Senders for LJ GTR dash
9 replies to this topic
#1 _monarodad_
_monarodad_
Posted 20 June 2007 - 07:31 PM
Just wanted to find out if it is possible to buy oil pressure , temp senders & if the standard fuel sender would be ok to use with a GTR dash ? :rolleyes:
Andrew
Mt Gambier
#2 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 20 June 2007 - 09:58 PM
Yup, Yup and Yup.
I got mine from Repco, and used the original fuel gauge sender.
Tim
#3 gtrboyy
gtrboyy
  • 3,208 posts
Posted 20 June 2007 - 11:42 PM
VDO outlets can sell you the correct senders,I ended up taking my dash out & taking it to them so I got the correct senders just to be sure.
#4 _monarodad_
_monarodad_
Posted 21 June 2007 - 09:17 PM
:spoton: :spoton: Thanks for your help. :spoton: :spoton:
Andrew
Mt Gambier
#5 orangeLJ
Posted 21 June 2007 - 09:41 PM
if you go into the little mune up the top tha says "my controls" there is an option to edit your "signature" you can put your location in there. saves typing it all the time :spoton:
and as for the GTR dash with std sender, mine doesnt work, tried 3 senders, and at full tank the gauge only reads half, it is a VDO gauge so not original, but im thinking the gauge must need a lower resitance. or something, i have it all figured in my head. haha. cheers mate.
Chris :spoton:
#6 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
Posted 21 June 2007 - 09:45 PM
I'm pretty sure original gauges are VDO, Chris...
Tim
#7 _73LJWhiteSL_
_73LJWhiteSL_
Posted 21 June 2007 - 10:36 PM
As far as I am aware all GTR cluster instruments are VDO.
You can also get the senders from Burson. Make sure when asking for them you say that is for a gauge not a warning light, as the senders are different. :spoton:
Steve
#8 _monarodad_
_monarodad_
Posted 21 June 2007 - 11:00 PM
:rockon: Thanks Chris & others just learning how to use the site , I'm not much of a computer operater . The responses are a great help & hopefully I am going to find the LJ coupe that I have been looking for quite a while. :rockon:
#9 orangeLJ
Posted 22 June 2007 - 12:44 PM
not all of them have VDO written down the bottom though, my old mans dash (which we know for sure is ridgy didge) doesnt have anything. maybe they are all VDO, but mine are not original VDO, if you get my drift.
#10 _troy_
_troy_
Posted 25 June 2007 - 02:54 AM
The fuel guage on the GTR dashes never worked from the factory...Some others work intermittently
