Heater hoses
Posted 25 December 2007 - 10:03 AM
Repco couldnt help me.
Posted 25 December 2007 - 11:54 AM
just checked L34 supplement and there is no different listing. So just get standard Torana V8 ones.
Edited by GML-31, 25 December 2007 - 12:02 PM.
#3 _The Baron_
Posted 25 December 2007 - 11:54 PM
All that I have found available is the general purpose one from mackay that has just one bend about 3 inches from the end that you can cut to your required length.
If you see a picture of REDA9X's engine bay you will see that the Original hoses leave the firewall towards the radiator for about 3 inches then they do a 90 deg turn up towards the bonnet, then after 3-4 inches they do a 90 deg turn towards the passenger side bonnet hing. Run to the passenger side rocker cover and then turn towards the front of the car again and follow the rocker cover to the thermostat and pump connections.
It shows it correctly in the GMH parts book.
Part #'s
Heater inlet to manifold(thermo)--9928623
Heater outlet to water pump --9943976
Above is pre emission ie L34.
Emission is more complex as a valve is used in the heater outlet plumbing to heat up the engine quicker by not running water throught the heater until the engine has warmed up.
I can post up those numbers to but unless you have the valve the numbers are useless and may lead to confusion. They are sure to be NLA any way.
Good luck.
Posted 26 December 2007 - 08:18 AM
The ones from Mackay do you have a pic to show what they turned out like?
Edited by GML-31, 26 December 2007 - 08:21 AM.
#5 _The Baron_
Posted 26 December 2007 - 02:41 PM
I ran straight out from the heater and crossed over behind the carby to the passenger side rocker cover. (Coil is now mounted out the drivers side near rocker cover--Not the best)
Then to the thermostat with one hose and the other to the pump.
The hose that runs to the pump is where I used the 90 deg bend at the pump.
The other is just a straight run, the bend I cut off.
Overall, I am not to happy with this layout but it is the best I can do for now.
Mind you, the original factory job is ugly too.
PS spring insertion I can understand but heating "rubber" to shape?? Let us know how you go.
Posted 26 December 2007 - 10:15 PM
I found one from a Commodore V8 that suits the LX V8. Just had to cut the end off. I was also told the early V8 Commodores are the same or very similar to the Torana's. Maybe go to a Holden dealer and see if they have some that you may be able to adapt.
This is the LX type that The Baron was talking about.
Baron, I spoke to a guy at the Masters this year. He said he buys his hoses from Holden under the Commodore part numbers.
#7 _The Baron_
Posted 27 December 2007 - 09:59 PM
I will look into it soon.
Posted 28 December 2007 - 01:49 PM
#9 _The Baron_
Posted 28 December 2007 - 06:17 PM
You finished your car yet?
#10 _l34nut_
Posted 29 December 2007 - 08:23 AM
#11 _Yella SLuR_
Posted 29 December 2007 - 09:06 AM
Posted 29 December 2007 - 09:30 AM
A9X
L34
This hose is from a commodore. On an original Torana (A9X style) the hose bend 90degress and then curved over the distributer then along the tappet cover and took an almost 90degree turn around the accelerator bracket to the thermostat housing. The Torana ones have been unavailable for years, and the Commodore ones just dropped off about a year ago. The second hose running beside it however that runs to the water pump is available at any auto store. All you can do is cut it to size and bend it round the accelerator bracket.
The L34 however only has one outlet on the water pump, that one goes direct to the heater core. The one coming from the thermostat housing runs into the manifold on the drivers side. On the passenger rear the water comes out and goes to the heater core. Hope thats of some help. I have no idea what hoses are available there.
#13 _The Baron_
Posted 29 December 2007 - 03:15 PM
I tried the layout RED used but due to the extra bends being missing, they looked and lay poorly.
Posted 30 December 2007 - 04:58 PM
It seems they dont even have a listing for V8 LH/X torana heater hoses, only an upper and low radiator hose in the replacement parts books at repco and auto one.
