Commodore Wheels
11 replies to this topic
#1 _Mr S_
_Mr S_
Posted 03 November 2009 - 09:49 AM
G'day everyone
This is props a stupid question for most but i need help
I got a set of Commodore wheels i wanna put on the Torrie and would like to know how do i go about doing so.
Ive seen those adaptor plates on ebay but pretty sure they are illegal. So changing the axels. Where do i start and what needs to be done? Also is the HQ pattern the same as the Commodore's?
any info would help
Thanks guys
pic of the wheels i wanna put on
#2 dattoman
  • 16,487 posts
Posted 03 November 2009 - 10:00 AM
There is a slight difference to the stud pattern
HQ is 120.65mm
Commodore is 120mm
Commodore studs are 12mm
HQ are 7/16"
Centre hole size is different on the wheels
Offsets are vastly different so you might find the wheels foul on the suspension and or bodywork as the wheels are essentially a FWD offset pulling everything in away from the guard
Incorrect wheel fitment can lead to breaking studs and losing a wheel
Not to mention the associated insurance problems
#3 GML-31
Posted 03 November 2009 - 10:01 AM
offset will be wrong ... I am running the wheel adaptors on mine and have had no problems so far, by memory I got them from St George tyres on ebay, they fix the offset by 30mm as well.
#4 _Mr S_
_Mr S_
Posted 03 November 2009 - 10:22 AM
Cheers for the quick replies
and those stud pattern measurments are handy to know so thanks
i sat one of then rims under the car on the rear and it wasnt going to hit anything but if i used those adaptor plates and they added an extra 30mm they will hit the guards for sure.
#5 ls2lxhatch
  • 5,332 posts
Posted 03 November 2009 - 10:23 AM
According to an article in Street Machine wheel adaptors are not legal in any state unless fitted by the vehicle manufacturer. They are definitely not legal in WA or any state that adopts the NCOP.
It may be possible to make an adaptor that is safe however it still will not be legal. If you survive an accident as a result of using the hub adaptors you may wish you didn't. Your insurance company would have the option not pay out for damage to your vehicle or any damage you do to other vehicles or property.
More pictures of failed wheel adaptor in this thread.
Edited by ls2lxhatch, 03 November 2009 - 10:27 AM.
#6 _Mr S_
_Mr S_
Posted 03 November 2009 - 10:33 AM
Thanks ls2lxhatch i thought they were illegal and i dont ever want that to happen
So what are the proper ways i can do this?
would early commodore axels just slide into the Torrie banjo diff?
CHEERS
Edited by Mr S, 03 November 2009 - 10:35 AM.
#7 76lxhatch
  • 7,205 posts
Posted 03 November 2009 - 11:07 AM
Yes but they'd stick out a long way! :tease:
Most people change stud pattern in conjunction with an all-round brake upgrade. If you want to spend that sort of money then take a look at some of the options in various threads on this site and through the likes of Hoppers Stoppers.
#8 _Mr S_
_Mr S_
Posted 03 November 2009 - 11:18 AM
Yes but they'd stick out a long way! Posted Image
Thanks mate
a brake upgrade isnt really on the list at the moment but will be done when the V8 comes into play. might just keep an eye out for some nice looking Torrie rims
#9 76lxhatch
  • 7,205 posts
Posted 03 November 2009 - 03:33 PM
Sounds like a plan, there is quite a bit involved in changing the stud pattern safely and costs add up quick
#10 ls2lxhatch
  • 5,332 posts
Posted 03 November 2009 - 04:14 PM
The stud pattern is the easy part. The big problem with Commodore rims is the offset. You can not legally use spacers to correct rim offset on an LX Torana. The rear can be fixed by fitting a diff that is wider than the standard Torana diff to suit the Commodore offset. Changing the front hub position to suit the Commodore offset is not as simple. Hopper Stoppers can make their front brake kit with the hubs set 8 mm further out than standard but this may not be enough.
#11 _Mr S_
_Mr S_
Posted 03 November 2009 - 08:47 PM
Thanks again for the info everyone
It seems like to much effort and money for something thats not going to make her go faster
CHEERS
#12 _gen3torrie_
_gen3torrie_
Posted 04 November 2009 - 11:04 PM
probably best off with doing a new brake conversion with hoppers stoppers or this place.. www.racebrakes.com.au
