Are all "HQ" stubs the same?
Posted 15 November 2010 - 12:35 PM
Posted 15 November 2010 - 01:30 PM
You are looking for a set of tonner ones as they are heat treated.
there is thread round here somewhere that gives the correct part number.
Grant..
Posted 15 November 2010 - 01:35 PM
HQ-HJ drum brake 7432662 (these are the same as HK-HG);
HQ-HX disc brake 2820996 and 7 (with cast iron calipers) (these should also be the same s HT-HG);
HQ-HX Drum brake 1-tonner 9932966;
HQ-HX Disc brake 1-tonner 9932964 and 5 (with cast iron calipers) - same as L34.
HX-WB disc brake 9943693 and 4 (with cast/aluminium calipers);
HX-WB disc brake 1-tonner 9943695 and 6 (with cast/aluminium calipers).
From memory the calipers for cast/alloy PBR or Girlock from HX-WB are just machined a bit different in the caliper mount area.
1-tonners are heat treated for superior strength, when you clean them up they are all purple and blue around the inner bearing area.
A9X are nothing special as far as I know, they are just HX-WB 1-tonner examples to suit allo/cast PBR or Girlock calipers.
#4 _CHOPPER_
Posted 15 November 2010 - 10:20 PM
#5 _cruiza_
Posted 16 November 2010 - 06:53 AM
the tale I was told is it is the exact same part! HQ to WB
as the casting wore a new one was made with a new part number
A9Z and one tonner are not beefer they are standard part heat treated, and yes after being cleaned up look for blueing around the bearing area
I had a set of each and could not find any difference at all in size
Posted 16 November 2010 - 07:17 AM
The HX part catalogue is quite clear though on different part numbers for early full cast stubs vs the later cast/alloy calipers. There must be a slightly different machining on them to suit the different calipers.
#7 _CHOPPER_
Posted 16 November 2010 - 08:39 PM
Posted 17 November 2010 - 05:35 AM
I think yel327 is correct above about the machining though, while the bolt pattern is identical some stubs may require extra machining to fit certain calipers?All HQ - WB calipers fit all HQ - WB stub axles.
Posted 17 November 2010 - 06:07 AM
#10 _rorym_
Posted 17 November 2010 - 05:53 PM
HX one tonner on left...notice heat treating...same stubs as A9X..same part number..
HQ on right..
Identical other wise.
I spent 3 months on this..trust me.
Edited by rorym, 17 November 2010 - 05:56 PM.
Posted 17 November 2010 - 09:07 PM
#12 _CHOPPER_
Posted 17 November 2010 - 10:19 PM
#13 _rorym_
Posted 17 November 2010 - 11:16 PM
Edited by rorym, 17 November 2010 - 11:19 PM.
Posted 18 November 2010 - 12:40 AM
Posted 18 November 2010 - 06:49 AM
If you look past the dirt on the right stub axle, you'll see that it has different machining around the brake caliper mounting holes and won't fit some types of calipers (at least not without some more machining)
edit: actually I never noticed this until now but the one on the right may also sit the steering arm slightly differently too?
Edited by 76lxhatch, 18 November 2010 - 06:51 AM.
Posted 18 November 2010 - 01:34 PM
Posted 18 November 2010 - 04:23 PM
Ive recently pulled the stubs and calipers out of a HZ tonner.
Cast aluminium calipers.
One stub has the number "GM43696" on the outside face,Im guessing this is correct HZ/A9X.It is also blue from heat treating.Dunno where the "99" went from the front of the part number,its not there.
There is also a letter "G" cast into it on the back face below the top ball joint.
The other stub,by comparison,has no numbers that match the above list,it also shows no "bluing" as a sign of heat treating.
My question is,what is it out of?
On the front face just below the top balljoint is the number "65". Nothing else on the front face.
On the back face it has "43 95" and about an inch under that is "GM" above the number "65"
No other marking are apparent.
My best guess is that it has been replaced by one from a HQ-X.
Can anyone positively confirm this?
Edited by wot179, 18 November 2010 - 04:24 PM.
#18 _ozbox_
Posted 19 November 2010 - 08:15 AM
up until about 5 years ago i knew that all hq to wb stubs were the same but not about the one tonner strength difference..
so in conclusion some dumb arse wrecker has sold him a normal hq to wb stub coz they like me did not know any anal differences...
Posted 19 November 2010 - 03:21 PM
Onto the shelf they go for future reference.Ill jam them into something.
Cant list them on ebay as LX HOLDEN TORANA A9X STUB AXLES RARE !!!!BROCK BATHURST!!! if the numbers aint right........
Posted 28 November 2010 - 06:11 PM
32965 ( passenger side) and 32964 (drivers side). Also had a pair of HX calipers to steal the long slides from. Stubs still had good discs attatched.
So have inserted all into the front end of the hatch with the original steering arms and standard height springs.
If it stops raining I will see how things have turned out and discover if harrop arms are needed for my tastes.
#21 _cruiza_
Posted 28 November 2010 - 08:53 PM
where I did find issues is tire wear very bad chewing out on the edge of the tire, never had a front tire last more then 10,000 km
#22
Posted 28 November 2010 - 10:14 PM
10,000 K might last me 20 years for the "good" car!
#23
Posted 29 November 2010 - 11:04 AM
With the commodore rears it brakes very nicely.
Given the parts were free and it took 2.5 hours to do it seems well worth it so far.
Will let it settle in for a while and then maybe look at adding 1 inch lowered springs.
#24 _cruiza_
Posted 29 November 2010 - 06:39 PM
Inner or outer edge?
both, 10,000 = 12 months of driving for me in the Hatch
2 to 3 months in the dribble car
