Surprisingly i didn't cop much flack about putting the clevo in the torana so here we go again. As stated in last thread, most tuff toranas don't have much Holden parts left in them. I figured that if you can put a top-loader box an a 9 inch in one ,why not a ford engine.
I bought this 4 door LX 202 trimatic a few years ago and stuck it in the shed up at the farm for a while until i was ready to commit to the project.
Modified front cross member for custom pipe and sump clearance.
Custom 4 into 1 pipes,custom collectors. Pipes are 1-7/8 primary stepped to 2 inch secondary into 3 inch collector.
Had made a sheet metal 9 inch, 35 spline moser axles, QA1 rear coil overs and mini-tubbed.
Glen and Cindy from Boomfunk can over and trimmed the boot area so i could mount fuel cell, battery box and fuel pump and filter .
Purchased Hopper stopper kit
Stripped engine bay and repainted
From this,
To this,
Installed B&M Pro Ratchet shifter into console. Wanted to maintain all the original interior.
During painting engine bay and getting tubs done. Bob Grant automatics was piecing together a full manual C4 capable of handling 800hp, 8 inch dominator converter(5500rpm) was getting a new balloon plate made by woolloongabba converters and engine builder was doing what engine builders do best(stuff me around). Anyhow engine changed from being 4V heads, TFC manifold,YT roller-rockers to CHI 3V heads, CHI manifold, jessel roller rockers. Finally engine was finished being built and dynoed midway through October 09. Figures were not to bad either.
So i was ready to put engine and box in on the 31st October. 30Th October, chopped end of finger off, operation next day, month off work,, school holiday trip to Darwin, change of jobs.
Anyhow engine and box is all in now so all the little fiddly bits to go. With all the luck i have been having of late, who knows when it will be finished.
Positive and negative comments welcome.
