fuel pump set up 5ltr in LX
_robrenjus_
Posted 03 February 2010 - 09:15 PM
#1. remove the low pressure pump and put in a high pressure pump and run a return line back into the top of the tank??
#2.fit a surge tank into the false floor ,use the low pressure pump to supply fuel to the surge tank then feed an efi high pressure pump?? OR
#3. if possible ,use the low pressure pump to supply a surge tank mounted where the charcoal canister is in the engine bay (is this legal in NSW) then to a high pressure pump, the fuel rail, then from the regulator back to the surge tank and a return line to the main tank. Has anyone done anything similar to this??where is a good place to put the return line?? can the charcoal canister be moved to just behind the r/h headlight if i use the smaller commodore one??
any help or advice is much appreciated ,cheers...
Posted 06 February 2010 - 02:12 PM
_robrenjus_
Posted 06 February 2010 - 02:30 PM
Posted 09 February 2010 - 07:37 PM
IF you can go to the trouble of fitting a commodore tank it would make it easier, or fit the internal swirl pot to the torana tank.
another cheap solution, how legal it is not sure fir a box section at the bottom of tank to create a low spot, have the pick up sitting in the box.
if you want bigger tank which is not a bad thing with torana might be easier to pick up a alloy drop tank, or have one made. it can be done for a reasonable price if you hunt around.
_robrenjus_
Posted 19 February 2010 - 10:47 PM
_nunganunga_
Posted 24 February 2010 - 07:56 PM
The plastic swirl pot inside the tank uses the return line and a venturi to scavenge any dregs of fuel to ensure constant pump immersion under most normal conditions and fuel levels.
Cheap, simple, and effective.
_robrenjus_
Posted 11 March 2010 - 10:24 PM
_robrenjus_
Posted 10 April 2010 - 07:26 AM
_robrenjus_
Posted 10 April 2010 - 07:39 AM
trial fitting the swirl pot
_@milco@_
Posted 11 April 2010 - 11:36 PM
_robrenjus_
Posted 15 April 2010 - 02:00 PM
mmmmmmm any more progress....
yep its all done pics to follow. 100 bucks and a six pack of beer and my radiator guy has done an awesome job of putting this all together again.
_robrenjus_
Posted 15 April 2010 - 09:53 PM
