1/4 mile times for SLR5000 and L34 etc
_TORANR AMORE_
Posted 06 February 2006 - 10:10 AM
I've read in a few publications that SLR5000's and L34's do flat 13's on the quarter, for examplt Fiv Antoniou talks about this. I think it was 12.8 for the L34 and 12.5 for the SLR5000 or something like that.
There are a few memebers here that own original and well restored and unmodified SLR5000's. Has anyone tested these on the 1/4? what were your times? Please be truithful.
The reason I ask is I'm currently in an arguement thats been doing on for some time from annother torana fan (and he knows his shit) and he says they do 15's, but the books say otherwise.
My mates SLR had a genuine SLR5000 but recently sold it:
http://www.gmh-toran...?showtopic=1800
Anyway, I used to beat him with ease every time with my SL 5ltr auto (TH400) and it wasnt even running healthy. It would beat his SLR from stand still across approximately 400m or from slow travelling speed (ie 30 or 40KPH) or any other speed.
Now here's the mindboggle: My car only did 14.3sec on the 1/4 then (at 30degrees celcius) and I'm convinced that it should do a flat 13 if the engine was built similar to the L34 output and use a decent auto (cos the TH400 is stuffed) and use better gears other than the 3:1 that it has now.
Please guys, without going into tangents with opinions and that, could you please give me some feedback on your experiences with your genuine unmodified SLR5000's on the 1/4 mile ????
Posted 06 February 2006 - 10:24 AM
Posted 06 February 2006 - 11:34 AM
Mine is not exactly stock so is not a good vehicle to judge by..
Posted 06 February 2006 - 12:41 PM
_TORANR AMORE_
Posted 06 February 2006 - 01:21 PM
_Yella SLuR_
Posted 06 February 2006 - 02:07 PM
_ChiaLX_
Posted 06 February 2006 - 02:38 PM
_keith1962_
Posted 06 February 2006 - 03:14 PM
I own a L31 LH SL/R5000 & i took it to the creek early January and it ran a 16.495 to 16.728 with 6 runs. The stats state that a sl/r5000 does a 16.1 1/4 mile and XU1 does a 16.00 flat.
regards keith
Posted 06 February 2006 - 03:38 PM
It states 16.1 here which sounds a little slow but may be correct. ChiaLX that sounds outstanding for a completely stock one!
_Mondie_
Posted 06 February 2006 - 04:06 PM
Posted 06 February 2006 - 04:20 PM
http://www.gmh-toran...topic=1140&st=0
To answer the question
In a test between the two cars I have written at the time, both the SLR5000 and L34 pulled flat 16.0 seconds.
Earlier in the year they got 15.8 quarter for an LH SLR 5000
0-100 8.0 sec for the SLR5000, 8.7 sec for the L34 (yes, slower)
0-160 24.1 SLR5000
0-160 25.2 L34.
just for the record
A9X 2.60 diff 16.1
A9X 3.08 diff 15.8
_TORANR AMORE_
Posted 06 February 2006 - 04:40 PM
All the answers are coming in the same
Looking at the sheet
It says there that SLR5000, 308, 9:1 compression 170KW, 3.08:1 gears, 1/4 Mile time = 16.01
Hmmmm,
My LX, SL has all of that and the same gears in the diff, but it's got a stock 308 that's running like a pig, an old clunker, probably 150Kw with a Holley on top. It has a stock TH400 that is stuffed that flares between 1st and 2nd. 15inch rims with 235mm wide road tyres on the back with a single exhaust, I reckon it would have run 15's when I first bought it, but since then, all I've done is lighten it up and use a 2inch spacer under the carbie. I weighed the car, it weighs 1200Kgs, which apparently is only up to 100Kgs lighter than an SLR5000, (so I'm told).
This car did 14.3 seconds at Heathcote on a 30 degree (celcius) day. It was only a test to see what it does before I make significant changes to it. I was dissapointed with it cos I had read that SLR5000's/L34's do flat 13's (which I'm gonna check again when I get home) and I was always under the impression that they do, reinforced by the numerous claims that people make on their 308 LX's over the net (especially when they're selling them).
Yet, it still doesn't make sense. What has thrown my car into early 14's in the state that its in?
_ChiaLX_
Posted 06 February 2006 - 04:42 PM
Posted 06 February 2006 - 04:52 PM
_ChiaLX_
Posted 06 February 2006 - 06:29 PM
_Yella SLuR_
Posted 06 February 2006 - 08:56 PM
As was also said previously, the L34 was built more for reliability than outright speed, well that was the intention anyways.
Edited by Yella SLuR, 06 February 2006 - 08:56 PM.
_Yella SLuR_
Posted 06 February 2006 - 09:39 PM
SL/T - 16.1s best 400m
- 16.5s average
A9X - 15.9s best 400m
- 16.5s average
^^ Article in rear on the Turbo Torana
P. 10
SL/R 5000 - 16.0s standing 400m
"It took 16.0s to cover the standing 400 metres, making it no faster (and a lot less nimble!) than the XU-1 it replaced.
Interesting aside: LX SL/R 5000's had a 9.7:1 compression ratio, beefed up from 9:1 to compensate for anti-pollution power drop.
P. 16
A9X ran the standing 400 metres in the low 15's (Contradicts above I know).
Page 17 onwards...
