Front Mount LH Sway bars, Pics?
24 replies to this topic
#1 _rorym_
Posted 08 May 2007 - 04:11 PM
I am trying to decide on which front mount bar type I use on the race car..Anyone got pics of the KMAC,Lovells,Selbys?..Cant get pics out of them.
#2 ls2lxhatch
  • 5,332 posts
Posted 08 May 2007 - 04:34 PM
I received this email from Whiteline a couple of weeks ago.
Thanks for your interest in Whiteline products.
The part numbers to suit your Torana are as follows:
Front - BHF37� � � RRP $235.00
Rear� - BHR37� � � RRP $235.00
� � � � �� KU4� � � �� RRP $65.00
� � � � �� Please note, a KU4 U-Bolt kit will be required to accommodate the axle tubes on a 9inch diff
Please find the photos of these bars attached. We no longer powder coat our swaybars in this blue, it is in a silver metallic, but for illustration/orientation purposes there is no change in the bars. I can't confirm if these bars will accommodate a non-standard front spoiler or brake ducting as we've designed the products around a standard vehicle.
In regards to final pricing and purchasing information you can contact one of our distributors in your local area such as Autobarn, Burson, Coventry or Repco stores.
If you have any further questions please let me know.
Kind Regards,
Wayne Vickery
(Ph: 61 2 96030111
2 Fax: 61 2 98202500
* Email: [email protected]
Front
https://cache.gmh-to...tch/hf35_01.jpg
https://cache.gmh-to...tch/hf35_02.jpg
https://cache.gmh-to...tch/hf35_03.jpg
https://cache.gmh-to...tch/hf35_04.jpg
Rear
https://cache.gmh-to...tch/hr37_02.jpg
https://cache.gmh-to...tch/hr37_03.jpg
https://cache.gmh-to...tch/hr37_04.jpg
I recevied this reply from KMAC a couple of weeks ago. Could not get any pictures and I am not sure that it is the same as used by Peter Brock.
Yes, we make them!!
Same as we supplied to Peter Brock and the first 6 over the finish line at Bathurst in 1977
Bars are ultimate slide adjustable.
Front Kit is $465 incl GST
Rear $425
Freight $38
The front bar is designed to fit with the Bathurst A9X
set up which included the brake ducts.
The side splash skirts were deleted with the 2 bolts that
hold them on becoming the 2 mount points for the sway
bar frame brackets
Regards
Kevin
K-MAC SUSPENSION P/L
366 Princess Highway
ROCKDALE NSW 2216
P: +61 2 9556-1799
F: +61 2 9556-1507
E: [email protected]
W: www.k-mac.com.au
Edited by ls2lxhatch, 08 May 2007 - 04:39 PM.
#3 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 08 May 2007 - 05:11 PM
Yes, the Whiteline look the same as the old Selby's front mount bars, they mount "directly" to the front rails (no surprise given Whiteline is the old Selby's).
#4 ls2lxhatch
  • 5,332 posts
Posted 08 May 2007 - 05:19 PM
In this picture you can see the bar has a selbys sticker.
#5 _rorym_
Posted 08 May 2007 - 05:28 PM
You guys are so QUICK! I am guessing the Whiteline one fits OK with the std front spoiler and brake ducts?. Hard to justify the extra cost of the KMAC..adjustable or not..Strange the rear Whiteline uses the axle as the twisting part and the stock rear bar fits to the trailing arms?..Guess they know what they are doing.
P.S. He gave you the wrong number..the forward mount Whiteline is a BHF 35...not a 37.....37 is std replacement rear mount one.
Edited by rorym, 08 May 2007 - 05:32 PM.
#6 _The Baron_
_The Baron_
Posted 08 May 2007 - 05:35 PM
Rear pick up point are very similar to A9X.
Edited by The Baron, 08 May 2007 - 05:36 PM.
#7 ls2lxhatch
  • 5,332 posts
Posted 08 May 2007 - 05:44 PM
Rory
Thanks for pointing out that they gave me the wrong part number. I am glad that I have not ordered it yet.
