I need some help here on identifying this drop tank and wether it'll fit my LX hatch.
I called into my local Aluminium fabricator enquiring about manufacturing a drop tank as they aren't as
easy to get over here in NZ, and he said he could do a new one for about a grand, or if this one works
I can have it for a lot less as it was made but not collected a long time ago. He couldn't remember if it was
for a Torana or an HQ.
The length left to right dimension at the back of the tank is 930mm, front 640mm, width front to back 530mm
(340mm before it angles in toward the front) - any other dimensions necessary let me know - these dimensions
differ from the drop tank thread posted here.
The guy let me take it home to try it, but I measured between the chassis rails at about 1125mm, so this tank
have to be either bolted to the floor pan (which I don't thinks is a good idea), or it gets strapped.
the bottom outlet pipe seems to be about 1 1/4 inch and the top breather pipe is about an inch. These seem way
to big, but the guy said he can adapt whatever is needed to make it work for me.
I just wanna know if this can work for me, or am I better to get something made properly for my hatch.
Cheers guys
