Interchangeable front suspension subframe LH-LX Torana
_mr hatchback_
Posted 10 June 2010 - 12:49 AM
I am currently restoring a LX SS Hatchback Torana & I have a donor LH Torana that I have been stripping for some parts & I wish to know
if the front subframe & suspension are interchangeable as I would like to restore that front subframe & suspension, control arms etc so as
to drop my my 355 Cubic Inch Stroker in over one weekend instead of pulling the existing subframe out & waiting for ages for it to be
restored from many different companies as there is always some sort of hold up.
Posted 10 June 2010 - 07:02 AM
http://www.gmh-toran...showtopic=14102
_Torrie_Man_
Posted 23 June 2010 - 07:00 PM
Posted 23 June 2010 - 07:08 PM
_Squarepants_
Posted 25 June 2010 - 08:12 PM
How is it not ideal? Because of the ratio? Or is there some other stuff that can be done to them to make them better?And a different rack ratio and inner pivot point on the top arms. Read up and figure out what would suit you best. An untouched UC rack is not ideal.
Posted 25 June 2010 - 10:29 PM
Posted 26 June 2010 - 11:01 AM
I don't own a UC crossmember but I was told that the mounting studs where that bar gets bolted onto the crossmember to have the top wishbone pivot around it, were located really high on the UC setup, and you want to pull it apart and redrill them to be lower down, I guess to control the camber differently.
OOTB they are not ideal, But yes I do realise that they have metal bushes on the rack, top balljoints located a bit aft on the top wishbones and a pair of steering arms that provide less bump steer, or so I have heard!
Posted 26 June 2010 - 06:02 PM
Find a UC front end, follow the guide in the above post, get it painted or powder coated, you will be much happier.
_Squarepants_
Posted 26 June 2010 - 07:35 PM
Yeah, from what I have gathered you should mount the UCA pivot bar 25mm (I think) lower that standard (to LX RTS position) to get the best camber radius, but that's not got anything to do with the rack.Yeah the ratio is one part
The LH LCA's are made from thicker steel but they don't have the steering arm stops on them, which causes clearance issues (in my car, anyway, with Hoppers brakes on it)
The steering rack ratio is slightly slower in the UC's so if you were really keen you'd make up solid bushes for an LX (rts?) rack and use it.
UC steering arms are the best unless you're running HQ stubs, in which case you're better off getting A9X or Harrop arms.
That's about all I can remember off the top of my head, all of this has been covered in previous threads.
Mr Hatch, I would suggest reading them and making your own decision.
Posted 26 June 2010 - 10:16 PM
Actually there are no bushes at all on the rack, just smaller mounting holes for the bolts only. The steering arms sit the tie rod end slightly further forward and a bit lower to make up for the increased caster - for a setup with a decent amount of caster this would be less bump steer compared to LH/LX arms, but not necessarily for a factory LH/LX setup. I.e. no particular set of steering arms is better for bump steer, they need to be matched to the suspension/settings.they have metal bushes on the rack, top balljoints located a bit aft on the top wishbones and a pair of steering arms that provide less bump steer, or so I have heard!
Posted 27 June 2010 - 06:41 AM
Posted 27 June 2010 - 02:04 PM
The general consensus is that the lower position is better for a track car with HQ stubs. However the HQ stubs lower the car 1" which basically alters the suspension geometry. Larger bump stops were added to reduce upwards suspension travel by approximately 1".
The lower position may be the ultimate position for a race car with HQ stub axles, it may also be the ultimate position for a street car with HQ stubs. However it may not be the ultimate position for a street car with Torana stub axles.
It would appear that the designers found that the optimal position for a street car with Torana stubs is the high UC position. The question is why? Did they feel that the car suffered from over steer and wanted to increase under steer or was there some other benefit?
Posted 27 June 2010 - 03:22 PM
_mr hatchback_
Posted 06 July 2010 - 06:44 PM
I will be keeping the HQ stud pattern as I am using the HQ GTS Rallye Wheels as I am a big fan of the old school steel wheel look, I also used a suspension place here in Sydney called Heasmen Suspension & Steering & they were very helpful with sorting out my other LX Hatchback thou not cheap as that is the norm when you want good professional advice & work you pay good money which I have no problem with.
