What are your thoughts and experiences from using phenolic, wood, or plastic carb spacers? The idea is to reduce the amount of heat transfer from the intake manifold to the carb. This can only be a good thing - the cooler you keep that carb and fuel bowls, the more power - or more consistent power you should be able to make - especially in hot conditions.
If you browse the various speed shop websites, there are endless choices - open, 4-hole, divided, etc, plus different heights.
I'm very keen to fit one to my 383 small block. My reason is purely for the heat transfer advantage, I don't actually need the added height or anything as I already have plenty of plenum area, and I'm happy with my rev-range etc.
So I have a specific question - I want to know which style of spacer I should choose to suit my manifold/carb. I'm running a BG Mighty Demon 4 barrel (squarebore). The manifold is an Edelbrock 7501 - RPM Air-Gap Dual Plane. If you look at this photo below, you can clearly see the dual planes, and also note the cut-out section of the middle dividing wall (this cut-out is the main reason why I'm asking this question):
Ok, so spacer choices:
Firstly, height-wise, I'm leaning towards 1/2" tall (as small as possible).
This is a 1/2" phenolic 4 hole:
This is a 1/2" phenolic open:
This is a 1/2" wood fibre laminate 'Divided Plenum':
Check this one out - 1/2" wood 'Divided Wall' - very strange shape - what on earth for???
THOUGHTS????
