Just bought this 186
54 replies to this topic
#1 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 07 April 2009 - 06:08 PM
Attached File  Chris_Maisons_186.JPG   803.68K   51 downloadsAttached File  Chris_Maisons_186__2_.JPG   1.03MB   129 downloads
Attached File  Chris_Maisons_186__3_.JPG   1.05MB   53 downloadsAttached File  Chris_Maisons_186__4_.JPG   1.02MB   90 downloads]Attached File  Chris_Maisons_186__5_.JPG   855.28K   32 downloadsAttached File  Chris_Maisons_186__6_.JPG   879.92K   27 downloadsG]Attached File  Chris_Maisons_186__7_.JPG   905.18K   47 downloadsAttached File  Chris_Maisons_186__8_.JPG   914.21K   33 downloadsPG]Attached File  Chris_Maisons_186__9_.JPG   938.71K   20 downloadsAttached File  Chris_Maisons_186__10_.JPG   880.07K   25 downloadsJPG]Attached File  Chris_Maisons_186__11_.JPG   775.37K   41 downloadsI just bought this lot tonight for a grand.The head looks pretty wild,I'm wondering if its been taken too far.
Came with a new full manual trimatic,and all the rest you can see in the photos.
The motor is apparently a 186 with a 202 crank.
Why anybody would need a full manual auto is beyond me,when you can have a full manual manual with the addition of a clutch pedal
I'll soon be looking for a Muncie.
This will not be going in a street car.
Any information or opinions on the head would be appreciated.I've included the engine no in case its something special to you number orientated guys.
Cheers,Craig.
#2 Zook
Zook
  • 1,536 posts
Posted 07 April 2009 - 06:57 PM
Those are huge ports and big valves and the head has been shaved a long way. I'd be doing some very careful compression ratio calcs just to make sure you can run it ok on pump unleaded....or else just add acetone!
#3 Heath
  • 18,403 posts
Posted 07 April 2009 - 07:00 PM
Yeah they are minute combustion chambers.
Ummm i THINK it's an early Irving head but I can't for the life of me find the documentation I'm looking for
I've got a spare 186P here... I don't think you really want this; do you want to swap for a more fuel efficient six cylinder instead?
#4 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 April 2009 - 07:01 PM
I'll be more inclined to stick some 2 inch SUs on it and fill it with methanol.
#5 _clubspClubsportr8ortr8_
Posted 07 April 2009 - 07:27 PM
Hi i can help supply some 2" su's.
Jeff
#6 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 April 2009 - 07:28 PM
Let me think about that trade for a couple of seconds(tic tic tic)Nope.Is a 186p anything special?
The guy I got it off had it in an LC about 8 years ago,pulled it to bits,reworked the head,got the auto built,then sold the car but kept the running gear.Its been moving from house to house,Sydney to Brisneyland and back ever since,never seeing another car.
I think he just got sick of moving it.
#7 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 April 2009 - 07:36 PM
Jeff
pm sent
#8 Zook
Zook
  • 1,536 posts
Now you're talking :clap:
#9 VitcLJ
VitcLJ
  • 130 posts
Posted 07 April 2009 - 08:52 PM
Nice work on the head. Looks like it has been set up for a cup head bolt (or a short stud)in the inlet ports and then plugged on top (Removes the centre interference.) Combustion chambers are very small I'd be cc'ing them and work out the compression ratio. just looking at it I'd guess its in excess of 11 to 1. Methanol and or AVgas or racing fuel would probably be needed to stop pinging. Also check the cam if its a big lift long, duration puppy you would be well advised to check the clearances to the piston and the cylinder edge. you may have to relieve either or both.
personally I dont think it would be a daily driver unless you live on a racetrack or need to get somewhere in a hurry and have stealth mode enabled to prevent radar bounce. Looks like a good head for an NC historic race car.
#10 _Bomber Watson_
Posted 07 April 2009 - 10:06 PM
Looks good mate.
Piff that stupid chrome oil pump cover off, thats asking for leaks as it flexes.
Head work does sure look impressive, exhaust is ported more than i have ever seen. Hasnt had that much shaven off it, can still see the thumb print. Unless its been shaven on an angle (to give more valve clearance). Some unsrouding around the combustion chambers wouldent hurt it with valves that big. Definitely have it thrown on a flow bench to see what you have there.
Do you have any picks of the sides of the slugs without the rings installed???
Lifters are useless, unless you get them surfaced. Stupid people mixing them up.
And fully manualized auto's rule if you wish only to go in a strait line. If its built right it will be a very good box.
Looks good anyway!!!!
#11 _HQ SS_
_HQ SS_
I have 186P listed as a HK, HT, HG engine.
Thats a real nice head you have there.
This is what I would rate as being the proverbial stage 5 type head.
Major port and throat work, Heavy duty duel springs and heavy duty retainers.
Does it have screw in studs or std rocker studs that have been pinned (that was a old trick to stop them pulling the studs out with high lift cams and
heavy duty springs)
It looks like the oil gallery's have been opened up too.
As stated above it has had a good size decking done to it too.
This is what a std chamber looks like.
I am not sure from the picture but have the inlet ports been polished, as this was a old common practice as well. (now shown to be a little misguided )
If they are real smooth and polished it may actually pay to have them roughened up a little to aid fuel atomization . (if you did not already now this that is.)
I would put a 7420109 head as being around a 1964 cast head so off a EH originally.
I would be interested to see what the actual date casting was on this head.
Would it be possible to use your pictures of this head in the head age/chamber design and modification guide's I am putting together.
It is a great example of a top end modified holden red 6 head.
What I have so far are here for casting to chamber design.
http://gallery.oldho...yl Casting ids/
and here for general information
http://gallery.oldho...ines/red heads/
that is now in need of a major clean up and reorganize.
