FRONT SWAY BAR MOUNTING
4 replies to this topic
#1 Orleans
Orleans
  • 99 posts
  • Car:LH
Posted 08 November 2009 - 07:50 AM
Can anyone show me some pics of the LH/LX front sway bar mounting points. My x-member doesn't have bolt holes for the u ring bushes, only the pin mount holes in the lower control arm.
Edited by Orleans, 08 November 2009 - 07:51 AM.
#2 Heath
  • 18,378 posts
Posted 08 November 2009 - 08:29 AM
You should just be able to bolt the ends of the swaybar on and see where it lines up
But I got a photo of a spare crossmember I have anyway, hope that helps. The holes are 15mm in diameter, which gives you lots of slack if you're using the correct U-bolts
#3 rodomo
  • 18,031 posts
Posted 08 November 2009 - 08:41 AM
^^That's how I would do it if the holes aren't there.
You would need the car at correct ride height and the "pins" happy.
By happy I mean with the least distortion in the bushes, and evenly tilting front/rear and left/right if that makes sense?
If you drill smaller holes than 15mm, it will give you more room to move on the "X" member for best result.
Edited by rodomo, 08 November 2009 - 08:41 AM.
#4 _Yella SLuR_
_Yella SLuR_
Posted 08 November 2009 - 08:59 AM
The young fella beat me to it, but here you go, you can never have enough pics. Didn't realise that plate wasn't on the second bolt, but that will be fixed shortly, as this front end is being pulled apart for painting.
Underside view:
View from above:
Detailed view of inside the side end arm:
Hope that is of some use to you.
#5 Orleans
Orleans
  • 99 posts
  • Car:LH
Posted 10 November 2009 - 05:54 PM
Thanks fellas.