Litre8
Is your front bar available from Whiteline? It looks like a good setup.
http://www.litre8.co...ont_discs_1.jpg
#8 _rorym_
Well it must be right then..they sort of worked OK?.. :tease:
Thanks Baron. :spoton:
#9 arrimar
arrimar
  • 3,134 posts
Posted 08 May 2007 - 05:53 PM
this is a mix of old and new kmac components.
must say that the old components are more rigid than the new in their construction
as you can see the "delete side splash guard" comment is a weird one.
Edited by arrimar, 08 May 2007 - 05:59 PM.
#10 _rorym_
Posted 08 May 2007 - 05:58 PM
I could be tempted with the KMAC front though.
#11 arrimar
arrimar
  • 3,134 posts
Posted 08 May 2007 - 06:03 PM
the rose jointed link pins are special order if you require them. the standard ones they send out nowdays are quite different.
the lower control arm bracket is a piece of crap in my opinion. soft as putty and needs some mods i reckon.
#12 _MRNOS_
_MRNOS_
Posted 08 May 2007 - 06:16 PM
Im going KMAC on mine Rory, Darrens hatch has the whiteline
#13 _rorym_
Posted 08 May 2007 - 07:30 PM
Hmmm...Twice the price and the only thing that was swinging me was the huge lower brackets bolted to the arms...but Howard says the later ones are a bit softer?...The Whiteline ones..brackets ,,look quite flimsy compared. Still dont know.
I could get the Whiteline and get stronger lower brackets made. If the rose jointed are are extra the KMAC is looking way over priced. Might be easier to get the Whiteline and improve it. Howard, is the lower arm bracket in that pic ^^ the old or the new?
Edited by rorym, 08 May 2007 - 07:32 PM.
#14 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 08 May 2007 - 07:52 PM
This is the Kmac bracket I have.
#15 _rorym_
Posted 08 May 2007 - 07:58 PM
Howard...got a pic of the front bracket holding the bar?...u have nearly convinced me.
#16 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 08 May 2007 - 08:01 PM
here it is, note the droplinks in the previous pic are ones I had made up, Kmac ones use neoprene bushings.
#17 _rorym_
Posted 08 May 2007 - 08:08 PM
So you dumped KMACs ones and made up some rose jointed ones>?...Funny thing happened today...I accidently found Frank Matichs old fitter and turner I used to work with....Peter Hughes...you might remember him being mentioned in AMC in the John Goose special about how he won Bathurst and bought the Matich F5000....he did all the work on Franks SR3/4 and all the Matich F5000 cars..he teaches TAFE in Tamworth..now I have a fabricator again ! :spoton: :spoton: He is itching for me to get him to make something! Lol!
#18 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 08 May 2007 - 08:11 PM
Skilled tradesmen are as rare as, once you find one you never trust anyone else.
#19 _rorym_
Posted 08 May 2007 - 08:12 PM
Bugger that it cuts into the brake duct. :cry:
#20 _rorym_
Posted 08 May 2007 - 08:15 PM
Just looked back at the Whiteline one...brackets look REAL flimsy now.
#21 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 08 May 2007 - 08:16 PM
I believe the more recent Kmac brackets clear the brake ducts (my setup is 1990)
#22 _rorym_
Posted 08 May 2007 - 08:17 PM
SOLD! To the skinny guy in the corner with the raincoat on!! :huh: :huh: :huh: Probably just use the Whiteline rear then.
Edited by rorym, 08 May 2007 - 08:18 PM.
#23 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 08 May 2007 - 08:19 PM
KMac rear bar is nice piece too.
#24 arrimar
arrimar
  • 3,134 posts
Posted 08 May 2007 - 08:39 PM
oh man too many howards in this thread i'm all confused.
the shiny bracket in my pic is the modern lower arm mount.
the black one in the other howards(litre 8) pic is the old sturdy style.
the bar i have came from a box of bits that included some really low springs and shocks.i'm not sure if the brackets are shorter to suit but it seems to fit higher from the road than others i have seen.youll notice packers between the u shaped mount and the support bracket,thats to clear the high volume oil pump.
#25 _rorym_
Posted 07 September 2007 - 02:56 PM
OK..All will be reveiled! I just ordered my K MAC adjustable front bar.
Pics to follow.
Edited by rorym, 07 September 2007 - 02:58 PM.
