202 oil pump external intake modification .
8 replies to this topic
#1 nzxu1
nzxu1
  • 275 posts
Posted 27 November 2008 - 04:56 PM
l've just bought a hi energy sump with an external pickup on the bottom of the sump but l don't have an oil pump to match . Can anyone help me with pics or info on how to modify a pump to suit or maybe someone has a spare modded plate that they would sell me ? . :)
#2 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 27 November 2008 - 05:09 PM
Hi mate
Sorry i cant help u with your questions but maybe u can help me i already have a high energy sump but want to fit external to my sump do u have photos or if u dont mind what did your sump cost so i can maybe sell mine n just buy one? Any photos would be GREAT
#3 nzxu1
nzxu1
  • 275 posts
Posted 27 November 2008 - 06:31 PM
HI Stedz , sump came fitted to an engine l bought but it was missing the matching oil pump so can't tell you have much they are sorry :(
#4 ls2lxhatch
  • 5,332 posts
Posted 27 November 2008 - 07:40 PM
I have not done this myself and I do not have an engine with the mod. However you will find some pictures in this thread.
http://www.gmh-toran.......25898&st=13
#5 _Drag lc_
_Drag lc_
Posted 28 November 2008 - 05:09 PM
NZxu1,
i have done this mod i hope these pics work when we modified the oil pump for external pick up we just tig welded a "jic" (an) plug
that i had spigoted into the std cover plate make sure you get it re faced after welding but i amsure you would do it any way ,from memory
i think you can tap the std oil inlet on pump to 1/4 npt to plug it off.
Hope this helps Thanks Hayden
#6 turbotrana
turbotrana
  • 155 posts
Posted 29 November 2008 - 12:22 AM
IMO you are wasting your time with an external pick up like that.
What is most important is a supply a feed to no 1 and no 6 main oil gallery on the pressure side. In the other thread there was a photo with the braided line.
I've run 500+rwhp in my turbo 6 for years with the standard pickup. My oil pump is ported and blueprinted and all internal oil passages have been massaged a bit, plus external lines on the main gallery. Only 50psi pressure and never a problem and its been well thrashed for years.
#7 _Drag lc_
_Drag lc_
Posted 29 November 2008 - 07:17 AM
turbotrana,
yes mate it is on the rather large side but unsure if you have done the calculations in regards to suction hose size
to help prevent cavation at high revs you would know that the std 10.5mm id pick up is very marginal in fact with a well
prepared hv oil pump it would have a flow velocity of 50+ ft/sec at 7,000 crank rpm in the std oil pick up if you were to put
the correct size suction hose on the pump it would have to be 11/4 id to get 4 or 5 ft/sec flow velocity but that would be a
little extreme this is why we have put a 1" id oil pick up on it. what you might find is that alot of the old blokes that have
run these engines for years in a racing enviroment have external oil pick ups fitted. but i am aware of the 1 and 6 pressure
feeds but i have not used then as yet.
Thanks Hayden
#8 nzxu1
nzxu1
  • 275 posts
Posted 29 November 2008 - 06:58 PM
Thanks for the pics and tips guys , have you run this engine with that pump setup Hayden ? . :)
#9 _Drag lc_
_Drag lc_
Posted 30 November 2008 - 07:09 AM
Nzxu1,
yes we have we have run into the 12s using this setup with no dramas and run it on the street aswell we also ran this
set up when we converted it to alcohol with no dramas aswell.
Thanks hayden
