walkinshaw wheels on my Torry
19 replies to this topic
#1 _robrenjus_
_robrenjus_
Posted 04 April 2010 - 10:06 PM
i want to fit a set of polished VL walkinshaw wheels to my LX Torana , i am running a hoppers style brakes with commodore stud pattern on the front and a commodore borg warner diff. the wheels look great but they are shaped in a way that i cant get them to sit flush up against the hub, and they wouldn't clear the caliper anyway. so i have a couple of options #1 is simply fit wheel spacers but i am worried about the legal ,safety and insurance side of things. or#2 have spacers welded to the back of the wheels . does anyone do this ??? anyone here had that done?? is it no better to weld them on ?? is the pressure on the studs any different if the spacer is made into "part of the wheel"??i would love to use these wheels but if it cant happen than so be it i'll have to get some wheels made up. here is a pic of the wheel on my car
#2 dattoman
  • 16,487 posts
Posted 04 April 2010 - 10:55 PM
The "welded" spacers would be the better idea
But isn't the offset all wrong and the wheels sit way in?
This effects your steering geometry and makes the car harder to steer... worse with big wheels and sticky rubber
I've seen it done but I'm not a fan of the look
Another thing to consider is the studs would have to be extra long to go anywhere near getting it right
Lots of stress on the studs and bearings
I wouldn't recommend it personally
#3 _robrenjus_
_robrenjus_
Posted 05 April 2010 - 07:57 AM
the offset has been brought out by the front brake set up and when this is combined with the spacer the outer edge of the wheel nearly sits out as far as the guard. the wheels are only 7 inch and ive had 13x7 inch wheels on before , it was heavy but i was going to run a more narrow tyre than the 225's in the pics. And yes the studs would have to be increased in length by around 15-20 mm. but the stress on studs and bearings does concern me
#4 _robrenjus_
_robrenjus_
Posted 05 April 2010 - 09:35 AM
i am talking about an 8-10 mm spacer by the way.
#5 dattoman
  • 16,487 posts
Posted 05 April 2010 - 10:25 AM
8-10mm will be OK
But I would step up to 1/2" studs myself
Maybe even spring for ARP ones just to be extra safe if your planning on doing any roundy roundy track work
#6 _LH SLR 3300_
_LH SLR 3300_
Posted 06 April 2010 - 05:43 PM
I have a Hoppers front brake upgrade on my LH & i found 16x7 inch Commie rims foul the top ball joint.
#7 _robrenjus_
_robrenjus_
Posted 06 April 2010 - 07:33 PM
thats strange !! i have 15x6 stock commy wheels on there at the moment and they are close ,but the 16's seem to clear by heaps both elevated and at normal ride height (i have only tried the vl wheels not later model ones), i am guessing yours is commodore stud pattern ?? did you get custom offset wheels ??
#8 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 06 April 2010 - 08:24 PM
You don't meed to weld the spacers on, just drill and tap the spacer and the rim and bolt them on with some countersunk head bolts.
As well as the longer, stronger studs ensure the rim still locates the centre bore on the disc as originally intended. This shouldn't be a problem at 8-10mm but it would pay to check.
JMHO
#9 bryanw
bryanw
  • 294 posts
Posted 13 March 2013 - 01:26 AM
ok, dragging up an old topic, was there an outcome? also which diff etc, was it shortened?
thanks
#10 _robslxhatch_
_robslxhatch_
Posted 18 March 2013 - 09:29 PM
I ended up selling the Walky wheels and picked up a set of ROH Chicanes that were the right stud pattern/offset and look great.
#11 _team bullet_
_team bullet_
Posted 17 October 2017 - 02:50 AM
Thats odd, we've been running ours for years running same set up.
No issues with steering or rubbing.
Denny
#12 _team bullet_
_team bullet_
Posted 08 August 2018 - 03:24 AM
Revisiting an old topic, im in the process of cutting down the 2 fronts on mine, to either a 5.5 or 6 inch wide rim.
Just chasing thoughts of anyone running skinnies on front as to what the best width would be for tyre sizes?
Denny
#13 _team bullet_
_team bullet_
Posted 08 August 2018 - 03:27 AM
Edited by team bullet, 08 August 2018 - 03:34 AM.
#14 _team bullet_
_team bullet_
Posted 08 August 2018 - 04:14 AM
#15 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 08 August 2018 - 08:27 PM
Hi Denny,
I don't know what tyre size to use, but who is cutting your wheels down from 7 to 5.5?
I would guess it means cutting the rim in a lathe or similar then trimming an inch off one side and welding back together?
Cheers, Tom
#16 _team bullet_
_team bullet_
Posted 09 August 2018 - 04:56 AM
Yes mate, a friend named Wally from Neale wheels, its what they do, he's been flipping and changing offsets for me for 20odd years now in our racetrucks and my 4x4s
He knows what he's doing..
Denny
#17 _team bullet_
_team bullet_
Posted 09 August 2018 - 10:42 AM
Thinking leave the rears at 225 50 16 and this could be an option for fronts
#18 _team bullet_
_team bullet_
Posted 09 August 2018 - 10:51 AM
or even better. 175 60 16 which is 24.3"diameter and only 6.9"wide
Anyone have any opinion on what would look better...
Thanks in advance
#19 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 09 August 2018 - 07:52 PM
Thanks Denny,
I had spoken to Neales about getting a pair of Walkinshaw wheels converted to 8"
Can't help with how the skinny tyres would look. I Prefer a wider front.
Mine are 205 55 16
#20 _team bullet_
_team bullet_
Posted 17 August 2018 - 03:56 AM
Yes Tom, he's widened for me before too.
Got the fronts back ready for the rubber..
Denny
Edited by team bullet, 17 August 2018 - 03:58 AM.
