LX Wheel alignment settings
Posted 18 August 2010 - 10:18 AM
But I've been wondering what settings I should actually aim for? The settings I'm after are for something I would consider 'sporty' i.e. regular use vehicle on good street tyres, no ridiculous camber or anything but more aggressive than factory settings to make it turn in better. I thrash the pants off it through the twisties etc
What have you used in the past with good success? Any comments about setups that did or didn't seem to work well? Should I just ask the expert doing it?
I was thinking in the ballpark of -1.5� Camber and +1.5� Caster, and some 'small' amount of toe in?
Opinions appreciated.
Posted 18 August 2010 - 11:10 AM
RTS gives increasing -ve camber on compression so needs less initial, also provides more +ve caster.
Posted 18 August 2010 - 11:59 AM
I like around -1 degree camber regardless of RTS or not; you may get away with -1.5 but I would think it will start eating the tyres a bit much. It may seem like a good idea to have more negative camber with non-RTS but you lose the ability to dial in some positive caster if you do that.
Toe 0 with UC RTS, 1mm or 2mm toe out (yes out) with non-RTS helps induce a bit of oversteer to make up for the lack of positive caster. This does assume a reasonably solid front end with urethane bushes etc, perhaps add 1mm or 2mm of toe in for rubber especially if a bit old. Compared to Commodores which love to tramline, a Torana will still sit on the road nicely even with a touch of toe out, so its not really a big issue.
Caster as much as you can get while maintaining wheel clearance and acceptable steering weight. With non-RTS and -1 degrees camber or less you should be able to get up to 1 degree caster without excessive/unsafe shimming. With UC RTS you should be able to get at least 1.5 degrees easily, anything over 2 you have to decide how heavy you want the steering.
Posted 18 August 2010 - 12:44 PM
I just did my upper arm bushes with Super Pro urethane units; I figure they are pretty important in keeping nice rigid camber, I was going to do the lower arms but the rubber bushes there were okay so I just left them.
Interesting about the toe... I will keep that in mind. But I am a bit hesitant to go static toe out because I haven't "done" everything on the front end, just fixed a few things that were pretty stuffed. There might be a bit of play in certain things (I haven't really cared about the handling of this car until now)
_Herne_
Posted 18 August 2010 - 01:06 PM
Herne
Posted 18 August 2010 - 01:24 PM
Posted 18 August 2010 - 01:40 PM
The toe can be difficult to set very accurately (e.g. to within 0.5mm) at home without good measuring equipment to begin with, but if you were to find out while the car is on the alignment rig exactly how much one turn of the tie rod end equates to then you could muck with it to your heart's content after the initial alignment. Just make sure you write down any changes and make alterations in terms of increments of turns, from the known starting point at wheel alignment. (Don't forget to adjust both sides evenly if you want to keep the steering wheel centred)Interesting about the toe... I will keep that in mind. But I am a bit hesitant to go static toe out because I haven't "done" everything on the front end, just fixed a few things that were pretty stuffed. There might be a bit of play in certain things (I haven't really cared about the handling of this car until now)
And yeah the wheel alignment guy did look at me funny when I told him I wanted toe out the first time, but I was happy with the result.
_robslxhatch_
Posted 18 August 2010 - 01:54 PM
^ problem herne is that alot of guys these days never worked on toranas or old cars at all and realistically would not give a shit if the 2008 corolla has 1deg extra camber, just gets them back sooner for tyres.
not real good for repeat business TerrA , if i did a wheel alignment on a car of yours and it chopped up a tyre due to a camber issue would you come and buy tyres off me???. There might be people out there that don't care , but they probably work for a franchise . Heath you cant go wrong with what most are saying , which is 1-1.5 deg neg camber (more will chop tyres) as much castor as you can get (reasonably) and somewhere around 0 toe .
