Banjo Torana stud convert to HQ stud
_TRRANA_
Posted 24 March 2010 - 07:00 PM
Has anyone done this whilst retaining the standard torana drum brake setup? Ive noticed it would seem dodgy to drill the flange because of lack of room and weakening of the steel.
If was to get some custom made Billet/Moser axles do you think the size of the axle face would foul behind the drum etc? (drum would have new stud holes drilled by engineer)
People may say replace the diff with a nine inch with hq stud etc, but this diff is fully fresh with new brakes, so i was just seeing if its just as easy as banging in a new set of axles, so i can remove them at anytime if i wanna go back to normal stud.
Any advice would be appreciated.
Dorzy
Posted 24 March 2010 - 07:15 PM
Before you get new axles made though, go and find some HZ or WB disc brake Salisbury axles and measure the flange diameter. I think you'll find they are awful close to Torana flange size as the disc has to go over them. These are a small flange with 4.75" PCD, so do the sums. Maybe a Torana sized flange can be OK with HQ stud pattern? Talk to a quality diff shop first though!
Posted 24 March 2010 - 07:18 PM
Yes it can be done - an L34 runs a Banjo with HQ pattern, but I don't believe that the drums are Torana drums.
Is it feasible? Well not really. I can understand swapping the axles to go back to Torana pattern, but if you want to do that, the BEST way is to have a Borg Warner 78 series rear end with a pair of HQ axles & rotors and a pair of Torana axles & rotors.
Either way it costs a bit to get where you want to be. If you want to have some real fun with the car, you'll probably need a tougher diff anyway. If you're not into that kinda thing, well yeah it's still expensive for not a lot of gain!
Posted 24 March 2010 - 07:43 PM
Posted 24 March 2010 - 08:00 PM
I have an LSD Banjo drum brake diff in my LH. It is in torana stud pattern. I would like to convert it to HQ stud pattern.
Dorzy
No, the drums will not fit.
You will need to change the whole braking system on the rear to go to HQ pattern.
Posted 24 March 2010 - 09:48 PM
this is the answer on how it was done
Quote
Holes filled,From what I can see they have removed old studs, filled holes, welded a ring onto flange, turned in lathe to clean up and true, redrilled new stud pattern,new wheel studs fitted, larger supporting ring added to centre, new wheel bearings fitted. It was also explained to me as such when I had it done.
The other option is to find a pair of genuine L34 axles and use hq drum brakes as std Torana brakes will not fit
or get some Hq or 1 tonner axles shortened and resplined
I may have a pair to sell
tn
_stu.slr_
Posted 24 March 2010 - 10:27 PM
_TRRANA_
Posted 24 March 2010 - 11:25 PM
Posted 25 March 2010 - 01:07 PM
Cheaper, lighter, and you won't be needing anything stronger IMHO.
If you still want drums, go the HK-T-G 10" drums then just swap the drum over to an HQ-J-X-Z later when you change to HQ pattern/diff.
Grant..
