drop tank
38 replies to this topic
#26 _427matt_
_427matt_
Posted 24 July 2014 - 03:11 AM
Hi guys, My Brown Davis tank has a 1/2" pick up but its up high, Is this normal? I would have thought it be at bottom of the tank.
#27 N/A-PWR
  • 9,636 posts
Posted 24 July 2014 - 07:36 AM
Hi Matt,
I could imagine, up high, meaning you would run out of fuel, when you still have fuel in the Tank,
have you used the Tank yet?
The Fuel sender float, probably goes from empty to full levels.
Do you have a picture to show us.
#28 N/A-PWR
  • 9,636 posts
Posted 24 July 2014 - 07:39 AM
maybe you can bend the pickup back down where it is supose to be
#29 ls2lxhatch
  • 5,332 posts
Posted 24 July 2014 - 11:17 AM
The 1/2" line (red plastic cap) is mounted above the factory sender mount however it should run down inside the tank to a swirl pot at the bottom towards the rear. If you look through the factory sender hole you should be able to see the 1/2" line. I assume that it is mounted above the factory sender so that the line comes out close to where the factory line ran.
This is a photo taken from a video inside the Brown Davis tank. It shows the 1/2" line in a Brown Davis swirl pot which is basically a box around 200 mm x 200 mm x 50 mm with a couple of holes in it for the fuel to flow when the fuel level is low. You can see one of the fill holes to the left of the pickup.
Edited by ls2lxhatch, 24 July 2014 - 11:24 AM.
#30 _427matt_
_427matt_
Posted 24 July 2014 - 11:36 AM
Thanks GasPower & Ls2LxHatch
I will try load a pic up.
Your responses are much appreciated
#31 _427matt_
_427matt_
Posted 24 July 2014 - 11:49 AM
No tank is not in car yet GasPower. Ls2Lx Hatch that little cap is the factory fuel pickup, I had an aditional larger 1/2 inch fitting welded in. Still working out how to upload a pic. Thanks guys
#32 ls2lxhatch
  • 5,332 posts
Posted 24 July 2014 - 11:53 AM
I ordered a Brown Davis tank with 1/2" pickup and swirl pot.
The little cap is the 1/2" pickup, it just looks small in the photo. You can see a large red cap plugging the hole where the factory sender/pickup mounts.
This is the brown davis tank without a 1/2" pickup.
This angle shows a bit more of the 1/2" pickup.
Edited by ls2lxhatch, 24 July 2014 - 12:01 PM.
#33 _427matt_
_427matt_
Posted 24 July 2014 - 12:28 PM
Stuffed if i know how to upload a picture. thanks for all the help and pictures guys.
#34 N/A-PWR
  • 9,636 posts
Posted 24 July 2014 - 12:49 PM
See if this Link helps Matt:-
http://www.gmh-toran...e-2#entry762617
#35 _427matt_
_427matt_
Posted 24 July 2014 - 12:50 PM
#36 ls2lxhatch
  • 5,332 posts
Posted 24 July 2014 - 12:53 PM
email the picture to [email protected] and I will post it up,
#37 ls2lxhatch
  • 5,332 posts
Posted 24 July 2014 - 02:23 PM
This is the picture of Matt's tank. It is similar to mine but instead Brown Davis have welded a -8 fitting to the end of the 1/2" pickup. If you remove the factory sender and have a look inside you should be able to see a -8 tube running from the fitting to the bottom of the tank. You could just weld a -8 fitting at the bottom of the tank without a pickup tube but then fuel would be able to run away from the fitting on acceleration.
This is the inside the tank I built. You can see the fuel tube and AN fittings.
Edited by ls2lxhatch, 24 July 2014 - 02:25 PM.
#38 Statler
  • 6,314 posts
Posted 24 July 2014 - 06:28 PM
I looked inside my BD tank with a scope & couldn't see anything except a baffle or the walls of the surge tank.
#39 _victor_
_victor_
Posted 29 July 2014 - 02:57 PM
My question is, if everything staying stock with straps will fit straight on.
Victor
