Does anyone do a cam to suit a turbo Holden 6?
Posted 23 June 2008 - 06:03 PM
Was just wondering if there any any cams available off the shelf to suit a turbo holden 6? I've looked through a few websites of some common manufacturers but couldn't really find anything except naturally aspirated stuff.
I was considering using a vk efi cam as they are meant to be a pretty good match for forced induction so i've heard but dont really want to take a risk with second hand stuff.
Any suggestions/advice etc would be good. If any more details are needed let me know.
Thanks in advance
#2 _coupe202_
Posted 23 June 2008 - 07:23 PM
Crow Cams 5651
These cams work really well in turbo holden 6s
Posted 23 June 2008 - 07:40 PM
Have you had experience with using this cam behind a holden 6?
Posted 23 June 2008 - 07:46 PM
Posted 23 June 2008 - 08:15 PM
Ex .267, 63-27, 199 duration @.050, 110 lobe sep
In .268, 25-64, 199 duration @.050, 110 lobe sep,
Might give Motor Improvements a shot.
#6 _brett_32i_
Posted 23 June 2008 - 08:29 PM
#7 _coupe202_
Posted 23 June 2008 - 08:33 PM
what manifolds are you using and is it carby or efi.
Posted 23 June 2008 - 09:04 PM
Posted 23 June 2008 - 09:16 PM
Posted 23 June 2008 - 10:27 PM
http://www.camtechcams.com.au/
Posted 24 June 2008 - 02:51 PM
minor blowup?Have you got the exhaust manifold made or is it still a planning thing....I still need to get mine made...and there was a minor blowup last time custom exhaust manifolds was discussed on here.
What kind of intricacy were you looking at for the manifolds, my old boy might be able to do something for you if you need it, just give him a bell.
Posted 24 June 2008 - 04:54 PM
I'll be building two motors as I have a few bits lying around. The first will be the prototype to sort out any issues etc, second more serious
Out out interest coupe202 what sort of power where you making with the 259a and what where the specs of the motor etc. Also efi or carby?
#13 _coupe202_
Posted 24 June 2008 - 07:12 PM
The engine was running a quadie carby. Power figure not sure. The engine was in lj the car ran 12.2 with 15psi. Thats with 259a wade cam.
Posted 26 June 2008 - 05:56 PM
I might make a few calls to see if I can find something better if not I�ll throw the wade in.
I'm hoping for around 200rwkw initially.
Posted 27 June 2008 - 12:16 AM
Our part number CT35 - 619 will suit your turbo 202 perfect.
Duration at 50 thou
241 Intake
232 Exhaust
Lift at valve with 1.6 rocker
508 Intake
493 Exhaust
Lobe separation 114
Price:
Camshaft $242.00
Seamed like a good price what do you think?
#16 _brett_32i_
Posted 27 June 2008 - 11:11 AM
price is about right,
Posted 27 June 2008 - 12:23 PM
My car wont be on the road much but I'm hoping I can drive it on the street without to many problems.
Going by their other cams its in-between a stage 4 and 5.
#18 _brett_32i_
Posted 27 June 2008 - 12:39 PM
#19 _mervex_
Posted 27 June 2008 - 05:25 PM
Edited by mervex, 27 June 2008 - 05:28 PM.
Posted 27 June 2008 - 05:44 PM
#21
Posted 28 June 2008 - 04:02 PM
I dont reveal my specs as took a bit of dosh working out what worked but I can grind you the same cam I got in my 500rwhp turbo tory.
Alot of cam companies really dont know what works with turbos. They will grind you something that they think will work.
#22
Posted 28 June 2008 - 04:07 PM
#23
Posted 28 June 2008 - 05:51 PM
The cam I do is 214 deg duration at 50 thou so its not a small cam. I use rhoads lifters and with these they idle nicely. With the solids just a bit more lopey.
#24 _2ELCS_
Posted 28 June 2008 - 09:06 PM
#25
Posted 29 June 2008 - 04:05 PM
2ELCS: carby or efi? Second hand manifolds are usually available on ebay to suit a carby setup.
