202 gilmer drive etup
#1 _yldlj_
Posted 07 January 2010 - 10:34 PM
Posted 07 January 2010 - 10:57 PM
The Holden 6 'kits' that I've seen all use a fairly skinny belt, which obviously doesn't have as much of a sound as the big fat bastards they use on other vehicles
#3 _yldlj_
Posted 07 January 2010 - 11:03 PM
Posted 07 January 2010 - 11:08 PM
Blake
link: http://www.youtube.c...h?v=fzlSJfD5r5k
#5 _yldlj_
Posted 07 January 2010 - 11:18 PM
Posted 07 January 2010 - 11:49 PM
#7 _yldlj_
Posted 08 January 2010 - 12:19 AM
Edited by yldlj, 08 January 2010 - 12:19 AM.
Posted 08 January 2010 - 10:54 AM
my setup for the hd only has 1 inch wide pulleys and belt, thats all i can squeeze in there with the desert cooler radiator. you shouldnt have any space issues in a tonner though
edit* just had another look and the alternator pulley restricts you to the 1.5 inch belt, unless you can find a wider pulley for the alternator
Edited by MCH11N, 08 January 2010 - 10:59 AM.
Posted 08 January 2010 - 11:23 AM
Posted 08 January 2010 - 11:43 AM
Posted 08 January 2010 - 01:53 PM
Posted 08 January 2010 - 02:32 PM
Posted 08 January 2010 - 03:39 PM
Posted 08 January 2010 - 04:17 PM
Yeah I have a similar kit here and the altnator pulley is 1.5" wide as mentioned before. They are pretty much universal as they have lots of holes so can probably be used with chevs etc as well.
They probably aren't that universal - I'm sure not all motors have the same rotating speed ratios between each of the driven parts.
dont forget whos selling them though... i reckon if it bolted on, they would class it as universal
#15 _Squarepants_
Posted 08 January 2010 - 07:26 PM
Posted 08 January 2010 - 07:56 PM
#17 _yldlj_
Posted 08 January 2010 - 08:28 PM
Posted 08 January 2010 - 10:53 PM
Pretty big wank factor, probably second highest to a crane cams sticker on the rear window.
Posted 08 January 2010 - 10:58 PM
If your car is a bit of a performer then underdriving the alternator may be favourable, but I wouldn't say it's the way to go for any streeter. Easy to check if it's doing its job at idle, but if you get that far you've probably already spent a few hundred bucks haha
#20 _Bomber Watson_
Posted 09 January 2010 - 05:00 PM
Agreed with Heaths statement.
That youtube vid convirmed it.
We have a totally standard 202, you can tell its bog stock by the sound (if you listen past the whistle) with a stupid fake whine that does absolutely nothing but irritate people.
#21 _Squarepants_
Posted 09 January 2010 - 05:16 PM
Bling!The only real question, is why??
A gift for the engine that has everything.
Or it could be the first step to fitting a super charger???
But I fail to see why you would want one on a standard engine, surely that money could be better spent on a real go fast bit.
#22
Posted 09 January 2010 - 05:36 PM
Sure a cam sticker is kinda bogan but who gives a f*ck. Come and spend some time where I live in gook central and you will find out what a shithouse car modification is. How about little plastic fake exhaust pipes glued onto the side skirts of a Daewoo Matiz? Live and let live
#23 _yldlj_
Posted 09 January 2010 - 05:38 PM
Edited by yldlj, 09 January 2010 - 05:43 PM.
#24
Posted 09 January 2010 - 05:42 PM
#25 _yldlj_
Posted 09 January 2010 - 05:44 PM