_Herne_
Posted 18 August 2010 - 03:02 PM
I would normally agree but I quote
"After I can sort the stance of my green car out I'm going to take it in for a wheel alignment at 'Edgars Tyrepower', a Melbourne workshop that has been recommended to me (apparently the bloke has done a lot of racing classic cars so he knows his stuff)"
Heath has obviously asked around or researched this guy somewhere/somehow....
Think about it
Herne
Posted 18 August 2010 - 03:13 PM
And Torana owners on here who have given a lot of thought to the suspension of their Toranas have probably played with different combinations a bit, people like Peter_UC or Brett_32i, or anyone who races etc
Anyway good stuff so far, cheers. I am aware of adjusting the toe without a machine by going off the thread pitch and geometry, will definitely keep that in mind!
My comment was not aimed at anyone and especially not at the mob that heath has named, just a generalisation of the way the industry has gone, from spare parts to tyre mobs thru to mechanical repairs, most of them hardly give you the time of day and from personal experience fixing friends and neighbours cars after they have been to a mechanic, most business are more that happy to take your money, no matter if you come back or not.
Sorry if my org. comment offended, I myself only use a guy that built ATCC toranas BITD, I trust his work as he does mine.
Posted 18 August 2010 - 08:38 PM
The above settings are all static and will give you good handeling and good tyre for every day driving on the road. For track work I would run around 1.30min -2.30min deg neg to both sides camber and even caster of around 3.30min positive.With track work you could give it a bit of toe out to increase the turn in with less understeer at high speed cornering
Make sure your drive axle is square in the chassis for all above settings
Now before you all argue just remember how many companys make camber kits for vehicles that totaly screw a set of tyres in now time flat, It wasn't untill the VE commodore that they started to produce vehicles with relistic cambers, they did this by coppying the Germans. (fact) Holden purchased a BMW E39 5 series and coppied it, the engineers admitted this in an interview 12 months after the release of the VE and at the time this vehicle was still in the Holden vehicle fleet. Remember how bad the VB-VC-VH-VN-VS choped out tyres with 1 1/2 degrease negitive camber and they recomended 2.5mm toe in.
With sloppy front ends you can get away with wild setting, stiffen it up with good shocks,springs,bushes and sticky wide tyres and you will need good setting to suit. Its all about the foot print of the tyre on the road surface, and you just carn't go through corners fast enough constantly on the street to get good tyre ware through high negitive camber settings, race cars can, street cars carn't.
Hope this helps.
Lenny
_robslxhatch_
Posted 18 August 2010 - 10:43 PM
[/quote]
[/quote]
its all good ,no offense taken , but there are alot of good operators around who have pride in thier work ,unfortunately the bad ones ruin it for everybody. i could not count the amount of wheel alignments i have had to 'fix' after getting done at shonky places. You are dead right in what you said though too many people have the 'dont give a fRock attitude'. You should always try to get someones recommendation and if you cant, then go somewhere that the owner of the bussiness is the one doing the work ,if you go somewhere and the owner hands your keys to some young bloke who hates his job and is too busy thinking about the contents of some young girls undies then that above mentioned attitude may apply.
Posted 19 August 2010 - 07:40 AM
Posted 19 August 2010 - 07:43 AM
_CHOPPER_
Posted 02 September 2010 - 03:26 PM
Depending on his wheel/tyre combo I would probably start with:
Castor: +1.5 deg
Camber: -1.0 deg
Toe in: +2.5mm
Those figures are merely a starting guide. Any or all of the above settings could/should be altered depending on several factors after a couple of months driving on the initial settings.
Posted 02 September 2010 - 05:44 PM
_mello92_
Posted 02 September 2010 - 09:07 PM
Got me stumped..
Posted 02 September 2010 - 09:16 PM
_cruiza_
Posted 02 September 2010 - 09:25 PM
#21
Posted 02 September 2010 - 09:26 PM
#22
Posted 03 September 2010 - 04:16 PM
#23
_mello92_
Posted 03 September 2010 - 10:37 PM
#24
Posted 03 May 2011 - 07:15 PM
Lenny.
#25
Posted 03 May 2011 - 07:20 PM