Cheers Paul.
Edited by HQ SS, 07 April 2009 - 10:09 PM.
#12 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 April 2009 - 10:17 PM
Thanks Paul.Feel free to use the photos.I'll send you some more detailed shots if you like.Tell me what you need.
Rocker studs are pinned.
Cheers,Craig.
#13 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 April 2009 - 10:31 PM
Looks good mate.
Yeah,all that Kmart Chrome is going in the bin.
Will be getting a couple of old drag racers I know to check it out as well.
Bottom end is assembled,apparently with 202 crank and pistons,and starfire rods.The pistons in the box are new +40 186 pistons.I'll add some shots if you want them.
Manual autos are dull.My old car was heaps more fun running 13.0 with a toploader than it was running 10.80s with a manual glide.
Stickshifts forever.
#14 Heath
  • 18,403 posts
Posted 07 April 2009 - 10:56 PM
Tricked up autos are definately an aquired taste. If you can get over the horrible sound they make when they shift gear then you can appreciate them a lot more. But obviously it's a debate that will never and should never be settled, but I would hesitate to ever put an auto behind a six.
I still can't find what I'm looking for about the head, but I'll tell you now it isn't a one-off. If I find anything out I'll let you know.
Chrome plated engine mounts are different...
#15 _HQ SS_
_HQ SS_
Cheers,Craig.
Thanks Craig.
That is very much appreciated.
If possible a shot showing a pinned stud would be good.
The other three shots are real good as they show the port, the chamber and the springs as well.
As I said I would interested in the date code on it as well if that is ok.
I need to update this but this is what I have put together so far here.
http://gallery.oldho...ing 01.jpg.html
and here
http://gallery.oldho...ing 02.jpg.html
Is the head a H casting head, the H casting should be up the front on the left hand side just behind where the thermostat housing bolts on.
Cheers Paul.
#16 _oldjohnno_
_oldjohnno_
Posted 08 April 2009 - 06:41 AM
I wouldn't be so quick to dismiss the auto (assuming this will be a strip only car). With the right convertor you'll probably find it to be significantly quicker and more consistent than a manual.
#17 Heath
  • 18,403 posts
Posted 08 April 2009 - 08:27 AM
^ Just for the record, he said manuals were more fun, not faster.
#18 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 08 April 2009 - 08:46 AM
Dead right Heath.The fun goes out of it when it just goes straight.Rippin gears is top fun.And consistency isn't that hard to achieve once you figure out what the car will do when you sidestep it.
#19 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 08 April 2009 - 08:46 PM
Attached File  Chris_Maisons_186__2_.JPG   811.43K   39 downloadsAttached File  Chris_Maisons_186__3_.JPG   797.66K   14 downloadsG]Attached File  Chris_Maisons_186__4_.JPG   987.31K   6 downloadsAttached File  Chris_Maisons_186__5_.JPG   917.35K   5 downloadsPG]Attached File  Chris_Maisons_186__6_.JPG   981.52K   19 downloadsAttached File  Chris_Maisons_186__7_.JPG   826.26K   9 downloadsJPG]Attached File  Chris_Maisons_186__8_.JPG   773.5K   6 downloadsAttached File  Chris_Maisons_186__9_.JPG   857.82K   11 downloads.JPG]Attached File  Chris_Maisons_186__10_.JPG   980.59K   6 downloadsAttached File  Chris_Maisons_186__11_.JPG   914.09K   2 downloads_.JPG]Attached File  Chris_Maisons_186__12_.JPG   1.02MB   4 downloadsAttached File  Chris_Maisons_186__13_.JPG   860.06K   15 downloads3_.JPG]Attached File  Chris_Maisons_186__14_.JPG   929.87K   12 downloadsAttached File  Chris_Maisons_186__15_.JPG   975.76K   19 downloads15_.JPG]Some more shots for HQSS showing pinned studs.Also some shots of an old yella terra I found lying in a paddock.
#20 _HQ SS_
_HQ SS_
Posted 08 April 2009 - 10:06 PM
Excellent thanks Craig perfect shots.
These 7420109 H heads seem to have been a favorite with Y/T and others as a starting point for a worked head.
Both heads are EH heads C 25 4 25th of the 3rd 1964 for the Y/T and K 4 5 4th of the 10th 1965 for your other head.
You head is a fine piece of work alright my head was actually pinned with freeze/lock pins,( Oh do I regret the day I sold that ex Circuit racing head for $100) on yours they have gone to the trouble of drilling tapping and grub screwing it.
It looks like it was made to rev hard that head.
I am curious did you have a look at this thread Craig.
http://www.gmh-toran.......=35157&st=0
I was wondering if the Y/T head has a code on the back the same as those in that thread.
So far they all seem to be stamped with a early eighties date code.
Thanks again Paul.
#21 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 08 April 2009 - 10:21 PM
yeah,Paul,I already checked that thread out.There dont appear to be any extra numbers stamped on it,and the valves dont have YT on them.
It may not even be a yella terra,maybe just painted yellow.
As I said,I found itin a paddock while cleaning up some junk at a house a friend was renting years ago.
Its been hanging around ever since.
#22 _HQ SS_
_HQ SS_
Posted 08 April 2009 - 10:56 PM
It may still be a Y/T but a early one before they started using the Y/T valves etc.
Thanks again Paul.
#23 orangeLJ
Posted 09 April 2009 - 12:21 PM
jesus christ.
I really really want that head!
#24 ToRunYa
ToRunYa
  • 2,073 posts
  • Name:Em
Posted 10 April 2009 - 08:14 AM
yer my y/t head was a early one. didnt have the yt on the valves... done the trick still LOL
#25 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 10 April 2009 - 08:39 AM
jesus christ.
I really really want head!
things a bit tight at home Chris? :tease:
