Plastic Welding
9 replies to this topic
#1 _MR & MRS L34_
_MR & MRS L34_
Posted 04 April 2010 - 11:11 AM
Hi all does anyone know off or had any plastic spoilers repaired by a plastic welder in the Fremantle or Perth area ,my spoiler on the boot has the normal cracks in it and needs to be repaired.
thanks Pete..
#2 _Yella SLuR_
_Yella SLuR_
Posted 04 April 2010 - 11:40 AM
Sorry mate, but don't leave your hand on top of the spoiler when you shut the boot, that's what splits em to start with.
Would love to have a broken one to provide the material to repair them with!!!
#3 _SableMet7/73_
_SableMet7/73_
Posted 04 April 2010 - 01:19 PM
Hi Pete,
havnt had spoilers done but have had bike plastics repaired/welded
before, maybe try them as well.
Theres Plastonics in Belmont...9277 1737, Hollywood P&P Welshpool...9451 5595
used to be Motorcycle P&P in Ossy Park but cant see him listed ATM.
Watched him repair a panel once, he just used a paint stripping gun & melted
a cable tie into the crack then sand, fill & sand. All looked too easy..
Ohh & I've only used the bloke in Ossy Park so cant vouch for the other places
but know that Plastonics has been around for a fair while now.
Jono
#4 _lx5008_
_lx5008_
Posted 04 April 2010 - 02:24 PM
here in newcastle does a great job. if all else fails i can look after that from here for ya.
#5 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 04 April 2010 - 08:38 PM
the spoilers are ABS plastic, a simple crack likr they get is very easy to fix and you can buy ABS rods, I repair my own.
#6 _MR & MRS L34_
_MR & MRS L34_
Posted 05 April 2010 - 08:48 AM
Thanks guys 4 the replys i might try and repair myself has crack bove kehole about 2 inches long. Who do you buy these ABS rods from and how do you apply them , with a heat gun or something else ?
#7 Heath
  • 18,394 posts
Posted 05 April 2010 - 09:34 AM
Soldering iron of some description is what I've seen used.
#8 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 05 April 2010 - 09:53 AM
There are suppliers on the net of the rods, I'll find the company name I use. You can use a soldering irn or some parts of the job, a heat gun is better, but you need a small tip and ABS neeeds to be done at 300degrees. I recomend a small pen type butane heat gun as a proper plastic welding gun like I have is about $900.
#9 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 05 April 2010 - 10:57 AM
wouldn't it be cheaper in the long run to learn to drive properly, stop crashing into things .....
#10 _MR & MRS L34_
_MR & MRS L34_
Posted 05 April 2010 - 11:24 AM
Thanks Red for the information much appreciated.
