LH SLR5000 Weight
_the gts_
Posted 19 December 2007 - 11:21 PM
Does anyone know what the normal weight is for an LH SLR 5000? I have the original manual and it only gives weight for the 6cyl models of 1183kgs.
Also does anyone know if bigger wheels than the 6" wide were offered as an option?
PHIL
Posted 20 December 2007 - 01:37 AM
http://users.bigpond....au/wray/lx.htm
Sedan
Kerb weight: 1143 - 1183 kg (2520 - 2609 lb)
Hatch
Kerb weight: 1170 - 1209 kg (2580 - 2666 lb)
Details from Holden hatch brochure.
https://cache.gmh-to...ch/brochure.jpg
SL 1183 kg (2610 lb)
SS 1213 kg (2674 lb)
_JBM_
Posted 20 December 2007 - 06:30 AM
James
Posted 20 December 2007 - 07:19 AM
The official GM-H 'Kerb Weight' of an LH SL/R5000 is 2724 lb/1236 kg.
Dr Terry
Posted 20 December 2007 - 09:26 AM
Do you have any documents to show to the licencing department?Hi Guys.
Dr Terry
_Yella SLuR_
Posted 20 December 2007 - 12:03 PM
Yella weighs 1300kg on the knocker. Maybe needs to go on diet.
Posted 20 December 2007 - 12:21 PM
I'll dig up the paperwork & see if that will help.
One reason why the official figures are always lower than the real world numbers is that official weights are based on absolutely stock cars i.e. no accessory or options, except what came as standard. For example, no radio (they weren't standard for LH SL/R), no bumper over-riders, no mudflaps or anything. Nothing in the glovebox or boot etc.
Quite often, the factory figures are 'guessed'. What I mean by that is, they might know the exact weight of an L20 SL/R & they know that a V8 weights says 70 kg more. All they do to get the weight of an L32 SL/R, is get the known L20 weight & add 70 kg. They haven't actually put a real V8 car on a weighbridge, but the 'guestimate' would be very close
Dr Terry.
_the gts_
Posted 20 December 2007 - 12:22 PM
1183kgs is the weight of an SLR 6 cylinder model, that info comes from the original LH user manual. Obviously the V8 models are going to be heavier.
Dr. Terry your numbers would seem close to being correct so if you know where i can get evidence please let me know.
_the gts_
Posted 20 December 2007 - 12:28 PM
what about the hotwires? were they offered as an option from any of the dealers?
PHIL
Posted 20 December 2007 - 03:23 PM
The 14 x 6 wheels in LH were L34 only with HQ axles & front stub axles.
The std wheel was 13 x 4.5. SL/R (Incl 5000) got 13 x 5.5 plus there was a 13 x 6 'heavy duty' option. This was the largest optional factory wheel for an LH. The Hotwires etc were all aftermarket, not GM-H. There was a Jelly Bean style alloy available in LX, but it too was only 13 x 6.
Some engineers & RTA types will know that you car hasn't got L34 axles etc & won't let you get away with the 14x 6 being the max wheel size.
Dr Terry
_the gts_
Posted 20 December 2007 - 04:10 PM
the stub axles on the front were no different for an L34 than standard torana according to the parts maual. although i have CRS drop stubs anyway
as for the rear mine is commodore everything but they will not allow me to use a 235/45/17 (VR GTS) as an optional tyre. This means that axle design does not come into their decision. that only makes sense if they are using car weight as the deciding factor which would obviously be based mainly for wet weather driving and aquaplaning with wider tyres.
thanks for the info Dr. Terry, I would still like to see any info on the LH SLR 5000 weight
PHIL
_the gts_
Posted 20 December 2007 - 04:12 PM
Edited by the gts, 20 December 2007 - 04:13 PM.
_Yella SLuR_
Posted 20 December 2007 - 04:32 PM
The good news is there is a test for wider wheels now that Engineer's can undertake for wider wheels. It's the new National Light Car Modification Regulations.
Posted 20 December 2007 - 05:47 PM
_moot_
Posted 21 December 2007 - 06:49 AM
so to find max engine capacity its 1205x4.86=5.856 litres.
if anyone has something offical for a v8 sedan of factory description (cant be a weigh bridge ticket,has to be holden info etc) please let me know as i'd love a big block
Posted 21 December 2007 - 09:46 AM
NCOP
http://www.infrastru...n/vsb_ncop.aspx
Quote from Section LA Engines 3 Feb 2006
Maximum engine capacity is based on the original tare of the model vehicle fitted with the largest engine available without optional accessories.
Less than 800kg
Naturally aspirated = kg * 3
Turbo/Supercharged = kg * 2.5
Between 800kg and 1100kg
Naturally aspirated = kg * 4
Turbo/Supercharged = kg * 2.75
More than 1100kg
Naturally aspirated = kg * 5
Turbo/Supercharged = kg * 3
They approved the 6lt LS2 for my hatch using 1204 * 5 = 6020 cc.
Edited by ls2lxhatch, 21 December 2007 - 09:47 AM.
_moot_
Posted 21 December 2007 - 11:26 AM