LH S - 3 speed auto - 2850 - 19.8s
LH SL/R 5000 5 spd manual (from above) - 16.0s
LH SL/R 5000 4 spd manual with L34 Option - 15.5s
LX SL hatch - 3 speed auto - 4.2L V8 - 17.5s
LX SS 5000 sedan with A9X option 4 spd - 15.9s
UC SL/T - 4 speed manual - 16.1s
From the debate so far and these figures, all depends on what mag you read as to what the standing 400m times were.
For what it's worth a quarter mile is actually 402.25 metres, not 400m.
Edited by Yella SLuR, 06 February 2006 - 09:39 PM.
_purpleLC_
Posted 06 February 2006 - 09:44 PM
I then hopped in it and ran a 14.8 which upset him greatly as he was also commentating at the track at the time!!!
It had no mods other than dual 2in system from the manifolds back.
Louie
_Yella SLuR_
Posted 06 February 2006 - 09:58 PM
Prolly also a bit of the Super Car Scare factor as well, as REDA9X said.
_TORANR AMORE_
Posted 07 February 2006 - 12:20 AM
Yella, you're right about what you said and I've already taken that into consideration. The Holley, Electronic Dizzy, electric fan, tri-wy extractors and a proper air cleaner. Each of these will make a small additional improvements to the performance and power output at the flywheel.
BUT
It's not a healthy motor and has a few problems (that I won't get into - long story) and the stock TH400 is crap and flares far too much btw gear changes, besides that TH400's use up btw 12 to 17% of the engines power just to operate. Both of these things need work & reconditioning and I'll be dealing with all that soon.
The Pro's and Con's probably weigh themselves out. The running gear is definately not putting out more than what a healthy SLR5000 would. And although I've been told by numerous SLR owners that they weigh btw 1250 and 1300Kg, the books say 1200Kg or 1180Kg. I'll accept a figure of say 1150 cos I think these guys weighed their cars with spare tyres and jacks and stereos and stuff in them or something. So apparently there isnt much difference in weight (or none at all)
First time ever testing it and the first time I've ever ran a 1/4 mile on a track, it runs 14.3 seconds and then consistent 14.4 again and again and again.
I will post some tables regarding the SLR5000, L34, A9X and XU1, standard and race trim tomorrow from the book I've got (History of the Holden V8) when I can get hold of a scanner.
Publications can be wrong, and the supercar scare can be one reason why, that's why I asked all you guys what you ran in your restored SLR5000's unmodified.
In any case, I'm starting to accept 14.3 as a good time, what do you guys think?
Edited by TORANR AMORE, 07 February 2006 - 12:21 AM.
#21
_Yella SLuR_
Posted 07 February 2006 - 12:43 AM
Mine weighs 1300kg, I had to take it to a registered weighbridge before they'd let me register it. Only had the stereo on board from your list, and only about 20L of fuel, didn't want it weighing too much.And although I've been told by numerous SLR owners that they weigh btw 1250 and 1300Kg, the books say 1200Kg or 1180Kg...........
...........Publications can be wrong, and the supercar scare can be one reason why, that's why I asked all you guys what you ran in your restored SLR5000's unmodified.
Yup, as much as I like the Spotlight Book, and all my other ones, they unfortunately do have glaring errors, even the manuals (scarey!!).
14.3 is a pretty good time for a street car. Something to work with to see which way your mods are going anyways.
#22
_TORANR AMORE_
Posted 07 February 2006 - 08:39 AM
Anyway, it seems that the books and some of the comments say 15's for these cars, I would like to think they do a lot better on the quarter. Maybe it came down to the driver and the 4-speed manual, having to gear change can slow you down, although you get a lot less transmission loss. Maybe they didn't race change? Who knows. Maybe some of the genuine owners can start to redefine this in March with some 14's or 13's, I hope so. I hope there's gonna be Falcons (XY's etc) there so we can dust em, blow em away.
Yella, yeh, thats what I thought, I reckon anyone who owns an SLR5000 or similar, they should expect 1300Kg. They may be in for a shock when they weigh it and it could weigh even more, I've weighed every car I've owned since my first Torana, always another surprise. The good news is that's its easy to change all that without butchering your car.
Edited by TORANR AMORE, 07 February 2006 - 08:40 AM.
#23
_Yella SLuR_
Posted 07 February 2006 - 02:46 PM
No need mate, it's a cruiser not a race car...... The good news is that's its easy to change all that without butchering your car.
#24
_TORANR AMORE_
Posted 08 February 2006 - 01:07 AM
Here are some scans from the book "History of the Holden V8", by Fiv Antoniou.
This is a comparison btw the HDT Team Brock SLR5000-L34 and the Stock SLR5000-L34, (Huge difference):
And this is a general comparison btw some stock Monaros with 1/4 mile times that may interest tiny:
The following you guys can download and view, they are ful page scans and are BIG:
Comparison of The HDT XU1 vs HDT L34 (Race cars in race trim), specifications (1Mb):
https://cache.gmh-to...XU1vsHDTL34.jpg
Comparison of Specs and performance differences btw the HDT L34 and GT 351 (1.2Mb):
https://cache.gmh-to...TL34vsGT351.jpg
Comparison of Specs and performance differences between the SLR5000 and the SLR 4.2 (750Kb):
https://cache.gmh-to...R5000andSLR.jpg
Specs on the LX SS A9x (430Kb):
https://cache.gmh-to...ecs/LXSSA9X.jpg
Edited by TORANR AMORE, 08 February 2006 - 01:12 AM.
#25
_TORANR AMORE_
Posted 10 February 2006 - 12:04 PM
