9 Inch Diff oil change
#1 _Bart15_
Posted 27 March 2010 - 05:59 PM
Posted 27 March 2010 - 06:11 PM
Level should be checked at every service
And I would replace every 2 yrs myself
#3 _Bart15_
Posted 27 March 2010 - 06:59 PM
Posted 27 March 2010 - 08:34 PM
If not then you need to undo some bolts and pull the centre forward to let the oil drain out the gap
And refill thru the upper plug
If no upper plug... out with an axle and pour it down the tube
I think they hold about 1.5L
But it would pay to check that
Posted 27 March 2010 - 08:43 PM
There should be a fill point again on the carrier that you can undo with a quarter inch drive generally
Fill with appropriate grade oil till it starts to come out this fill point
Of course this will depend on the year and model the original diff came out of.
Posted 28 March 2010 - 03:14 AM
There is a filler plug in the side of the centre. The oil capacity varies depending on the housing, somewhere around 2.5 litres should see oil at the filler plug. If you have a LSD then you will need to use LSD oil.
You could pull an axle and drain the housing that way. If you are going to unbolt the centre then I would remove it completely and replace the gasket or use silicone to seal the centre.
Edited by ls2lxhatch, 28 March 2010 - 03:18 AM.
#7 _Bart15_
Posted 28 March 2010 - 07:24 AM
Posted 28 March 2010 - 12:49 PM
This might only work if your able to turn the car on its side... bit hard to get the oil out of the housing this way
Unless the diff if out of the car
Posted 28 March 2010 - 02:16 PM
Posted 28 March 2010 - 03:48 PM
The oil in the nine inch in the daily is now 16 years old and all still sounds fine. Its had a fair flogging over the years too with plenty of power and sticky tyres.
By all means change it if you like when you first get the car as its an unknown from perhaps a cheap skate prior owner but after that I would leave it alone for at least 5yrs/100,000km.
I always use a heavy full synthetic oil.
#11 _2wild4u_
Posted 29 March 2010 - 12:25 AM
Posted 29 March 2010 - 08:16 PM
This being the drain plug.
I changed the oil in mine last week.
Posted 30 March 2010 - 01:01 PM
A magnetic drain plug or just a magnet in the bottom of the diff housing (I used a Hard Drive magnet in my Banjo) should do a decent job of collecting ferrous material
But yes unless your diff is overheating (quite possible!) to 'break down' the oil, and there are no real contaminants, you shouldn't need to change the oil. Agree with the comment about if you don't know the history of the vehicle etc then change it.
Posted 30 March 2010 - 01:13 PM
Again the center is attached to the housing with studs but the bottom one is not a stud but a bolt
There are no bolts just studs in the two 9" housings I have. I had the drain plug fitted when the housing was made.
McDonald Bros Housing
Edited by ls2lxhatch, 30 March 2010 - 01:24 PM.
Posted 30 March 2010 - 02:00 PM
http://www.steeltech....com/FORD9.html
Posted 30 March 2010 - 11:13 PM
But the oil drain is the bottom bolt of the carrier in bolt in the 2 XB GT's and my XC Coupe but eh its not a McDonald Bros housing, or I didn't get these made so I suppose Ford must have
got it wrong,
Posted 31 March 2010 - 01:44 AM
The truck housing is stronger and more commonly available at the wreckers therefore it is the basis for the majority of diff conversions. I had one housing built by John Taverna Chassis and one built by Final Drive. Both conversions used original Ford truck housings with full studs and no drain plug. I took the housing in the picture above back to Final Drive and asked him to put in a drain plug.
Posted 31 March 2010 - 08:37 AM
Posted 31 March 2010 - 03:42 PM
alot cleaner when changing the oil and with a magnetic plug alot more chance of picking up any metal etc
I agree with Andy to that the year and type of vehicle the diff originated from determines the different housing styles
Posted 14 February 2013 - 11:19 PM
Also, are gaskets easily found (Supercheap, Repco, Ford dealer etc??) for the 9 inch centre? I want to swap mine over on the weekend.
#21 _434LX_
Posted 14 February 2013 - 11:31 PM
Dont know if you could get the tube in the fill hole and down into the oil.
#22
Posted 14 February 2013 - 11:40 PM
And 9" gaskets should be easy enough to get
#23
Posted 15 February 2013 - 07:37 AM
#24
Posted 15 February 2013 - 11:45 AM
Sounds like the way to go.
#25
Posted 15 February 2013 - 03:42 PM
