Torque settings for 202
8 replies to this topic
#1 _LC2250_
_LC2250_
Posted 23 April 2007 - 01:39 PM
I recall a while ago someone posting up a pdf or a jpg or all of the torque settings from the LC/LJ service manual.
Just so I can go ahead and do some work on wednesday does anyone have this around?
If so could you be so kind as to post it or email it?
Would be greatly appreciated.
-Al
#2 _uglybob_
_uglybob_
Posted 23 April 2007 - 06:28 PM
dosnt your elbow click?
#3 _LC2250_
_LC2250_
Posted 23 April 2007 - 07:40 PM
unfortunately so do my soft annealled bolts ... which is why I'm curious about the torque settings
#4 _uglybob_
_uglybob_
Posted 23 April 2007 - 08:22 PM
what kind of bolts are they??
standard torques are normaly just 20 to 25 ft lbs for a 5/16 bolt and 35 to 40 ft lbs for a 3/8 bolt. and 7/16 incase your doing the suspension gear as well is 50 to 55 ft lbs.
ill dig out my torana manual and see if the torque specs are differnent in that.
#5 _uglybob_
_uglybob_
Posted 23 April 2007 - 08:28 PM
is there any speciafic compartment that you are looking for?
#6 _LC2250_
_LC2250_
Posted 23 April 2007 - 09:08 PM
It's the engine mostly ... I'm doing the cam shaft and it would just be handy to have them on hand.
The bolts I've got are if the relative condition of the ones holding the rockers are any indication will be on their last legs (probably a good idea to replace).
So tensions for the timing gear case and anything to do with the head and rockers.
-Al
#7 _uglybob_
_uglybob_
Posted 25 April 2007 - 04:41 PM
sorri the picture is not the best. hope u can still read it. it is all the torque specs for the engine compartment.
ben
Posted Image :rockon:
#8 _LC2250_
_LC2250_
Posted 27 April 2007 - 02:21 AM
It still did the trick, as much as its pixelated you can still make out the numbers so I'll just re-type it for future reference and thanks once again for that bob
-Al
ps. it was a success!
#9 _uglybob_
_uglybob_
Posted 28 April 2007 - 12:20 PM
yeh sorri about that i dont know why it came out so bad.
no worries glad to be of help.
ben
