LH HEATER CORE
25 replies to this topic
#1 _crabby_
_crabby_
Posted 19 February 2010 - 10:15 PM
looks like i have to replace the heater core in the lh for a rwc
saying i need a working heater for the demister?
any tricks to this , easy job?
thanx crabby
#2 _Woodsy_
_Woodsy_
Posted 19 February 2010 - 10:22 PM
its a pain in the butt, will take you a couple of hours to do, is the heater connected or is it bypassed? if its connected it may have a blockage in it which means u just have to flush it.
#3 _crabby_
_crabby_
Posted 19 February 2010 - 10:28 PM
hey woodsy
its not connected , so i rang the previous owner and he said it was leaking so he bypassed it.
he said in brisbane he didnt need one lol
think im goin to get a newy from rare spares or somwhere ? about $220
#4 rodomo
  • 18,031 posts
Posted 19 February 2010 - 10:34 PM
Go to your local radiator bloke and offer cash.
#5 _robrenjus_
_robrenjus_
Posted 19 February 2010 - 11:08 PM
i just did this in my lx, i had the option of replacing the heater core with a two hundred dollar one or get mine recored for 80 bucks and my radiator bloke recons it will work twice as good as any factory job it is a totally different core than the factory one and he tells me that they are way more efficient. while you are at it you can rebuild the heater box .just ask the radiator guy to get some of the foam tape that goes around the edge of the heater core and get some foam from the motor trimmers and replace all the foam on the vent doors .Takes a bit of time and patience but its better to do it right now than regret it later.
#6 TerrA LX
Posted 19 February 2010 - 11:15 PM
Pull it out and take it to a radiator shop or two for a quote for a reco.
#7 dattoman
  • 16,487 posts
Posted 19 February 2010 - 11:36 PM
http://cgi.ebay.com....=item3ef8716544
#8 rodomo
  • 18,031 posts
Posted 19 February 2010 - 11:41 PM
Correct. Talk to your radiator bloke and offer cash.
Hang on? I'm havin a deja vu here? :dontknow:
#9 TerrA LX
Posted 20 February 2010 - 06:55 AM
Twice as good or half the price :dontknow:
#10 _crabby_
_crabby_
Posted 20 February 2010 - 11:52 AM
thanx guys Posted Image
i will pull it out and do the rounds localy and see what price i can get it reco,d for
regards crabby
#11 _crabby_
_crabby_
Posted 22 February 2010 - 09:31 PM
well the heater core is out as well as half a forrestPosted Image
must of been stored under a tree at some stage or somethin tried to make a nest in there lol
will do the rounds tomorrow and see if i can get it reco,d
#12 _ass308_
_ass308_
Posted 23 February 2010 - 06:25 AM
i was told the same thing.the repo ones are more efficent.
i got my repo one pressure tested before i fitted it.
i also had my heater box vents retrimed as sugested
but the biggest pain in the arse in the firewall seal.this is what i did.
good luck
#13 _crabby_
_crabby_
Posted 23 February 2010 - 12:53 PM
droped the core off today and get it back tomorrow $125
cheaper than rare spares 230 + postage
retrimmed?...is that new foam on heater vents?
nice idea with thye pipes...i reckon ill do that
mine were just poking through the forewall and had some foam around it
Edited by crabby, 23 February 2010 - 12:54 PM.
#14 _crabby_
_crabby_
Posted 25 February 2010 - 09:13 PM
well the new heater core is in but now the next isseu
this might sound like a dumb question but where do the heater hoses go from the heater core out the firewall?
top hose and botom hose?
water pump has two outlets blocked off and thermastat has one?
thanx crabby
#15 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 25 February 2010 - 10:11 PM
I have one heater hose going to thermotstat cover outlet and the other to first water pump outlet.
However I dont have heated manifold.
Edited by fuzzypumper, 25 February 2010 - 10:12 PM.
#16 _crabby_
_crabby_
Posted 26 February 2010 - 07:02 AM
sounds like what i should do.
here is my manifold
#17 _manderin_red_slr_
_manderin_red_slr_
Posted 26 February 2010 - 11:29 AM
Your manifold is missing the bit that pre heats it. the first hose should go to the bit that you are missing, the second goes to the bottom of the heater core (i think) and the one on the passengers side of the manifold goes to the top of the heater core.....
I think...
from memory,,,,,
maybe i should be corrected???
Darren
#18 _crabby_
_crabby_
Posted 26 February 2010 - 01:03 PM
didnt know there was a pre heat , was just hoping i could run one hose to the thermostat and one to the water pump or both to the waterpump as it has two outlets just so i can get the rwc .
#19 TerrA LX
Posted 26 February 2010 - 01:46 PM
Just run the one from the thermostat housing to the tap side of the heater and the return to the pump.
If you have a second hose take off point on the thermostat housing and the pump then run a hose from one to the other too for the thermostat bypass..
I don't know what a pre heat is either.
#20 _manderin_red_slr_
_manderin_red_slr_
Posted 26 February 2010 - 02:35 PM
The one on the drivers side of the manifold,,, Pre heat or whatever its called.....its missin!
#21 TerrA LX
Posted 26 February 2010 - 02:39 PM
Oh, the inlet manifold preheat.
Forget about it unless you are chasing condition 1 or concourse.
Edited by TerrA LX, 26 February 2010 - 02:40 PM.
#22 _crabby_
_crabby_
Posted 26 February 2010 - 07:04 PM
sorry mate
didnt understand the tap side of the heater?
#23 _crabby_
_crabby_
Posted 26 February 2010 - 08:33 PM
found another thred on a similsr question and have hooked it up as follows
bottom hose going to waterpump and top to thermastat
seems to be doing ok , ran it for about 15min and demister is now warm(slightly but definatly not hot)
how hot should the demister get?
this isnt very hot at all but i can feel some warmth there
#24 TerrA LX
Posted 27 February 2010 - 09:33 AM
Tap side, on/off side.
Heater core should be as hot as the engine so the air coming out the ducts should be very warm to hot.
#25 _torbirdie_
_torbirdie_
Posted 06 March 2010 - 04:50 PM
Only ac models have a heater tap.
