UC rear discs
_CHOPPER_
Posted 12 November 2008 - 10:29 PM
Posted 12 November 2008 - 10:47 PM
Edited by rodomo, 12 November 2008 - 11:00 PM.
Posted 13 November 2008 - 12:09 AM
14.22 minimum
Cant find anything that says new thickness yet!
But have a contact that might have some old PBR books that might shed more light on this.
If/when i get it i'll add it.
I'm currently searching/researching for all this info at the moment.
_CHOPPER_
Posted 13 November 2008 - 03:17 AM
Posted 13 November 2008 - 12:46 PM
DBA had one of my spares for a time and couldn't match the measurements up with anything else australian - std or turned down........
We may need to take orders and see if we can have a bulk order produced.
Grant..
_CHOPPER_
Posted 13 November 2008 - 01:19 PM
I do know what is likely to be the other possible vehicles they may have been on, and I can arrange a batch of new discs as long as I pay in advance. When I asked, the minimum order was 10 units.
Posted 17 November 2008 - 12:07 PM
When we sat down at Silverwater, they were going to come out about three times the cost of an HZ rotor!!
An minimum run.....don't ask.
We should be able to make the disc slightly thicker, as the caliper is the same as A9X, so accepts a wider rotor.......
Can they do slotted or vented??
Grant..
Posted 17 November 2008 - 02:24 PM
The UC rear disc rotors are 10 1/2 inches in diameter & 5/8 inches thick. In metric this is 266.7 mm x 15.875 mm. A lot of these companies round up & down when they convert imperial to metric. To my knowledge the HZ/WB & A9X rear disc is the same thickness as the UC (15.875 mm), just larger in diameter (both hub & outer).
Dr Terry
_CHOPPER_
Posted 17 November 2008 - 04:48 PM
When I have the spare cash t o lay down, then I will get those details.
Terry:
Thanks for the confirmation of the diameter and original thickness.
Posted 18 November 2008 - 12:40 PM
Grant..
Posted 18 November 2008 - 09:02 PM
Not alot
But its different
And I doubt you would get any more radial out of the disc before it bangs the caliper
Not to mention the top radius of the pad
Don't go reinventing the wheel
Posted 19 November 2008 - 05:15 PM
It was worth a try.
Are you able to post the differences Neil?
Grant..
Posted 22 November 2008 - 01:34 AM
They'll need to be wider so they can be machined a few or 4 times if they are going to be around $400 eachthey were going to come out about three times the cost of an HZ rotor!!
Grant..
Otherwise it will be bloody hard to justify too SWMBO
(she who must be obeyed)
_CHOPPER_
Posted 22 November 2008 - 09:30 AM
Thankyou oh wise and noble sir.
It was worth a try.
Grant..
I have HZ and UC rear discs and calipers here if you are after pics. But I'm moving in a couple of weeks, so don't hold your breath.
Posted 10 June 2009 - 06:33 AM
I'm a couple of steps ahead of you Grant.
If anyone is interested in going ahead with this then I'm another person who might be interested in sharing the cost of a limited run. Does anyone know how much exactly it would cost?
_memorylane-spare-parts_
Posted 10 June 2009 - 08:39 AM
_torana50_
Posted 25 June 2009 - 10:26 AM
Posted 12 November 2009 - 05:59 AM
I am about to fit a set of rear discs to my UC Hatch. I am interested in availability of new rotors. Also I heard that I will have to make some changes to the proportioning valve, can anyone help?
New UC Rear Discs.
_wally308_
Posted 23 February 2010 - 05:54 PM
I have picked up a UC rear Disc Diff for my 308 hatch,
can someone tell me wat booster/master cylender i can use.
iv heard u can use the A9X style booster?
but where do i find one.
any info would help.
thanks
Posted 23 February 2010 - 06:59 PM
#21
Posted 23 February 2010 - 09:57 PM
#22
_wally308_
Posted 24 February 2010 - 09:10 PM
