holden 6 engine mounts
_lcgtr_
Posted 08 December 2009 - 09:01 PM
Anyone know if anyone makes nolathane type ones?
_Squarepants_
Posted 08 December 2009 - 09:12 PM
If you're really keen make some solid steel ones.
I have seen a few with rubber engine mounts and a chain welded from the block to the chassis rail to limit torque twist.
Otherwise a lot of jappers use dampers (little gas shockies) from the engine to the chassis. Maybe you could adapt one of those???
Posted 09 December 2009 - 07:13 AM
http://images.google.co.nz/url?source=imgres&ct=img&q=http://littlekeylime.com/MrN/mrnimages/engine_mount_homemade02_.jpg&usg=AFQjCNEeg_YTSSET4FzLUswGaR5sryLcOg
I've seen much better implementations than the second pic but can't find them at present, you get the idea.
Posted 09 December 2009 - 08:48 AM
_mumstaxi_
Posted 09 December 2009 - 11:32 AM
I looked at all the rubber ones i could find (inc genuine holden) i didnt want nolathane, and the best i liked in rubber are the Kelpro ones i found at super cheap,i used the later model ones with the saftey stops.
I guess ive probably done almost 15,000Ks with over 400rwhp on these mounts ,they have seen heaps of 1/4 mile track time, inc 3days with a car full at powercruise, Just checked them the other day and no cracks etc.
MT
_oldjohnno_
Posted 09 December 2009 - 12:25 PM
Another thing to watch with solids (apart from with an engine plate) - it's surprising how much flex and movement there is in the crossmember or subframe of some cars. You could easily feed some pretty serious stresses into the block if the side mounts are too stiff or solid. Some of the old american GM cars had crossmembers about as stiff as a piece of paper..
_Squarepants_
Posted 09 December 2009 - 07:26 PM
Edited by Squarepants, 09 December 2009 - 07:26 PM.
_lcgtr_
Posted 09 December 2009 - 10:00 PM
wouldnt heve thought something like this was too hard to make though http://www.velocitya...tuffmountshq308
the guy who sold me the mounts suggested the chain thing
Posted 10 December 2009 - 07:15 AM
Posted 10 December 2009 - 11:00 AM
This is the case with the LSX mounts to suit the Torana, the rubber used by CAE and CRS does not have an interlock. I purchased the bottom half of a Velocity Auto's Tuff mount and made the top half to suit the LSX.
CRS EM69 mount
Modified Tuff Mount
Edited by ls2lxhatch, 10 December 2009 - 11:02 AM.
Posted 10 December 2009 - 11:22 AM
_Squarepants_
Posted 10 December 2009 - 07:18 PM
I might look at making some like them. $345 is a lot of money for engine mounts, I'm certain they wouldn't cost anywhere near that to make. Might be able to make some more as well if anyone else is interested??? They will be considersbly cheaper than that and come with my renowned 1-2 warranty (once you fit 'em, too f#cken bad) or optional Concrete warranty (once you're off my concrete, warranty is void).
Need to know what those bushes are first though please.
_lcgtr_
Posted 10 December 2009 - 11:29 PM
I work at an Auto Pro store when Im back in Perth
When I get back Ill go through the nolathane stock out the back to let you know what I think will work
_2X044_
Posted 11 December 2009 - 03:21 PM
The metal is 5mm laser cut steel and the bushes are nolathanes (forgotten part number but they come with the internal sleave).
I used two nolathane bushes to counter the imbalanced moment caused by the engine side of the mount being well inside the chassis side of the mount. I have however only done the passenger side mount as the drivers mount will be in compression anyway (and I don't have the space restriction on that side of the motor that I have on the other).
At the moment I have replaced the nolathane bush with a rod of wood of the same dimensions so that I didn't hurt the real bush during welding of the tube onto the bracket.
_lcgtr_
Posted 14 January 2010 - 12:45 AM
got some on the way, Ill post photos
Posted 17 January 2010 - 10:50 AM
Engine plates are legal in QLD, not so much elsewhere. �Check with a local engineer before fitting one for street use.
Grant..
_sickboy_
Posted 21 January 2010 - 07:11 AM
What are he bushes in the Tuff Mount/Velocity mounts? (Part No./application)
I asked these guys recently, the bushes are a front control arm bush from an early Magna.
Edited by sickboy, 21 January 2010 - 07:12 AM.
Posted 22 January 2010 - 06:50 PM
Grant..
I thought a rubber mounted one was fine???
_Squarepants_
Posted 22 January 2010 - 08:32 PM
Thanks Sicko!I asked these guys recently, the bushes are a front control arm bush from an early Magna.
