Difference between 186A and 186S
17 replies to this topic
#1 tonkstoy
tonkstoy
  • 49 posts
  • Car:LC GTR, LC 2 Door S
Posted 03 February 2008 - 07:47 PM
Hi all can someone tell me what the difference from a 186A and a 186S
186A 186 126(94)@4200 181(245)@1600 9.2
186S 186 145(108)@4600 184(249)@2200 9.2
yep I know its a silly question but it would be good to understand it more
#2 limo
limo
  • 2,673 posts
Posted 03 February 2008 - 07:54 PM
camshaft, 2barrel ww carby and headers, similar to GTR
#3 micklx
micklx
  • 1,785 posts
Posted 03 February 2008 - 07:58 PM
A 186A is the standard HR engine with single barrel carb.
186P is standard engine from HK,T,G can't remember if it was still 126 hp or if it went to 130
186S is the engine found in 6 cyl GTS Monaros and a few HR's.
The 'S' has twin exhaust headers, twin barrel stromberg carby with larger A/C, mild cam, slightly larger valves, this was the engine that all 186/202's should have been. Stronger all through the rev range but especially in the top end.
LC GTRs had a 161/173 version of the S
Some people tell you the 'S' had a steel crank, others tell you they all did.
#4 tonkstoy
tonkstoy
  • 49 posts
Posted 03 February 2008 - 08:28 PM
thanks guys , I have 2 STD bore 186 engines a 186A and a 186P and have also scored a 202 STD bore engine, and all totally complete with all the bits ,I have a LC 2 door S Torana , so now just decided which motor to rebuild and what to do with it to give it a few more horses
Edited by tonkstoy, 03 February 2008 - 08:29 PM.
#5 _threeblindmice_
_threeblindmice_
Posted 05 February 2008 - 08:50 AM
Have you driven a car with a 186 ? They do feel different.
#6 tonkstoy
tonkstoy
  • 49 posts
Posted 05 February 2008 - 09:30 AM
have driven a car many years ago with a 186, my Torana currently has a 202 bore 60 thou , currently with a 350 holley but i did have triple SU on it ( taken them off for a service ) all the rest is pretty standard ( i think as it came with the car ) so i am just looking to find the best combination , i do like the idea of 186 bored to a 192 , so looking for comments of people think
tonks
#7 Dr Terry
Dr Terry
  • 3,324 posts
Posted 05 February 2008 - 09:49 AM
Hi Guys.
Yes, a 186A is a standard HR 186 motor.
A 186P is the standard HK/T/G 186 motor.
A 186S is the optional 186 'S' engine for all HK/T/G (except Brougham & GTS 327/350) & is standard fitting for the Monaro GTS in those model series.
The HR 186 'S' motor is stamped 186K. AFAIK the only difference between a 186K (HR) & a 186S (HK/T/G) is the sump & pick-up.
There is no difference in air cleaner size between a 186 'S' & a standard 186.
AFAIK all 186 'S' have a forged steel crankshaft.
To answer tonkstoy's original question, I would use the 186 'S' head, carby & manifolds & build a 202 'S'. You will need the 186 pushrods as well.
Dr Terry.
#8 tonkstoy
tonkstoy
  • 49 posts
Posted 05 February 2008 - 10:23 AM
thanks Dr Terry
tonks
#9 _CHOPPER_
_CHOPPER_
Posted 05 February 2008 - 11:00 AM
Dr Terry.
While we are on the subject, I keep forgetting which pushrods are longer, 186 or 202. And does somebody know how long the buggers are? I have a box full of them, just need to get around to sorting them out one day.
#10 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 05 February 2008 - 11:04 AM
186 are longer...I don't have the specs on me...but I have a box full of them too
#11 _CHOPPER_
_CHOPPER_
Posted 05 February 2008 - 11:08 AM
I thought they were, just wasn't 100% sure.
#12 _threeblindmice_
_threeblindmice_
Posted 05 February 2008 - 11:17 AM
I'll probably get a bullet in the back for saying this but ,on the street,on many club runs I have not found a lot of difference between the two.Except I think the 186 feels better ,revs easier ,and uses less fuel .My new project an LJ will be running a 186 thats my thoughts .
#13 _oz772_
_oz772_
Posted 05 February 2008 - 01:04 PM
A question about this. I thought 186A's were cast the same way as this 179 below, and 186P's and 186S's were cast as per the other photo. Is that correct, or was the casting changed when the 186 was introduced?
#14 _threeblindmice_
_threeblindmice_
Posted 05 February 2008 - 01:21 PM
I thought he was deciding which motor to use.
#15 tonkstoy
tonkstoy
  • 49 posts
Posted 06 February 2008 - 10:07 PM
gents heres a pic of my toy
#16 _threeblindmice_
_threeblindmice_
Posted 07 February 2008 - 08:28 AM
Looks good you will have to do a photo shoot .
#17 _threeblindmice_
_threeblindmice_
Posted 07 February 2008 - 08:36 AM
oz772 I like your pictures ,thats one thing that is easy to miss .
#18 _ck1971_
_ck1971_
Posted 21 February 2008 - 12:16 AM
I could be wrong but wasn't the extra webbing introduced with the XU-1?
