LH Front end with UC Rack
22 replies to this topic
#1 _v8slrtorana_
_v8slrtorana_
Posted 31 October 2006 - 07:59 PM
Ok, so i just found out that my tie rod is bent, not my fault, no wonder why i cant stop the tyre from rubbing !
Anyway, can i fit the UC rack without any ill effects like bumpsteer ect.
I know the LH has the rubber rack mount bushes, but that can be changed over, cant it?
#2 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 31 October 2006 - 08:04 PM
just bolt the uc rack up, everything will be fine (even better)
#3 _v8slrtorana_
_v8slrtorana_
Posted 31 October 2006 - 08:13 PM
Thanks for that.
You say even better, does the UC rack have a better steering ratio or somethink?
#4 _bodallafella_
_bodallafella_
Posted 31 October 2006 - 08:24 PM
The UC rack is solid mounted and the LH ones are rubber mounted. If you are pulling the rack of a UC make sure you get the bolts as the LH bolts wont fit through UC rack without mods.
Nick
#5 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 01 November 2006 - 10:53 AM
whoops, I forgot about the bolts!
it is better because it gives a more direct feel as it is solid mounted, not 100% sure about then ratios as there are about 3 different torana ratio's that I know of
#6 _@milco@_
_@milco@_
Posted 02 November 2006 - 08:41 PM
mmmmm i got a uc front end out of a car to put in my LH and the rack is not solid mounted..... must of been changed at some point........
#7 LS1LX
LS1LX
  • 1,931 posts
Posted 01 December 2006 - 07:45 PM
How different is the UC rack mounts vs A9X?
Does anyone have a pic of the UC bushes?
#8 _rorym_
Posted 01 December 2006 - 08:03 PM
Will post when the sun is up tomorrow.. remind me..both LH and UC front ends are sitting in my trailer.
#9 _rorym_
Posted 01 December 2006 - 08:05 PM
Hang on! UC is at the front if that helps..
Edited by rorym, 01 December 2006 - 08:06 PM.
#10 LS1LX
LS1LX
  • 1,931 posts
Posted 01 December 2006 - 09:32 PM
Cant tell what the bushes look like with the big washer in front of them :)
#11 _rorym_
Posted 02 December 2006 - 11:22 AM
Best I can do...dont want to take it off yet.
#12 _rorym_
Posted 02 December 2006 - 02:40 PM
LH on top UC on bottom..Totally different mountings..so will need the bolts ..
Edited by rorym, 02 December 2006 - 02:43 PM.
#13 _rorym_
Posted 02 December 2006 - 02:52 PM
No you wont...the bolts are captive in the subframe.
#14 LS1LX
LS1LX
  • 1,931 posts
Posted 02 December 2006 - 04:42 PM
So how do I tell if this rack I have is off an A9X or UC?
The rack used the LX captive bolts not the UC ones and they fit straight in.
The bushes arent worn to have elongated enough.
#15 _rorym_
Posted 02 December 2006 - 06:26 PM
Both my LH and UC front end have captive bolts in the subframe..cant see how it would be any different..there is no way to get in to do up the bolts on the inside I I guess they all have captive bolts...only going on what I see with both front ends.
#16 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 03 December 2006 - 08:46 AM
Rory, the bolts are coach heads, you undo the nuts and poke the bolts inside the subframe and you can reach in where the lower control arm goes and take them out completely.
M@
#17 _rorym_
Posted 26 December 2006 - 12:51 PM
Does too Mat!..Worked it out when I got the lower arms off...stupid system!.
#18 _LXcellent_
_LXcellent_
Posted 08 July 2009 - 11:58 PM
Ok, great thread so far, I have a UC cross member that I got without steering rack. With thanks to a forum member I got a UC steering rack - I have skimmed HQ discs on UC stubs and HQ Calipers already attached. I now need to bolt the rack to the crossmember. What do I need? Can I get a mounting kit? and if yes what part numbers do I need or which suppliers?
Thanks for any help, getting closer now, front end - check, motor (308 Quadrajet) - check, full rebuild 308 trimatic - check.
The pieces are coming together - next stop is the Diff! Still want to stick with Banjo (DON'T try and talk me out of it!) and Chief Financial Officer has said enough! That said I have a 2.78 Coarse centre and 3.55 fine centre that I will get the guts swapped to make a 2.78 fine. then Axles to suit with HQ pattern, get the drums filled and drilled and I am ready to commission the local panelbeater to knock out a couple of rough spots.
Anyone in WA with a rotisserie for sale to suit an LX would be welcome to drop me a line. Anyone in SW of WA with a torana is also welcome, would love to see what others are doing.
#19 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
Posted 09 July 2009 - 06:52 AM
The UC rack is solid mount, so you dont need a mounting kit as such. You just need two washers per side and the UC bolts. They have a narrower shank than the LH/LX ones so you will specifically need UC ones to fit a UC rack as the holes in the solid mount are smaller diameter than the LH/LX bolt.
#20 Torryhead
Torryhead
  • 90 posts
  • Name:Dan
  • Car:74 LH
Posted 15 February 2010 - 10:02 PM
guys, where do i get the replacement bushes for the centre of the UC rack, mine are elongated and i think should be replaced. only worn on the RHS. cheers
#21 _ass308_
_ass308_
Posted 16 February 2010 - 06:16 AM
its suposed to be like that.
mine was.
im guessing its to allow a little flex if there is any needed.i also had to run a half inch drill through the bushes on the rack so i could get the subframe bolts through,from memory.id check that before u just go drilling.
i think the uc may have metric and my lx was imperial.the drill only shaved a bit out,to clearance the bolt
#22 76lxhatch
  • 7,202 posts
Posted 16 February 2010 - 07:20 AM
Yes as above one end is a slotted hole, its fine - just bolt it in.
#23 Torryhead
Torryhead
  • 90 posts
  • Name:Dan
  • Car:74 LH
Posted 21 February 2010 - 06:18 AM
cheers guys. the rack is in and all good. its fitted to my LH. didnt need to drill out the bushes, the bolts went straight in. maybe the last bloke (the guy who changed the rack in the first place) used UC bolts?? thanks again.
