positioning your baster coil and 6AL
_SSbloke_
Posted 26 January 2010 - 10:01 PM
Posted 27 January 2010 - 06:50 AM
My coil is on the firewall, and the box behind the driver side headlight (charcoal canister relocated to underneath, in front of wheel):
The wiring has since been tidied up
Edited by 76lxhatch, 27 January 2010 - 06:51 AM.
Posted 27 January 2010 - 11:09 AM
Ev
_SSbloke_
Posted 27 January 2010 - 12:41 PM
Posted 27 January 2010 - 04:43 PM
Posted 27 January 2010 - 09:02 PM
The MSD 6A/6AL are not digital, I don't know whether the digital versions also make noise.
_SSbloke_
Posted 27 January 2010 - 10:17 PM
Posted 28 January 2010 - 06:58 AM
Lots of people put them in the engine bay without heat issues, the only thing they specify with mounting is to keep them somewhat upright to avoid any moisture collecting inside the container.
_SSbloke_
Posted 28 January 2010 - 08:20 AM
MSD claims that they operate right down to about 5V but one would have to assume that the spark is somewhat diminished. You could just run a bigger cable to compensate, if I recall correctly the instructions that come with even have recommendations for wire gauge and distance.
thanks for that, i reckon i will run it on the passenger side of the engine bay
_RLH308_
Posted 29 January 2010 - 08:26 PM
It's another option for you anyway.
_Torana308_
Posted 30 January 2010 - 10:42 PM
_@milco@_
Posted 02 February 2010 - 06:57 PM
_L32M20_
Posted 08 May 2010 - 10:52 PM
My car had the coil under the dash and used one of thise firewall feed throughs, I had two crack right down the sides allowing it to arc to the body. I moved my coil to the engine bay now.
can you tell me the effect of this arc ing out on body,did it damage the msd , coil or paint work? and was the car undrivable,like did you break down somewhere?
