Drop tank / Bathurst tank
14 replies to this topic
#1 _lostinspace_
_lostinspace_
Posted 25 March 2007 - 01:53 PM
Has anyone put in a drop tank or know what modifications are needed to LH boot floor or body and how many types of drop tanks there is for LH Torana
were they off the shelf or do I have someone make to suit ?
Any input on this topic will be appriciated
Thanks in advance
#2 _ChevLX_77_
_ChevLX_77_
Posted 25 March 2007 - 02:10 PM
I had a bathurst style drop tank on the back of my car. The spare wheel carrier has been cut out. The tank has a rear pickup and its capicity was somewhere in the vacinity of 160 litres.
#3 _lostinspace_
_lostinspace_
Posted 25 March 2007 - 04:50 PM
Thanks for the pics ChevLX_77 I've noticed the difference that your drop tank has straps and is squared off and others are strapless and tapperd do the strapless tanks become the boot floor or are they bolted by the tanks flanges?
#4 _ChevLX_77_
_ChevLX_77_
Posted 25 March 2007 - 04:57 PM
The strapless ones, at least ones i have seen, have plates welded to them then they bolt the tank to the chassis rail. I think that ChevLX has a strapless tank on his car.
#5 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 25 March 2007 - 05:47 PM
Filling up with one of those sucker's would be an expensive experience.
Most droptanks that you see aren't square at the back, like as you see above.
Tim
#6 LXdamo
LXdamo
    Still Lurking
  • 521 posts
  • Name:Damo
  • Car:bits here bits there.....
Posted 25 March 2007 - 05:55 PM
Here is a pic of my strapless tank.
All i had to do to fit it was drill four holes in the chassis rails and mod the filler neck.
Edited by LXdamo, 25 March 2007 - 05:58 PM.
#7 TerrA LX
Posted 25 March 2007 - 06:06 PM
Tim
Race tanks are square, road tanks are angled off to A; stop them hitting things like exiting driveways and B; draw a line from the rear of the car down to the back of the rear tyre and most state laws state that anything protruding the rear of the car past that line is illegal due to point A.
#8 _The Baron_
_The Baron_
Posted 25 March 2007 - 08:56 PM
********** 2 basic types ************
Strapped using original tank strap mounts.
Strapless bolting through the chassis rails.
I have seen a range of capacities for both.
Check with your local road authorities before you spend, they are not cheap.
55 litre stocker was a joke.
You should NOT need to stuff with the boot floor where your spare tyre sits.
#9 _Yella SLuR_
_Yella SLuR_
Posted 25 March 2007 - 09:43 PM
A Bathurst tank, like that pictured on ChevLX77, is actually not legal for road use, due to non-compliance with rear entry angle. I did some drawings here somewhere of my droptank which is 160L, which includes a diagram on what the rear entry angle is. Dual exhausts are considered part of the body for working out the rear entry angle.
Actually, ChevLX77's tank isn't even a Bathurst type tank, as they had an angle on the front, i.e. toward the rear wheels.
Most droptanks have a cut-out for the spare wheel well, so it doesn't need to be removed.
Obviously over the years, peeps have had their own ideas on how to make em.
#10 _Yella SLuR_
_Yella SLuR_
Posted 25 March 2007 - 09:46 PM
Here ya go, have a look at this:- http://www.gmh-toran...topic=8698&st=0
More info is here:- http://canberratoran...o/droptank.html
Enjoy.
Mod's maybe a sticky link is required in this section to the sticky in LH-LX-UC section.
#11 ls2lxhatch
  • 5,332 posts
Posted 25 March 2007 - 10:15 PM
One thing to note about the Brown Davis tank is that you have to cut off the original rear strap mounts which are spot welded to the floor.
#12 _Yella SLuR_
_Yella SLuR_
Posted 25 March 2007 - 10:17 PM
^ Why? I take it you are talking about the ones behind the rear beaver panel. Tank should sit in front of these, shouldn't need to remove them.
#13 TerrA LX
Posted 25 March 2007 - 11:04 PM
http://canberratoran...k-RearAngle.jpg
#14 ls2lxhatch
  • 5,332 posts
Posted 26 March 2007 - 02:13 AM
The Brown Davis tank does not sit in front of the strap mounts, it goes all the way to the beaver panel. The tank is the same shape as the chassis rails which narrow towards the diff, so there is no option to move it forward.
#15 _lostinspace_
_lostinspace_
Posted 27 March 2007 - 06:15 PM
That info is Great thanks guys. I've started a total rebuild of my torana and working out what mods it needs now that it's only a bare shell and this sort of info helps me decide what I will need to do. some nice torrie out there Thank for the pics and drawings.
