New front end for LC-LJ
31 replies to this topic
#1 _HRH by DESIGN_
_HRH by DESIGN_
Posted 04 July 2010 - 07:44 PM
Hi guys a quick hi and thought i would share with you the new double wishbone tubular front end ive developed for LC-LJ Torries
Can be supplied with standard spring and shock, or coilover, or airbag, runs standard rack and any brake package
Hope you guys like it,
cheers Matt
Posted ImagePosted Image
Edited by HRH by DESIGN, 04 July 2010 - 07:53 PM.
#2 _Bomber Watson_
Posted 04 July 2010 - 08:13 PM
OOoooooo me likey.
#3 _HRH by DESIGN_
_HRH by DESIGN_
Posted 04 July 2010 - 08:23 PM
OOoooooo me likey.
Thanks mate, we put a heap of work and research into this and are wrapped with the results, we have 2 LC's in the shop right now getting these front ends and can als do them for any early holden, available in stainless too, Matt
#4 dattoman
  • 16,487 posts
Posted 04 July 2010 - 08:25 PM
Best get some pics of an LH-X one happening
#5 _HRH by DESIGN_
_HRH by DESIGN_
Posted 04 July 2010 - 08:40 PM
Hey datto, yep we are onto it, the LH-LX is actually easier for us and will be finished by end of week, luckily i also have a LH in the shop for respray at the moment, so can work off that one, cheers Matt
#6 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 04 July 2010 - 08:48 PM
That looks great, with these top arms i reckon would be better.
Adjustable Chrysler screw in ball joints.
#7 _HRH by DESIGN_
_HRH by DESIGN_
Posted 04 July 2010 - 09:08 PM
Nice looking arms, would not really match the bottoms though, also comes down to cost, my arms can be produced all in house and and well priced, utilising gemini ball joint, so cheap to replace, my bottom arms utilise HQ balljoint, would like to look into a high end arm though, i could make them, also comes down to what engineer would say, would be interesting to see the breaking point of them. cheers
#8 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 04 July 2010 - 10:17 PM
Dont know about the breaking point, but they are designed for the big old US tanks, Chevs, Pontiacs, Camaro's etc
#9 _2DR_
_2DR_
Posted 05 July 2010 - 11:41 PM
looks the goods what sort of dollars are we talking?
#10 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,671 posts
  • Car:LJ GTR
Posted 05 July 2010 - 11:48 PM
Put me down 4 being very interested also Matt..
#11 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 06 July 2010 - 01:52 PM
Matt, do they come complete with Eng Cert?
Bart, what's your engineer say about certifying those for a road car??
Grant..
#12 _HRH by DESIGN_
_HRH by DESIGN_
Posted 06 July 2010 - 08:33 PM
Grant..
We are getting them tested at the minute, all looking good. They have great strength and design. They will require that you send me your crossmember, or I can source if required.
Alternatively we can fabricate a all new crossmember also, however I like retaining the original crossmember
Thanks Matt
#13 _HRH by DESIGN_
_HRH by DESIGN_
Posted 06 July 2010 - 08:48 PM
Price will depend on end requirement.
Can you supply crossmember
Do you want Torana or HQ stub axles
What brake package, can run any size rotor and any caliper combo from Stock or Hq to 355 mm HSV
Mild steel or stainless arms
Spring or coil over.
At an indication the one pictured is around the $1500 mark with customer supplying crossmember, stubs, springs
Cheers Matt
#14 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 06 July 2010 - 10:44 PM
Just wondering if the caster rod is still used in this setup?
#15 _HRH by DESIGN_
_HRH by DESIGN_
Posted 06 July 2010 - 10:55 PM
No caster rods used in this setup. That's the beauty of it. Frees up all that room too. Front end is secured with 4 19mm grade8 bolts, or can even be welded in
#16 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 07 July 2010 - 08:08 PM
Grant..
Good question, the engineer sighted them but cant remember if its in the report.
Will have a look
Any chance in getting arms and cross member in aluminium? Just to drop the weight a bit.
I was thinking adapting alloy BMW lower arms
Edited by Bart, 07 July 2010 - 08:17 PM.
#17 _HRH by DESIGN_
_HRH by DESIGN_
Posted 10 July 2010 - 05:23 AM
Grant..
Will have a look
Can't see the point in alloy, to get same strength weight would almost be equal, and negligible,
Just add more horsepower, lol
#18 _Bomber Watson_
Posted 11 July 2010 - 02:55 PM
Think the advantage is moreso a lower unsprung mass....
#19 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 July 2010 - 10:31 PM
Thats it
But mild steel is ok, im just being fussy
Titanium would be to go, light and strong, not as expensive as some may think because the amount of material isnt huge
Thats it
#20 _dickiep_
_dickiep_
Posted 11 July 2010 - 11:04 PM
looks the goods. can someone explain the benefits of this set up compared to standard setup? to someone who doesnt know much about suspension!
#21 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 July 2010 - 12:13 AM
I would say the lowers would have less binding and better geometry since the caster rod is eliminated. And the arm it self would be stiffer under load.
#22 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 July 2010 - 12:38 AM
Titanium and aluminium Lateral links for WRX's.
So it may be possible to make Titanium arms
http://www.poltec.us...teral_links.htm
#23 Heath
  • 18,376 posts
Posted 12 July 2010 - 07:41 PM
I think you'd have to say that chromo would probably be a good material for a 'high end' one. In the same way that the better rollcages are chromoly. You can get away with thinner wall sections and lower your unsprung mass.
I'll be listening intently when I see the LH-UC jobs released :)
#24 _niterida_
_niterida_
Posted 12 July 2010 - 09:15 PM
I'll be listening intently when I see the LH-UC jobs released Posted Image
Yep Cr-Mo and LH-UC ones sound like a good idea to me too Posted Image
#25 ls2lxhatch
  • 5,332 posts
Posted 12 July 2010 - 09:44 PM
McDonald Bros have a full tubular front endfor the LJ $4500 inc shocks.
McDonald Bros will build one for the LX if someone puts down a deposit. The LX tubular k-frame is around $2200. Then you have to add the price of tubular wishbones and your choice of coilover shocks.
