Rat Trap V8
#1 _mars_
Posted 13 February 2008 - 03:15 PM
This rebuild is starting to give me the shits, what I now need to find is a Rat Trap suitable for my LX 308 with an Aussie 4 speed. There is one on e-bay that I am bidding on but with a few hours to go I feel that the price will skyrocket.
Have a lead on an after market one that is much stronger but I would really love to get the original, any helpers.
Thanks Mars
Posted 13 February 2008 - 03:40 PM
toryman76
#3 _SLRMike_
Posted 13 February 2008 - 03:58 PM
http://cgi.ebay.com....1QQcmdZViewItem
I think you will find its the HJ/HX type and I dont think they fit.
You will need this one, genuine Torana
The first and second pics are repro the last genuine.
Mike
#4 _SLRMike_
Posted 13 February 2008 - 04:04 PM
May cause some problems fitting to the pedal end?
Mike
Posted 13 February 2008 - 04:36 PM
I have a hydraulic set up for sale.
#6 _trna76hb_
Posted 13 February 2008 - 07:39 PM
#7 _UC HATCH_
Posted 13 February 2008 - 07:53 PM
#8 _SLRMike_
Posted 13 February 2008 - 08:37 PM
It's the only pic of an original I have to show the differences between that and a repro
Posted 13 February 2008 - 09:17 PM
Edited by toryman76, 13 February 2008 - 09:18 PM.
#10 _UC HATCH_
Posted 13 February 2008 - 09:57 PM
I asked because trying to work out what will work with the supra box as the one like the top doesn't.
Wonder if one like on ebay can be fitted with the lever part without the hook to suit the torana cable.
Thanks for the pics also they help a bit.
#11 _SLRMike_
Posted 13 February 2008 - 10:02 PM
I suppose its up to the buyer to check these things first but on the other hand its advertised as a V8 Torana cable clutch setup and its clearly not, so is there a comeback through ebay of not making the purchase based on the fact the item is not as described? Personally I would ring ebay customer support, live chat they call it and discuss. If it was sold in a shop as described and it was not fit for purpose that is was the wrong part you would be entitled to a refund. Of course you can try a fitment and I may be completely wrong so in the spirit of the day, I'm sorry.
Mike
Posted 14 February 2008 - 09:15 PM
what is the part number of that cable pictured? and where abouts does it go through the firewall?Further to previous post here is the cable to go with the genuine one, you will notice the difference from the ebay pic
Mike
also heres another one from ebay... looks to be a HJ/HX type again?
Link
Posted 14 February 2008 - 09:36 PM
Part No CC103 suit HJ-HX V8 sedan
I believe the 102/103 is the measurement in CM of the inner cable.
Available from:
86 Stubbs St.
KENSINGTON, VIC 3031
T: (03) 9381-9222
F: (03) 9376-5859
Email: [email protected]
You can also order them through Bursons and probably Repco at extra cost.
The Part No's work at Bursons.
Edited by rodomo, 14 February 2008 - 09:47 PM.
Posted 14 February 2008 - 09:59 PM
#15 _SLRMike_
Posted 14 February 2008 - 11:14 PM
In the first pic you will see how the 6 cyl clutch linkage bolts to the fire wall
You will note in veiw A the nut and bolt holding the bracket.
In the second pic you will see the V8 clutch linkage
You will note the same nut and washer and existing bolt on the firewall the same as the six.
From memory the firewall is double plated at this point with the exception of the hole you see in the second pic for the cable to run thru. This area is single skin firewall and if you look from the underdash you will see the 'cutout' section. It will be a matter of drilling or cutting this pre marked section/hole.
Hope that helps
Mike
Posted 15 February 2008 - 10:33 AM
thanks again,
toryman76
Posted 19 February 2008 - 09:16 PM
also got the engine on the cross member for a trial fit up of the running gear today and bloody hell its tight around the drivers side! and thats with it all out of the car. anyway the idea was to check to see if the clutch mechanism (from HJ i believe) i had would fit and i can tell you it doesn't. it fouls badly on the extractor. also the extractor seemed to be quite a tight fit with the sway bar on the drivers side too. what could be causing this?
heres a photo of the rat trap:
Posted 24 February 2008 - 05:16 PM
Edited by toryman76, 24 February 2008 - 05:17 PM.
Posted 25 February 2008 - 05:28 AM
Posted 06 March 2008 - 04:09 PM
#21 _trna76hb_
Posted 06 March 2008 - 07:03 PM
Ian
Edited by trna76hb, 06 March 2008 - 07:04 PM.
#22
Posted 06 March 2008 - 07:56 PM
#23 _trna76hb_
Posted 07 March 2008 - 06:37 PM
Hope that helps, if not i will get the wife to show me how to link this.
Ian
#24
Posted 07 March 2008 - 08:50 PM
thanks
