Can someone point me in the right direction as i thought i have seen this infromation somewhere bur F**ed if i can find it, i was chasing the technical specs for a UC K Frame so i can check for aligment, thanks
UC K Frame
_dapperUC_
, Sep 22 2008 04:13 PM
2 replies to this topic
_dapperUC_
Posted 22 September 2008 - 04:13 PM
Posted 22 September 2008 - 07:43 PM
I have not seen any technical specs for the K-frame. A few people have measured the distance between the K-frame bolt holes.
http://www.gmh-toran...?showtopic=2065
794 mm front and 792 mm rear centre to centre was the result for three k-frames and one 790 mm front and 789 mm rear. I measured my power steering front end which is LX RTS and it was 789 mm front and 787 mm rear which made me think it had sagged from the V8 and power steering mods. I then measured the spare UC front which had a six and and came up with the same measurements, so I guess it must be within typical tolerance's.
You will find a body drawing in this thread.
http://www.gmh-toran...showtopic=11911
_dapperUC_
Posted 22 September 2008 - 09:24 PM
Thank you
