rallymaster/sprintmaster
14 replies to this topic
#1 Burrawout
Burrawout
  • 80 posts
Posted 30 May 2010 - 09:04 PM
Have seen a set of Sprintmaster style mag wheels. They have self locating wheel nuts that go right into the base of the mags,not fastening on the top like the CSA wheel nuts. These mags have no castings/dating or id markings on them like the Globe Sprintmaster or CSA copies. Could they be Rallymaster wheels, like I have read about that were used on early LC Rally cars?
#2 blake
blake
  • 267 posts
  • Name:Blake
Posted 30 May 2010 - 10:30 PM
ye mate, i think your right. i had the same issue with a set of globes i got. there blank also and i found out from people off this forum that there was a high possibility that there off of the eraly rally cars. so i think thats what there off of from what i know so far.
cheers Blake
#3 jpxu1
jpxu1
  • 570 posts
Posted 08 June 2010 - 11:07 PM
The very first Sprintmasters weren't date coded.
The Rallymaster wheels have a deeper offset to the Sprintmasters.
Aldo or Brad may care to help with some pics.
Cheers,
jpxu1 :)
#4 _73xu1_
_73xu1_
Posted 09 June 2010 - 05:35 PM
i also would like to see some good photos of both kind. get those cameras clicking!Posted Image
#5 _1973bathxu1_
_1973bathxu1_
Posted 09 June 2010 - 07:26 PM
Hi there were 2 different off sets for the sprint master/rally master mags,
the rally master mags off set is aprox 13 mil more to the sprintmaster which kicks out towards towards the guard
looking a the 2 mags u cant tell
im sure ive got a couple of each mags, ill see i i can take some photos to show u the differences in the 2 with a measuring tape
regards aldo
#6 _73xu1_
_73xu1_
Posted 09 June 2010 - 08:26 PM
if you could get photo showing how the date is missing that be great of you aldo.
mine have the date circle but no date or dots.
#7 Burrawout
Burrawout
  • 80 posts
Posted 11 June 2010 - 03:43 PM
If they are genuine rallymaster what date code period would suit a LC?
#8 _1973bathxu1_
_1973bathxu1_
Posted 16 June 2010 - 08:54 PM
Hi im sorry it took so long to put the photos of a 73 sprintmaster mag and the rally master mag
if u put them side by side on a torana they would be very hard to pick until u actually see the difference for yourself
the 1st pic is a 73 sprint master
the 2nd pick is the rally master
the 3rd pic is the rally master with the square edge the letter H stamped in no date numbers
the 4th pic is the 73 sprint master self locater
the 5th pic is the rally master which measures 116 mil approx the difference in off set is 13 mil
the 6th pic is the 73 sprint master mag which measures 129 mil approx
the 7th pic isthe 73 sprint master mag and it measures 37 mil approx
the 8th pic is the rally master mag which measures 50 mil approx
and the 9th and the 10th pics are just to see the differences between the 2 mags
ive put the tape measure on the 2 mags for every one to see
the photos will show that there is a sizible difference in the off set between the 2 mags
i hope this helps any one that was interested
regards aldo
#9 Burrawout
Burrawout
  • 80 posts
Posted 16 June 2010 - 09:06 PM
Great info. What LC's wore them?
#10 _macdou_
_macdou_
Posted 04 February 2012 - 02:11 PM
Hi
Does anyone know or have a pick of the rallymaster centre caps from factory?
#11 _Mike73_
_Mike73_
Posted 06 February 2012 - 04:42 PM
Hello,
is it possible that the deeper dish wheels were used at a later date ( 1973 - 4 ) instead of having to use a stack of spacers and problems that would arrise from those. wouldn't the later wheel nut type be an indication they could be 1973 - 4 ?
I think it was the overall track that had to be maintained, don't think it mattered how they got there?
Does the offset difference match up to the 1973 spacer stack thickness?
I have a couple of the deeper offset ones here, but they are 14" and have a different shape rim edge, I assumed they were from a HK - T- G, perhaps they are 1973 wheels afterall.
Contrary to some interertations of the rules, they were permitted to race with 14" wheels, and HK- T - G front brakes as they had the same pad surface area.
Mike
#12 brocks72xu1
brocks72xu1
  • 730 posts
Posted 06 February 2012 - 07:03 PM
hi aldo
i have two rallymasters they are on the rear of my car,and 6/72 rims on the front,even the finish is different once polished between the two
#13 _JamesB_
_JamesB_
Posted 21 March 2012 - 11:09 PM
I have a set of 4 of 13x6 RallyMasters on my UC. Unlike the RallyMasters in the above photographs, mine have a rough cast natural alloy finish (rim is machined and polished) instead of the machined spokes and black paint trim, but like the one in the photographs, they are not self locating. In the early 80s, I painted the spokes and caps with black engine enamel, but a bit of paint stripper will take that off easily.
The rough cast RallyMasters are the wheels you'll usually find on a HDT rally prepared LC XU-1, and I think they were also used on the supercharged LC GTR that Brock used to rallycross.
I got my RallyMasters back in 1974 at a sale of flood damaged wheels after the 1974 Brisbane floods. They had piles of them @ $35 each in water damaged boxes. In each box was also a set of wheel nuts and a centre cap stamped with the the Globe "World" logo and then filled with blue and yellow paint. They went onto my LC 4 door and replaced the 13x5.5 GTR rims that I was running. A mate bought a set of 14x6 SprintMasters at the same time for his HG, but the different size and offset made them look weird to me.
Interestingly, the extra 1/2" offset makes them more closely match the offset of the 13" wheels fitted to the HR and earlier Holdens, while the SprintMaster version with less offset more closely matches the offset on the Toranas.
I had a couple of problems with the RallyMasters. Firstly, the alloy was just a bit porous, and I found that I needed to run tubes. Secondly, when I fitted them on to the UC, the stick on weights that they need to run, fouled the rear disk brake calipers on my factory 4 wheel disk installation.
#14 liswar2
liswar2
  • 1,513 posts
  • Name:Wazza
Posted 04 April 2012 - 10:57 PM
Hi , i am after some wheel nuts for my self locating rims , and they need to be the conical type , as the flat nuts with washers are unsuitable ,
March 30th under wanted ,
i have the info from the rim, are these Rally Masters ?
any help appreciated.
wheel nuts appreciated , thanks liswar
sorry for stealing the thread.
Edited by liswar, 04 April 2012 - 10:58 PM.
#15 _JamesB_
_JamesB_
Posted 04 April 2012 - 11:38 PM
Try seller brettcnc on eBay. He doesn't have any on his eBay page at the moment, but he was making and selling copies of the different styles of Globe wheel nuts.
I was after a few of the washer type nuts to replace some damaged ones on my RallyMasters. I haven't had any dealings with him since 2007, but back then, he'd only sell them in full sets of 20 for about $90.
