Chevy parts to Holden 308
Posted 26 December 2009 - 08:12 PM
Like roller rockers ,pushrods,conrods,roller lifters aso.
Uwe
Posted 26 December 2009 - 10:19 PM
Posted 26 December 2009 - 11:14 PM
Standard lifters are small block Chev, rockers are different ratio though. A lot of 355 stroker cranks use Chev rods and journals
The standard 350 Chev etc hydraulic lifter is not interchangeable with the Holden V8 as the oil holes do not line up 100% causing problems.
In fact there is no Chev part I know of that fits the Holden V8 without machine work.
Edited by TerrA LX, 26 December 2009 - 11:15 PM.
Posted 27 December 2009 - 03:52 AM
Uwe
Posted 27 December 2009 - 07:04 AM
Oops, fair enoughThe standard 350 Chev etc hydraulic lifter is not interchangeable with the Holden V8 as the oil holes do not line up 100% causing problems.
Posted 27 December 2009 - 03:28 PM
This is news to me. The plunger height is different however as far as I am aware they are otherwise identical.
I have seen numerous Holden engines with Chev hydraulic lifters, Yella Terra even supply a shim to allow the use of Chev Hydraulic lifters with their non adjustable rockers.
There isn't even a Holden Solid lifter, you have to use Chev ones (the plunger height issue is overcome by the need to run adjustable rockers anyway).
Posted 27 December 2009 - 08:15 PM
These things are irrelevant in a solid lifter, that is why I stipulated hydraulic.
Posted 27 December 2009 - 08:41 PM
You said "The standard 350 Chev etc hydraulic lifter is not interchangeable with the Holden V8 as the oil holes do not line up 100% causing problems." If this was the case then surely the solid lfter would suffer the same oil problems ? Oil has to travel thru both sorts of lifters in order to get to the pushrod and upstairs. Have I missed something here ?
Posted 27 December 2009 - 08:49 PM
You are correct in that the installed height is different.
Must get some lifters side by side one day.
To the OP, my suggestion Uwe would be to have an engine built locally, here in Australia as there are some unique parts in a hot up motor and the know how is here too, then have it shipped to you.
Maybe some local guys can help arrange it for you.
Posted 27 December 2009 - 08:57 PM
_cruiza_
Posted 28 December 2009 - 08:04 AM
I do not know if this is true but havxe been told that Chevy 6 fly wheel is same as 308 v8
Posted 28 December 2009 - 02:44 PM
On the same note as 76lxhatch says, some 308-350 strokers use large journal SBC rods, and in this case I think they normally use a 350 Chev stroker piston (377-388ci dependant upon bore size).
I have also seen 327 pistons used in 308's, but again before good stuff became available.
Offset ground strokers (around 327-330ci) often use SJ SBC rods.
253/308 heads can take rocker studs and then use BBC (same as Cleveland I think?) roller rockers.
SBC bellhousings will bolt straight up to TH pattern 308's s well.
