting with no dramas yet.
Obviously if its only a small imperfection then you just use a bit of spot putty, i use Upol Hot Shot, great stuff.
Just bigger imperfections that im not so sure about.......But like i said i'll try it one day, probably on the LH.
#16 _yldlj_
Posted 19 December 2009 - 02:27 PM
Edited by yldlj, 19 December 2009 - 02:30 PM.
#17 _Viper_
Posted 19 December 2009 - 02:42 PM
That data sheet isnt for the exact primer I got... The one I got is 410-34294 Epoxy Primer Beige... But I cant find the data sheet for it anywhere. On the small instructions on the back of the tin it says it doesnt need any sanding and doesnt mention 8hrs working time to apply another primer so maybe its a little different.
Doing the bootlid first and I just need to put a little bit of filler where the lock has been cut out and plated... and there seems to be a small gouge from a grinder in the top corner.
On the tafe course they said to use the filler on top of the epoxy but under the primer
Ok so 20% thinner it is..
Should I sand the baremetal with anything? 180? 220? or just leave it... (I use paint stripper and a clean n strip disc to stop the paint to its pretty smooth)
#18 _Bomber Watson_
Posted 19 December 2009 - 02:54 PM
#19 _yldlj_
Posted 19 December 2009 - 05:27 PM
Posted 19 December 2009 - 05:49 PM
I have never used that product but it sounds like straight etch, i use etch primer which which can be coated over but this one sounds like it needs a primer over it before coating.
So as with acrylic, you need to etch, let it flash then prime.
I don't really think it matters what primer you use but the key here is to apply it soon after or you will have to sand the etch, re apply it again then primer.
If in doubt I suggest contacting the supplier for their recommendation, as an agent they should be happy to help.
FYI you can use 2K filler over the primer but this is for minor scratches and dimples etc missed while repairing, any substantial repair should be made on bare metal and the whole area primed and blocked, then once all that is done, etch and prime the rest of the car in preparation for a block down.
#21 _Bomber Watson_
Posted 19 December 2009 - 05:54 PM
For instance the primer i would have used in vipers position, Protec EX-408, you just put that over bare metal and its about as high fill as you can get strait up. Then after blocking 2k top coats go strait over that.
Every epoxy i have used has been like that....im confused with this one.
Viper, is it really thick or really thin??
#22 _Viper_
Posted 19 December 2009 - 06:00 PM
Spoke to my mate who is a 1st year app and he said most epoxys you dont have a set time to spray the primer on but you do have to use a primer and cant spray the basecoat direct over the epoxy... He uses PPG at work too.
#23 _yldlj_
Posted 19 December 2009 - 06:06 PM
#24
Posted 19 December 2009 - 07:19 PM
hi bomberOk, starting from the top, the amount of thinner depends on how much build you need, just go strait for 20%.
you are 100% correct ,but im not a big fan of poly spray filler ,panel shop still go the old fashion way ,but when i do resto's i tend to repair as much as i can using easy beats ,hammer and dollys and a body file ,then apply epoxy over bare metal allow to dry for up to weeks then guide coat and block with 180 grit ,if there is any imperfections you may fill with some body filler ,this way you dont get any moisture under the filler and hands are not touching bare steel,re epoxy and then hifill
cheers grant
#25 _Bomber Watson_
Posted 19 December 2009 - 10:52 PM
As i said i can see many benefits from putting filler over primer, just have yet to try it.
Think the LH i may do that way.
