Distribtor cap
#1 _Barman_
Posted 13 January 2008 - 08:59 PM
Baz
Posted 13 January 2008 - 09:08 PM
#3 _JBM_
Posted 13 January 2008 - 09:11 PM
Yes the rotor is different it has a contact on both sides 180 apart.
James
Posted 13 January 2008 - 09:39 PM
When you could walk into selected Repco's (ones with machine shops in house) and ask to speak to someone "out the back".
These were the types of blokes that engineered and built those dissys.
Not the wet behind the ears babies that you have to deal with now at Repco.
The ones that YOU teach how the read the parts manuals.
But.....life goes on.........
Posted 13 January 2008 - 09:57 PM
Posted 01 March 2009 - 06:42 AM
Posted 01 March 2009 - 08:05 AM
Posted 01 March 2009 - 08:23 AM
It is very disappointing when you walk into an auto store these days to have three different people serve you and in the end you have to serve yourself.
It is disappointing... Imagine getting that same service in a brothel...
Posted 03 March 2009 - 04:55 AM
#10 _Pallbag_
Posted 03 March 2009 - 06:03 AM
Just did ...
Posted 03 March 2009 - 08:11 AM
Everyone was happy..and we kept them busy with our antics of wanting to go faster ..and the old fella's used to say we were nuts.."you no you wont get good ecommony with holes that big"...
Posted 04 March 2009 - 03:31 PM
Originally they used GB752, which are XU-1 points. Basically the same but with a higher spring tension & I believe a more durable rubbing block.They look like standard Holden Bosch points to me. GB534?
They were also used in some Porsche models but AFAIK they are no longer available.
I used to use them in performance 308 V8s also. They used to get points bounce before 5,000 rpm with standard points.
Electronic ignition was a great invention, wasn't it.
Dr Terry.
Posted 04 March 2009 - 03:33 PM
Originally they used GB752, which are XU-1 points. Basically the same as GB534 but with a higher spring tension & I believe a more durable rubbing block.
Dr Terry.
#14 _finer70_
Posted 04 March 2009 - 05:53 PM
My 1927 Chrysler 6 cylinder has a twin point distributer.
Brand DELCO. Twin point, 6 lobe cam, standard type rotor.
Trick with this distributer is to get both points opening together.
Another early type distributer used in the 1924 CHrysler has 3 lobes with the twin points opening on an alternating basis.
Posted 04 March 2009 - 06:46 PM
Actually, that would'nt be a bad thing at all....imaging teaching them the manual!!!!!
#16 _Squarepants_
Posted 13 March 2009 - 08:26 PM
No one can do it like I can!
Posted 13 March 2009 - 09:04 PM
