Over the last few months, I have been doing minor mods to my ute to improve on its fuel economy. Before people say "Why do you drive a V8 if you want fuel economy" I drive one because I LOVE V8's, I use it to tow, and its a great car!
The best thing about all these mods, are they also improve power! So you get the best of both worlds! Extra grunt for less $$$$$
Ok, When i first got my ute, Fuel economy was at about 15.5L/100km's (Around town avg speed about 50-60km/h). I thought that was a little bit ridiculous.
Here is a boring plastic fantastic shot of the engine bay when i got it
![Posted Image](https://cache.gmh-torana.com.au/i29.photobucket.com/albums/c257/253ToranaSS/Picture016.jpg)
First thing I did, was give the car a tune.
- Oil Change
- New Spark Plugs
- New Leads (MSD ones are only $10 more than stock ones i found)
- New Filters
This helped to bring economy down to about 15L/100kms and the car was feeling a lot nicer to drive.
The First "Mod" - Set the Turtle Free
- The first "mod" I did, was rip off the turtle shell engine cover! Apparently the big covers can trap alot of heat over the plastic inlet manifolds, causing heatsoak and damaging economy. This is mainly a problem on hot days. Seeing I did this over winter, I noticed no real difference. But I have heard others noticing big gains by doing this.
I bought some VZ twin monaro engine covers to make the engine bay presentable, They only cover the coil packs, so heat from the Inlet manifold can kind of escape.
I found that it also made my engine actually look like an engine! No more hiding things! HAHA
![Posted Image](https://cache.gmh-torana.com.au/i29.photobucket.com/albums/c257/253ToranaSS/Picture018-1.jpg)
The Second Mod - Twin 2.5" Exhaust
- The second thing i had to do. Was get this V8 sounding like a V8. The Stock exhaust was very restrictive and really did make the car sound like a V6 Commodore. So i put on a Twin 2.5" Cat-back twin system on it. Instantly I could hear the car, but it was not drony or over the top. It now has a nice growl to it and sounds nice to drive. Being a ute, i was worried it would drone. But my exhaust guy put on a really good system, and at 110k's you don't hear a thing!
This mod was the first one where i started to notice an improvement in economy, suddenly if i drove like a grandma. I could get economy down to about 14.5L/100km's. I can't say i noticed any real "power" gains... But it was a lot nicer to drive with a good exhaust. I'm sure if i strapped it on a dyno, there probably would be a 5kw gain or something like that.
The Third Mod - OTR CAI (Over the radiator, Cold Air Intake)
- Ok, The third mod is kinda mixed in with the 4th mod (Have to do them at the same time)
The OTR is a Cold Air Intake mod, It comes off the front of the Throttle Body and gets cold air directly from the front of the radiator. These are the best forms of CAI's for the VT-VZ range. To fit the OTR though, you need to remove the MAF (Mass Air Flow) Sensor. Its not as simple as just disconnecting it though. Your engine computer is set-up to adjust things according to this sensor. So if you disconnect it and try and drive... The car will most likely run like a bag of shit. So to match the removal of the MAF, you will need to get yourself a Mafless tune, which leads me to my 4th and final mod.
(See my garage on how i installed the OTR http://www.gmh-toran.......106&CID=15)
The Fourth Mod - Custom Mafless Tune
- I dummy fitted up my OTR, then returned it to stock to drive to my Tuner, Once i got there I bolted on the OTR and he tuned my car for me. This is the biggest increase in EVERYTHING that you will see! Make sure you tune it after all your mods, or you may be returning in the future to get things changed.
The LS1's are detuned from factory (Why? I don't know, Warranty precautions?). They have conservative Timing and A:F ratios.
There are "mail order" options for tunes, which i was going to go. But i ended up meeting a tuner who tuned my car for me. My car absolutely flies now! It is incredible! I haven't run it on a Dyno, but my tuner said going on the other cars he has tuned, Mine should be about the 230rwkw mark (Not bad considering it was 225 Fly wheel kW from factory, now it would be 300fwkW!)
The BEST thing about all this, is that fuel economy is SO much better now! Even with me "enjoying" the new found power, i have STILL managed to drop my economy to 13.5L/100km's! (This is around town btw). So if i can just drive it normally, i won't be surprised it i drop into the low 13's or high 12's! Which I think is BLOODY awesome!
Here is how my engine bay looks now as well.
![Posted Image](https://cache.gmh-torana.com.au/i29.photobucket.com/albums/c257/253ToranaSS/Picture005-4.jpg)
If you have any questions or people have other tips, just post them up! I know a lot of guys on here have LS1's or LS2's and this will no doubt help them out!
Matt
P.S Check my Garage for pics of all my mods
http://www.gmh-toran.......item&CID=15
