UC handbrake in LH
8 replies to this topic
#1 _rorym_
Posted 15 January 2007 - 08:04 PM
Anyone want to explain this one?..same as LJ?..seems a better deal to me than the floor crappo!
#2 TerrA LX
Posted 15 January 2007 - 08:13 PM
you need to cut out the floor pan section from a uc and lap weld it into the LH, if its a road car you need to factor in seat belt mounts and possibally check with engineers/rego first.
#3 _bodallafella_
_bodallafella_
Posted 15 January 2007 - 09:15 PM
Or you could just run a Lokar universal Floor or trans mount handbrake. Much easier.
http://www.lokar.com...ges/ebrakes.htm
#4 dattoman
  • 16,487 posts
Posted 15 January 2007 - 09:28 PM
Maybe read this
https://cache.gmh-to.../Handbrake1.jpg
https://cache.gmh-to.../Handbrake2.jpg
https://cache.gmh-to.../Handbrake3.jpg
https://cache.gmh-to.../Handbrake4.jpg
However for the track cars we have decided that we'll keep the floor mounted pedal and have a "fly off" hydraulically operated centre pull for when the need arises
#5 _rorym_
Posted 16 January 2007 - 08:58 PM
Seems a bit over the top to me. why not make a bracket to bolt under the floor to hold the handle and 2 slots to take the cables?..seems a lot easier than the floor cut thing.
#6 _bodallafella_
_bodallafella_
Posted 16 January 2007 - 09:12 PM
Agree, bolting to the floor and running a couple of cables seems much easier and better than replacing half the floorpan. The handbrake doesn't even need to be from a Torana.
#7 TerrA LX
Posted 16 January 2007 - 09:18 PM
4" angle grinder makes quick work but whatever suits you.
#8 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 16 January 2007 - 09:20 PM
Rory I'm in the process of doing the UC into LX handbrake thing. If you already have a UC handbrake assy, you'll see it's easy.
Because the tunnel is a different shape from the UC, I have made my own re-enforcing plate to put under the tunnel to prevent the metal flexing, and then it's simply a matter of drilling three holes, and creating those two slots, viola, done!!
Dave
#9 _rorym_
Posted 17 January 2007 - 11:52 AM
Thanks Dave...thats where I am heading.
