CUTTING REAR GUARDS
5 replies to this topic
#1 _wardy_
_wardy_
Posted 18 May 2008 - 09:29 PM
Posted Image[/IMG]
Cut the outer away
Posted Image[/IMG]
Shaped and cut in around 20mm
Posted Image[/IMG]
Tacked welded the starting edge and kept shaping the inner with a hammer and dolly
Posted Image[/IMG]
Finished off all the weldeing
Posted Image[/IMG]
Give it a very quick grind down , will finish off and dress later
Hope this may help some others
#2 _Yella SLuR_
_Yella SLuR_
Posted 18 May 2008 - 09:47 PM
I should take some pics of mine, was done circa 1974/5.
#3 _wardy_
_wardy_
Posted 18 May 2008 - 09:49 PM
Hi Yella , Would be interesting to see how it was done in those days .....
#4 _Yella SLuR_
_Yella SLuR_
Posted 18 May 2008 - 09:57 PM
Yes it would. I just have to remember one day when it is out of bed.
Just thinking (dangerous I know), but it will be interesting to see if they cut and tuck, or if they have just made up a new bit of sheet metal to weld in. I don't know, but will be interesting to see, just in case, heaven forbid, I ever have to make a new Yella.
EDIT2: God I'll get it eventually. The way you have tackled it doesn't look too bad. How did you check to make sure it didn't suck in the outer panel? Bout the only risk I can see.
Edited by Yella SLuR, 18 May 2008 - 10:02 PM.
#5 _wardy_
_wardy_
Posted 19 May 2008 - 05:49 PM
Yella, Outer didnt suck in at all , i kept rotating were i was welding . diferent tack spot each time , not 1 big long line
#6 arrimar
arrimar
  • 3,134 posts
Posted 19 May 2008 - 08:37 PM
hows it look with the door shut?
Looks tidy from here.
