Booster And Master Cylinder Combo's
14 replies to this topic
#1 _Chaotic_
_Chaotic_
Posted 27 March 2008 - 09:16 PM
More of a point of interest i'm throwing out there of what's getting done to my car that others may be interested in.
Dropped her off to brake shop to get a bit of work done that i can't do myself at home. Including a booster overhaul. Dropped it off with the booster that was fitted to the car, originally a lx 6 cylinder. With the car came a double diaphram booster that i knew nothing about.
Got a call asking where the original proportioning valve was, as i'd completely stripped the car for work to be done. I'd bought a master cylinder with the 2 kits i got from hopper's assuming it'd be fine to run the 4 wheel disc brakes. (Guys fittnig everything up say otherwise and after hearing what they have to say i really do agree)
Car is now being fitted with the back half of the double diaphram booster, with a modified pedal linkage, front half of a falcoon booster mated to a late model commodore master cylinder, which has built in pro-portioning valve and brake warning light.
Bit of a rant but i find i learn more from what others have done. Let me know what you guys have done with your brake setups as well.
#2 _rocket_
_rocket_
Posted 28 March 2008 - 08:05 AM
All you really needed to do was use a commodore booster and cut 50mm off the rod that goes to the pedal and weld the Torana end back on, everything bolts straight up and shouldnt cost any more than $ 150. You will have to bend one of the lines to suit the new m/cylinder.Use a vk comm double/dia booster & wb mastercylinder, if you want the A9x look. ( square lid m/c.)
Edited by rocket, 28 March 2008 - 08:06 AM.
#3 ls2lxhatch
  • 5,332 posts
Posted 28 March 2008 - 10:52 AM
The standard Torana 1" bore master cylinder and proportioning valve will run the four wheel disc brakes, HQ or Hoppers. The only modification required is to remove the residual valve from the rear brake port on the master cylinder.
The standard VK Commodore master cylinder P10220 has a 23.81 mm ( 15/16" ) bore which is smaller that the Torana and Ford master cylinders. An engineer could knock this back due to the size of the bore. The Police VK Commodore master cylinder P10037 has a 25.4 mm (1") bore. I think it is also difficult to get stainless steel brake line fittings to suit the Commodore master cylinder.
Another option is to fit the front cover from a Commodore booster to the Torana booster and then use a Ford XD 1" master cylinder with integral proportioning valve. I suspect this is what you now have.
Edited by ls2lxhatch, 28 March 2008 - 10:52 AM.
#4 _Chaotic_
_Chaotic_
Posted 28 March 2008 - 11:46 AM
My brake guy felt that running the standard torana master with valve removed, as well as the standard proportioning valve required for rego would leave with poor pressure to the rear, but give the illusion of a great pedal still.
I believe the master cylinder being used will be from something like a vr commo, which was standard 4 wheel discs, and has proptioning valve built in as well as brake warning light required for rego purposes.
#5 ls2lxhatch
  • 5,332 posts
Posted 28 March 2008 - 02:26 PM
I think you need to find another brake guy. Make sure he fits a 1" master regardless of the donor vehicle.
Edited by ls2lxhatch, 28 March 2008 - 02:33 PM.
#6 _CHOPPER_
_CHOPPER_
Posted 28 March 2008 - 04:12 PM
What I plan on doing sometime next year is to use a 1.125" bore M/C with an aftermarket booster that has a much smaller outside diameter for extra clearance around the engine. This booster apparently offers more braking assistance and doesn't use engine vacuum to operate.
#7 _Brewster_
_Brewster_
Posted 29 March 2008 - 09:54 PM
I thought already having a double diapragm booster in my car, all I needed was a WB master cylinder ( I think statesman, not 1 ton ) and WB booster. Take the front cover off the WB booster and use it to replace the cover on the Torana booster. That way, you don't have to cut or modify the pin.
#8 _SS Hatchback_
_SS Hatchback_
Posted 29 March 2008 - 11:19 PM
1 in commodore master and the front cover of a commodore booster onto the torana unit on mine and works great with hoppers up front and commodore VL rears
#9 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 30 March 2008 - 09:43 PM
I have just had my booster and master cylinder overhauled but have been given a new Master cylinder not the original one.
I took her out for a blat today and found that the rear brakes dragged only after a heavy brake application and would not release completely .Is this due to the residual valve in Master cylinder?
Where exactly in the rear of master cylinder is it located and how do you remove it? :blink:
#10 ls2lxhatch
  • 5,332 posts
Posted 30 March 2008 - 11:38 PM
It is the check valve and spring in this diagram of a front and rear drum brake master. If you remove the brake line and poke a paper clip in the hole you should be able to feel the rubber check valve behind the olive.
See this thread for removal tips.
http://www.gmh-toran...p?showtopic=323
#11 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 31 March 2008 - 12:37 AM
Thanks for the heads up
I am tempted to take car into the brake centre where i took booster and master cylinder for overhaul but the forecast is for rain so it wont be tomorrow.
#12 _SIR383_
_SIR383_
Posted 31 March 2008 - 11:37 AM
What model commodore did you grab the booster cover and master from, any part numbers?
#13 _scottya!_
_scottya!_
Posted 06 April 2008 - 06:00 PM
I did get told that the VN v8 commodore booster and master was a good substitute.
I also was informed that that the m/c came in 15/16" an 1" bore. The only mod was to overhaul booster and change the fork to torana. I also am running hoopers fronts and VN rears.
#14 _SS Hatchback_
_SS Hatchback_
Posted 09 April 2008 - 10:21 PM
I believe it was from a vk but i will find out for you, the booster was a spare at a mates workshop when i looked and thought it may fit so not 100% sure . I will find out and post it here for you.
#15 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 10 April 2008 - 10:23 AM
Dual Diaphragm Commodore brake boosters, VB to VR, will suit.
