I've had the 9 inch in my UC torana for years and never got around to fitting a rear sway bar. The original UC sway bar was bolted onto diff i believe and it goes to the sway bar pins (?).
My question is that if i want to ran a sway bar on a 9 inch in a UC, how would i go about it?
9 inch diff in a UC torana
_studricho_
, May 05 2008 09:58 PM
4 replies to this topic
_studricho_
Posted 05 May 2008 - 09:58 PM
Posted 05 May 2008 - 11:00 PM
K-MAC and Whiteline have a swaybar similar to the standard UC swaybar with optional U bolts to suit the 9". You should be able to buy the U bolts separately and use your existing swaybar. K-MAC also have a rear mount swaybar that will fit the 9" but it costs around $400 and will probably not fit with your exhaust.
This is a picture of the K-MAC front mount rear swaybar temporarily fitted to a 9" in an LX.
Edited by ls2lxhatch, 05 May 2008 - 11:04 PM.
_studricho_
Posted 06 May 2008 - 06:09 AM
Thanks for the reply. that rear end looks like it means business.
Posted 25 May 2008 - 01:23 AM
I have a U bolt kit for a whiteline rear sway bar to 9 inch on an LX Hatch (presume will fit UC too?)
Turns out I didn't need it as the U bolts supplied with the kit were ok.
PM me if you need those U bolts and we'll work something out.
_Chamois hatch_
Posted 25 May 2008 - 09:42 AM
whiteline does a setup for under $200, got one in my uc with 9 inch, cant complain.
