Mark
Posted 20 April 2007 - 09:47 AM
Posted 20 April 2007 - 10:08 AM
Posted 20 April 2007 - 10:20 AM
Edited by ls2lxhatch, 20 April 2007 - 10:23 AM.
Posted 20 April 2007 - 04:48 PM
Posted 20 April 2007 - 07:53 PM
Posted 20 April 2007 - 08:50 PM
Posted 20 April 2007 - 09:04 PM
Posted 21 April 2007 - 08:13 AM
Posted 22 April 2007 - 04:57 PM
Posted 24 April 2007 - 09:10 PM
Posted 25 April 2007 - 10:49 PM
Posted 26 April 2007 - 01:00 AM
Posted 26 April 2007 - 01:45 PM
Posted 26 April 2007 - 08:41 PM
The depth of the LS1 1005M dry sump pan is 3.750" (95mm) at the deepest point of the scavenge "bumps".The front is under 2.0" (50mm) I will send you a link to the web site picture of this pan. Shipping via parcel post air is approx. $120
Posted 26 April 2007 - 10:48 PM
Posted 28 April 2007 - 10:48 PM
Posted 02 May 2007 - 05:57 PM
Ok, I have measured the clearance with CRS engine mounts. This sump will go close to fitting without any mods. Maybe where it kicks out on one side could be a problem.One thing to note is that none of the aftermarket sumps are designed to have the gearbox bolted to them. I am lead to believe that the standard sumps are refereed to as structural sumps because the gearbox is strengthened by bolting to the sump.
This picture of the VZ LS2 with the standard sump shows the gearbox mount.
If you are not running a LS1/LS2 gearbox then this is not a problem. I have a 4L65e so it is preferable to have a structural sump.
Posted 02 May 2007 - 09:34 PM
